[opa-nightly-tests] honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
Dave Goodell goodell at mcs.anl.gov
Tue Aug 17 07:59:03 CDT 2010
Pavan updated OPA yesterday to use libtool in the build system.  The source trees need an "autoreconf -vif" run.
-Dave
On Aug 17, 2010, at 1:05 AM CDT, HDFTEST Community User wrote:
> *** OPA Tests on 0817Tue ***
>   Tests Summary
> ****FAILED honest1: standard****
>   Tests Time Summary
> honest1: Ran 1(0/1/0) tests, Grand total test time =  0m 4s
> honest3: Ran 1(0/0/0) hosts, Grand total test time =  0m 58s
>   Timekeeper log
> Timekeeper started at Tue Aug 17 01:04:59 CDT 2010
> Timekeeper sleeping for 1800 seconds
>   Tests Failures
> Dumping logfile of honest1: standard
> Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0817Tue_0105
> PBS_DEFAULT=abem5.ncsa.uiuc.edu
> PKG_CONFIG_PATH=/usr/local/lib64/pkgconfig
> PLATFORM=linux-rhel4-x86_64
> PWD=/u/ac/hdftest/snapshots-opa
> SHELL=/bin/tcsh
> SHLVL=3
> SOFTENV_ALIASES=/usr/local/softenv-1.6.2-r3/etc/softenv-aliases.csh
> SOFTENV_LOAD=/usr/local/softenv-1.6.2-r3/etc/softenv-load.csh
> SSH_CLIENT=141.142.31.132 42984 22
> SSH_CONNECTION=141.142.31.132 42984 141.142.31.130 22
> TG_APPS_PREFIX=/usr/local
> TOTALVIEW=/usr/apps/tools/toolworks/totalview/bin/totalview
> TOTALVIEW_HOME=/usr/apps/tools/toolworks/totalview
> TVDSVRLAUNCHCMD=ssh
> USER=hdftest
> VENDOR=unknown
> VMI_SPECFILE=/opt/vmi-2.2.0-1-gcc/specfiles/openfabric.xml
> WHATAMI=linux-rhel4-x86_64
> _=/usr/bin/printenv
> ===Done Dumping environment variables after option parsing ===
> Configure command is configure  --prefix=${PWD}/opainstall
> CURRENT is /u/ac/hdftest/snapshots-opa/current
> ===== Run Tests: Tue Aug 17 01:05:15 CDT 2010 =====
> Check to see if TESTDIR /u/ac/hdftest/snapshots-opa/TestDir/honest1 exists
> /bin/sh ./config.status --recheck
> running CONFIG_SHELL=/bin/sh /bin/sh /u/ac/hdftest/snapshots-opa/current/configure --prefix=${PWD}/opainstall --no-create --no-recursion
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for a thread-safe mkdir -p... /bin/mkdir -p
> checking for gawk... gawk
> checking whether gmake sets $(MAKE)... yes
> /u/ac/hdftest/snapshots-opa/current/configure: line 2342: syntax error near unexpected token `2.2.6'
> /u/ac/hdftest/snapshots-opa/current/configure: line 2342: `LT_PREREQ(2.2.6)'
> gmake: *** [config.status] Error 2
> TESTDIR is /u/ac/hdftest/snapshots-opa/TestDir/honest1
> snapshot is yes
> ===== configure: Tue Aug 17 01:05:16 CDT 2010 =====
> Failed running configure
> ===== Exit bin/snapshot with status=2: Tue Aug 17 01:05:18 CDT 2010 =====
> Dumping done
> Runtest did not exit normally.
>   Watchers List
> OPA Daily test features/platforms watchers and procedure
> Procedure:
> The watcher will investigate and report the cause of failure by 11am.
> The developer who checked in the error code may report so by then too.
> The watcher or the developer should get the failure fixed and report it
> by 3pm.
> Watcher for OPA:	 	Neil
> updated: 2009/05/05
>   Tests Details
> Testing all hosts.
> opa
> 01:04:40 up 19 days, 10:12, 28 users,  load average: 0.06, 0.10, 0.40
> Filesystem           1K-blocks      Used Available Use% Mounted on
> none                   8218016         0   8218016   0% /dev/shm
> abem4:/var/lib/perceus/
>                      74763440  42299920  28665712  60% /var/lib/perceus
> 10.1.69.1:/usr/src   138916864  99971520  31888736  76% /usr/src
> /dev/sda3             29463920     47088  29119552   1% /tmp
> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
>                     3385032528 620743632 2592338856  20% /usr/apps
> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
>                     55567516032 19180819132 33609246924  37% /u
> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
>                     3385032528 124240920 3111768192   4% /usr/local
> abem5:/var/spool/torque/server_logs
>                     961428816 201451344 711139632  23% /var/spool/torque/server_logs
> abem5:/var/spool/torque/server_priv/accounting
>                      73575600  56692832  13084960  82% /var/spool/torque/server_priv/accounting
> pop:/var/forward      70557056  65120056   1852904  98% /var/forward
> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
>                     276891315456 155142158488 111900655348  59% /cfs/scratch
> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
>                     92298352896 67398023772 23493778892  75% /cfs/projects
> STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
> TEST_TYPES=standard
> Running source repository checkout with output saved in
>   /u/ac/hdftest/snapshots-opa/log/REPO_LOG_0817Tue
> Checking MANIFEST file ...
> cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0817Tue.21063: No such file or directory
> rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0817Tue.21063': No such file or directory
> *** launching tests from honest3 ***
> TESTHOST is honest1
>    Fork off timekeeper 30
> Testing honest1
> ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
> Using configname option for -configname
> opa
> 01:05:04 up 19 days, 10:13, 30 users,  load average: 0.22, 0.20, 0.41
> abem2:/var/lib/perceus/
>                      74763440  49226688  21738944  70% /var/lib/perceus
> /dev/sda2             63013156    360476  62019880   1% /tmp
>                     55567516032 19181750692 33608305220  37% /u
>                     3385032528 124240988 3111768244   4% /usr/local
>                     961428816 201451440 711139536  23% /var/spool/torque/server_logs
>                      73575600  56693104  13084688  82% /var/spool/torque/server_priv/accounting
> pop:/var/forward      70557056  65120128   1852832  98% /var/forward
>                     276891315456 155142436308 111900519492  59% /cfs/scratch
> TEST_TYPES=standard
> Running standard
> *** starting standard tests in honest1 ***
> Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
> SRCDIRNAME is honest1
> Running snapshot with output saved in
> SNAPCMD is srcdir test clean
> SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
> *** finished standard tests for honest1 ***
> Total time = 0m 3s
> *** finished tests in honest1 ***
> ****SYSTEM ERROR honest1: Abnormal exit from runtest ****
> 	Tue Aug 17 01:05:48 CDT 2010
> 	****SYSTEM ERROR honest1: runtest command failed ****
> *** finished tests in honest3 ***
> opa-nightly-tests mailing list
> opa-nightly-tests at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
