[opa-nightly-tests] honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
HDFTEST Community User
hdftest at ncsa.uiuc.edu
Tue Aug 17 01:05:48 CDT 2010
*** OPA Tests on 0817Tue ***
Tests Summary
****FAILED honest1: standard****
Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time = 0m 4s
honest3: Ran 1(0/0/0) hosts, Grand total test time = 0m 58s
Timekeeper log
Timekeeper started at Tue Aug 17 01:04:59 CDT 2010
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of honest1: standard
Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0817Tue_0105
PBS_DEFAULT=abem5.ncsa.uiuc.edu
PKG_CONFIG_PATH=/usr/local/lib64/pkgconfig
PLATFORM=linux-rhel4-x86_64
PWD=/u/ac/hdftest/snapshots-opa
SHELL=/bin/tcsh
SHLVL=3
SOFTENV_ALIASES=/usr/local/softenv-1.6.2-r3/etc/softenv-aliases.csh
SOFTENV_LOAD=/usr/local/softenv-1.6.2-r3/etc/softenv-load.csh
SSH_CLIENT=141.142.31.132 42984 22
SSH_CONNECTION=141.142.31.132 42984 141.142.31.130 22
TG_APPS_PREFIX=/usr/local
TOTALVIEW=/usr/apps/tools/toolworks/totalview/bin/totalview
TOTALVIEW_HOME=/usr/apps/tools/toolworks/totalview
TVDSVRLAUNCHCMD=ssh
USER=hdftest
VENDOR=unknown
VMI_SPECFILE=/opt/vmi-2.2.0-1-gcc/specfiles/openfabric.xml
WHATAMI=linux-rhel4-x86_64
_=/usr/bin/printenv
===Done Dumping environment variables after option parsing ===
Configure command is configure --prefix=${PWD}/opainstall
CURRENT is /u/ac/hdftest/snapshots-opa/current
===== Run Tests: Tue Aug 17 01:05:15 CDT 2010 =====
Check to see if TESTDIR /u/ac/hdftest/snapshots-opa/TestDir/honest1 exists
/bin/sh ./config.status --recheck
running CONFIG_SHELL=/bin/sh /bin/sh /u/ac/hdftest/snapshots-opa/current/configure --prefix=${PWD}/opainstall --no-create --no-recursion
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether gmake sets $(MAKE)... yes
/u/ac/hdftest/snapshots-opa/current/configure: line 2342: syntax error near unexpected token `2.2.6'
/u/ac/hdftest/snapshots-opa/current/configure: line 2342: `LT_PREREQ(2.2.6)'
gmake: *** [config.status] Error 2
TESTDIR is /u/ac/hdftest/snapshots-opa/TestDir/honest1
snapshot is yes
===== configure: Tue Aug 17 01:05:16 CDT 2010 =====
Failed running configure
===== Exit bin/snapshot with status=2: Tue Aug 17 01:05:18 CDT 2010 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
01:04:40 up 19 days, 10:12, 28 users, load average: 0.06, 0.10, 0.40
Filesystem 1K-blocks Used Available Use% Mounted on
none 8218016 0 8218016 0% /dev/shm
abem4:/var/lib/perceus/
74763440 42299920 28665712 60% /var/lib/perceus
10.1.69.1:/usr/src 138916864 99971520 31888736 76% /usr/src
/dev/sda3 29463920 47088 29119552 1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
3385032528 620743632 2592338856 20% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
55567516032 19180819132 33609246924 37% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
3385032528 124240920 3111768192 4% /usr/local
abem5:/var/spool/torque/server_logs
961428816 201451344 711139632 23% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
73575600 56692832 13084960 82% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 65120056 1852904 98% /var/forward
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
276891315456 155142158488 111900655348 59% /cfs/scratch
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
92298352896 67398023772 23493778892 75% /cfs/projects
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/u/ac/hdftest/snapshots-opa/log/REPO_LOG_0817Tue
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0817Tue.21063: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0817Tue.21063': No such file or directory
*** launching tests from honest3 ***
TESTHOST is honest1
Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
Using configname option for -configname
opa
01:05:04 up 19 days, 10:13, 30 users, load average: 0.22, 0.20, 0.41
abem2:/var/lib/perceus/
74763440 49226688 21738944 70% /var/lib/perceus
/dev/sda2 63013156 360476 62019880 1% /tmp
55567516032 19181750692 33608305220 37% /u
3385032528 124240988 3111768244 4% /usr/local
961428816 201451440 711139536 23% /var/spool/torque/server_logs
73575600 56693104 13084688 82% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 65120128 1852832 98% /var/forward
276891315456 155142436308 111900519492 59% /cfs/scratch
TEST_TYPES=standard
Running standard
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 0m 3s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
More information about the opa-nightly-tests
