[opa-nightly-tests] Fwd: honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
Quincey Koziol koziol at hdfgroup.org
Tue Aug 17 08:05:04 CDT 2010
Hi Larry/Neil,
	Can you take care of this?
		Quincey
Begin forwarded message:
> From: Dave Goodell <goodell at mcs.anl.gov>
> Date: August 17, 2010 7:59:03 AM CDT
> To: opa-nightly-tests at lists.mcs.anl.gov
> Subject: Re: [opa-nightly-tests] honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
> Pavan updated OPA yesterday to use libtool in the build system.  The source trees need an "autoreconf -vif" run.
> -Dave
> On Aug 17, 2010, at 1:05 AM CDT, HDFTEST Community User wrote:
>> *** OPA Tests on 0817Tue ***
>>  Tests Summary
>> ****FAILED honest1: standard****
>>  Tests Time Summary
>> honest1: Ran 1(0/1/0) tests, Grand total test time =  0m 4s
>> honest3: Ran 1(0/0/0) hosts, Grand total test time =  0m 58s
>>  Timekeeper log
>> Timekeeper started at Tue Aug 17 01:04:59 CDT 2010
>> Timekeeper sleeping for 1800 seconds
>>  Tests Failures
>> Dumping logfile of honest1: standard
>> Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0817Tue_0105
>> PBS_DEFAULT=abem5.ncsa.uiuc.edu
>> PKG_CONFIG_PATH=/usr/local/lib64/pkgconfig
>> PLATFORM=linux-rhel4-x86_64
>> PWD=/u/ac/hdftest/snapshots-opa
>> SHELL=/bin/tcsh
>> SHLVL=3
>> SOFTENV_ALIASES=/usr/local/softenv-1.6.2-r3/etc/softenv-aliases.csh
>> SOFTENV_LOAD=/usr/local/softenv-1.6.2-r3/etc/softenv-load.csh
>> SSH_CLIENT=141.142.31.132 42984 22
>> SSH_CONNECTION=141.142.31.132 42984 141.142.31.130 22
>> TG_APPS_PREFIX=/usr/local
>> TOTALVIEW=/usr/apps/tools/toolworks/totalview/bin/totalview
>> TOTALVIEW_HOME=/usr/apps/tools/toolworks/totalview
>> TVDSVRLAUNCHCMD=ssh
>> USER=hdftest
>> VENDOR=unknown
>> VMI_SPECFILE=/opt/vmi-2.2.0-1-gcc/specfiles/openfabric.xml
>> WHATAMI=linux-rhel4-x86_64
>> _=/usr/bin/printenv
>> ===Done Dumping environment variables after option parsing ===
>> Configure command is configure  --prefix=${PWD}/opainstall
>> CURRENT is /u/ac/hdftest/snapshots-opa/current
>> ===== Run Tests: Tue Aug 17 01:05:15 CDT 2010 =====
>> Check to see if TESTDIR /u/ac/hdftest/snapshots-opa/TestDir/honest1 exists
>> /bin/sh ./config.status --recheck
>> running CONFIG_SHELL=/bin/sh /bin/sh /u/ac/hdftest/snapshots-opa/current/configure --prefix=${PWD}/opainstall --no-create --no-recursion
>> checking for a BSD-compatible install... /usr/bin/install -c
>> checking whether build environment is sane... yes
>> checking for a thread-safe mkdir -p... /bin/mkdir -p
>> checking for gawk... gawk
>> checking whether gmake sets $(MAKE)... yes
>> /u/ac/hdftest/snapshots-opa/current/configure: line 2342: syntax error near unexpected token `2.2.6'
>> /u/ac/hdftest/snapshots-opa/current/configure: line 2342: `LT_PREREQ(2.2.6)'
>> gmake: *** [config.status] Error 2
>> TESTDIR is /u/ac/hdftest/snapshots-opa/TestDir/honest1
>> snapshot is yes
>> ===== configure: Tue Aug 17 01:05:16 CDT 2010 =====
>> Failed running configure
>> ===== Exit bin/snapshot with status=2: Tue Aug 17 01:05:18 CDT 2010 =====
>> Dumping done
>> Runtest did not exit normally.
