[opa-nightly-tests] co-login OPA_Daily_Tests_0817Tue_FAILED!!!
HDF Tester hdftest at ncsa.uiuc.edu
Tue Aug 17 01:01:21 CDT 2010
*** OPA Tests on 0817Tue ***
   Tests Summary
****FAILED co-login: standard****
   Tests Time Summary
co-login: Ran 1(0/1/0) tests, Grand total test time =  0m 10s
   Timekeeper log
   Tests Failures
Dumping logfile of co-login: standard
Last 50 lines of /u/ac/hdftest/snapshots-opa/log/co-login_0817Tue_0101
TG_APPS_PREFIX=/usr/apps
TG_CLUSTER_CXFS=/scratch/users/hdftest
TG_CLUSTER_GPFS=NULL
TG_CLUSTER_HOME=/u/ac/hdftest
TG_CLUSTER_LUSTRE=NULL
TG_CLUSTER_PFS=/scratch/users/hdftest
TG_CLUSTER_PVFS=NULL
TG_CLUSTER_SCRATCH=/scratch/users/hdftest
TG_COMMUNITY=NULL
TG_EXAMPLES=/usr/local/examples
TG_NODE_SCRATCH=NULL
USER=hdftest
_=/usr/bin/printenv
VENDOR=suse
WHATAMI=linux-sles10-ia64
WINDOWMANAGER=/usr/bin/X11/gnome
XCURSOR_THEME=Industrial
XDG_CONFIG_DIRS=/usr/local/etc/xdg/:/etc/xdg/:/etc/opt/gnome/xdg/:/etc/opt/gnome/xdg/
XDG_DATA_DIRS=/usr/local/share/:/usr/share/:/etc/opt/kde3/share/:/opt/kde3/share/:/opt/gnome/share/:/opt/gnome/share/
XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB
XNLSPATH=/usr/X11R6/lib/X11/nls
===Done Dumping environment variables after option parsing ===
Configure command is configure  --prefix=${PWD}/opainstall
CURRENT is /u/ac/hdftest/snapshots-opa/current
===== Run Tests: Tue Aug 17 01:01:15 CDT 2010 =====
Check to see if TESTDIR /u/ac/hdftest/snapshots-opa/TestDir/co-login exists
/bin/sh ./config.status --recheck
running CONFIG_SHELL=/bin/sh /bin/sh /u/ac/hdftest/snapshots-opa/current/configure --prefix=${PWD}/opainstall --no-create --no-recursion
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether gmake -j 8 sets $(MAKE)... yes
/u/ac/hdftest/snapshots-opa/current/configure: line 2342: syntax error near unexpected token `2.2.6'
/u/ac/hdftest/snapshots-opa/current/configure: line 2342: `LT_PREREQ(2.2.6)'
gmake: *** [config.status] Error 2
TESTDIR is /u/ac/hdftest/snapshots-opa/TestDir/co-login
snapshot is yes
===== configure: Tue Aug 17 01:01:18 CDT 2010 =====
Failed running configure
===== Exit bin/snapshot with status=2: Tue Aug 17 01:01:20 CDT 2010 =====
Dumping done
   Watchers List
More information about the opa-nightly-tests mailing list