>>  Watchers List
>> OPA Daily test features/platforms watchers and procedure
>> Procedure:
>> The watcher will investigate and report the cause of failure by 11am.
>> The developer who checked in the error code may report so by then too.
>> The watcher or the developer should get the failure fixed and report it
>> by 3pm.
>> Watcher for OPA:	 	Neil
>> updated: 2009/05/05
>>  Tests Details
>> Testing all hosts.
>> opa
>> 01:04:40 up 19 days, 10:12, 28 users,  load average: 0.06, 0.10, 0.40
>> Filesystem           1K-blocks      Used Available Use% Mounted on
>> none                   8218016         0   8218016   0% /dev/shm
>> abem4:/var/lib/perceus/
>>                     74763440  42299920  28665712  60% /var/lib/perceus
>> 10.1.69.1:/usr/src   138916864  99971520  31888736  76% /usr/src
>> /dev/sda3             29463920     47088  29119552   1% /tmp
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
>>                    3385032528 620743632 2592338856  20% /usr/apps
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
>>                    55567516032 19180819132 33609246924  37% /u
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
>>                    3385032528 124240920 3111768192   4% /usr/local
>> abem5:/var/spool/torque/server_logs
>>                    961428816 201451344 711139632  23% /var/spool/torque/server_logs
>> abem5:/var/spool/torque/server_priv/accounting
>>                     73575600  56692832  13084960  82% /var/spool/torque/server_priv/accounting
>> pop:/var/forward      70557056  65120056   1852904  98% /var/forward
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
>>                    276891315456 155142158488 111900655348  59% /cfs/scratch
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
>>                    92298352896 67398023772 23493778892  75% /cfs/projects
>> STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
>> TEST_TYPES=standard
>> Running source repository checkout with output saved in
>>  /u/ac/hdftest/snapshots-opa/log/REPO_LOG_0817Tue
>> Checking MANIFEST file ...
>> cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0817Tue.21063: No such file or directory
>> rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0817Tue.21063': No such file or directory
>> *** launching tests from honest3 ***
>> TESTHOST is honest1
>>   Fork off timekeeper 30
>> Testing honest1
>> ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
>> Using configname option for -configname
>> opa
>> 01:05:04 up 19 days, 10:13, 30 users,  load average: 0.22, 0.20, 0.41
>> abem2:/var/lib/perceus/
>>                     74763440  49226688  21738944  70% /var/lib/perceus
>> /dev/sda2             63013156    360476  62019880   1% /tmp
>>                    55567516032 19181750692 33608305220  37% /u
>>                    3385032528 124240988 3111768244   4% /usr/local
>>                    961428816 201451440 711139536  23% /var/spool/torque/server_logs
>>                     73575600  56693104  13084688  82% /var/spool/torque/server_priv/accounting
>> pop:/var/forward      70557056  65120128   1852832  98% /var/forward
>>                    276891315456 155142436308 111900519492  59% /cfs/scratch
>> TEST_TYPES=standard
>> Running standard
>> *** starting standard tests in honest1 ***
>> Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
>> SRCDIRNAME is honest1
>> Running snapshot with output saved in
>> SNAPCMD is srcdir test clean
>> SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
>> *** finished standard tests for honest1 ***
>> Total time = 0m 3s
>> *** finished tests in honest1 ***
>> ****SYSTEM ERROR honest1: Abnormal exit from runtest ****
>> 	Tue Aug 17 01:05:48 CDT 2010
>> 	****SYSTEM ERROR honest1: runtest command failed ****
>> *** finished tests in honest3 ***
>> opa-nightly-tests mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
