[opa-nightly-tests] jam OPA_Daily_Tests_0817Tue_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Tue Aug 17 00:12:12 CDT 2010
*** OPA Tests on 0817Tue ***
Tests Summary
****FAILED duty: standard****
****FAILED jam: standard****
****FAILED liberty: standard****
****FAILED linew: standard****
Tests Time Summary
jam: Ran 1(0/1/0) tests, Grand total test time = 0m 3s
duty: Ran 1(0/1/0) tests, Grand total test time = 0m 4s
liberty: Ran 1(0/1/0) tests, Grand total test time = 0m 4s
linew: Ran 1(0/1/0) tests, Grand total test time = 0m 56s
jam: Ran 4(0/0/0) hosts, Grand total test time = 1m 51s
Timekeeper log
Timekeeper started at Tue Aug 17 00:10:28 CDT 2010
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of jam: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/jam_0817Tue_0010
MAKE=gmake -j 8
MANPATH=/usr/local/man:/usr/share/man:/usr/kerberos/man:/usr/X11R6/man
OSTYPE=linux
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/acheng/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/usr/X11R6/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
SSH_CLIENT=72.36.68.169 35108 22
SSH_CONNECTION=72.36.68.169 35108 72.36.68.169 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
USER=hdftest
_=/usr/bin/printenv
VENDOR=intel
===Done Dumping environment variables after option parsing ===
Configure command is configure --prefix=${PWD}/opainstall
CURRENT is /home/hdftest/snapshots-opa/current
===== Run Tests: Tue Aug 17 00:10:47 CDT 2010 =====
Check to see if TESTDIR /home/hdftest/snapshots-opa/TestDir/jam exists
/bin/sh ./config.status --recheck
cd /home/hdftest/snapshots-opa/current && /bin/sh /home/hdftest/snapshots-opa/current/confdb/missing --run automake-1.10 --foreign
/home/hdftest/snapshots-opa/current/confdb/missing: line 54: automake-1.10: command not found
WARNING: `automake-1.10' is missing on your system. You should only need it if
you modified `Makefile.am', `acinclude.m4' or `configure.in'.
You might want to install the `Automake' and `Perl' packages.
Grab them from any GNU archive site.
running CONFIG_SHELL=/bin/sh /bin/sh /home/hdftest/snapshots-opa/current/configure --prefix=${PWD}/opainstall --no-create --no-recursion
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether gmake -j 8 sets $(MAKE)... yes
/home/hdftest/snapshots-opa/current/configure: line 2342: syntax error near unexpected token `2.2.6'
/home/hdftest/snapshots-opa/current/configure: line 2342: `LT_PREREQ(2.2.6)'
gmake: *** [config.status] Error 2
TESTDIR is /home/hdftest/snapshots-opa/TestDir/jam
snapshot is yes
===== configure: Tue Aug 17 00:10:48 CDT 2010 =====
Failed running configure
===== Exit bin/snapshot with status=2: Tue Aug 17 00:10:49 CDT 2010 =====
Dumping done
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0817Tue_0010
KRB5CCNAME=FILE:/tmp/krb5cc_DOkUbt
LOGNAME=hdftest
MACHTYPE=i386
MAIL=/var/mail/hdftest
MAKE=gmake -j 4
OLDPWD=/mnt/scr1/SnapTest/snapshots-opa
OSTYPE=FreeBSD
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/acheng/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/games:/usr/local/sbin:/usr/local/bin:/usr/X11R6/bin:/home/hdftest/bin:/mnt/hdf/ec2-api-tools/bin
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/csh
SHLVL=1
SSH_CLIENT=72.36.68.169 60573 22
SSH_CONNECTION=72.36.68.169 60573 72.36.68.164 22
TERM=su
USER=hdftest
VENDOR=intel
===== Run Tests: Tue Aug 17 00:10:51 CDT 2010 =====
Check to see if TESTDIR /home/hdftest/snapshots-opa/TestDir/duty exists
checking for a thread-safe mkdir -p... /home/hdftest/snapshots-opa/current/confdb/install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... nawk
checking whether gmake -j 4 sets $(MAKE)... yes
./configure.lineno: 2342: Syntax error: word unexpected (expecting ")")
TESTDIR is /home/hdftest/snapshots-opa/TestDir/duty
snapshot is yes
===== configure: Tue Aug 17 00:10:53 CDT 2010 =====
===== Exit bin/snapshot with status=0: Tue Aug 17 00:10:55 CDT 2010 =====
Dumping done
Dumping logfile of liberty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0817Tue_0010
KRB5CCNAME=FILE:/tmp/krb5cc_1oCxvg
LOGNAME=hdftest
MACHTYPE=unknown
MAKE=gmake -j 4
OSTYPE=FreeBSD
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/csh
SHLVL=1
SSH_CLIENT=72.36.68.169 42796 22
SSH_CONNECTION=72.36.68.169 42796 72.36.68.165 22
TERM=su
USER=hdftest
VENDOR=unknown
===== Run Tests: Tue Aug 17 00:10:52 CDT 2010 =====
Check to see if TESTDIR /home/hdftest/snapshots-opa/TestDir/liberty exists
TESTDIR is /home/hdftest/snapshots-opa/TestDir/liberty
snapshot is yes
===== configure: Tue Aug 17 00:10:54 CDT 2010 =====
===== Exit bin/snapshot with status=0: Tue Aug 17 00:10:56 CDT 2010 =====
Dumping done
Dumping logfile of linew: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/linew_0817Tue_0010
HOME=/home/hdftest
HOST=linew
HOSTTYPE=sun4
JAVA_HOME=/usr/java/jdk-106/jdk
KRB5CCNAME=FILE:/tmp/krb5cc_27429_XXXXl_aise
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail//hdftest
MAKE=gmake -j 2
OSTYPE=solaris
PATH=/opt/SUNWspro/bin:/home/hdftest/bin:/usr/hdf/bin:/home/acheng/bin:/usr/hdf/bin:/opt/SUNWspro/bin:/opt/csw/bin:/opt/csw/gcc3/bin:/usr/ccs/bin:/usr/sfw/bin:/usr/local/bin:/usr/bin:/usr/ucb:/usr/openwin/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/home/hdftest/snapshots-opa
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=1
SSH_CLIENT=72.36.68.169 38952 22
SSH_CONNECTION=72.36.68.169 38952 72.36.68.173 22
TZ=US/Central
USER=hdftest
VENDOR=sun
===== Run Tests: Tue Aug 17 00:11:00 CDT 2010 =====
Check to see if TESTDIR /home/hdftest/snapshots-opa/TestDir/linew exists
/bin/bash ./config.status --recheck
running CONFIG_SHELL=/bin/bash /bin/bash /home/hdftest/snapshots-opa/current/configure --prefix=${PWD}/opainstall --no-create --no-recursion
checking for a BSD-compatible install... /home/hdftest/snapshots-opa/current/confdb/install-sh -c
checking whether gmake -j 2 sets $(MAKE)... yes
TESTDIR is /home/hdftest/snapshots-opa/TestDir/linew
snapshot is yes
===== configure: Tue Aug 17 00:11:20 CDT 2010 =====
===== Exit bin/snapshot with status=0: Tue Aug 17 00:11:39 CDT 2010 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
00:10:11 up 56 days, 13:19, 34 users, load average: 1.10, 1.12, 0.89
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 4027392 26072800 14% /
/dev/sda1 101086 22704 73163 24% /boot
/dev/sda2 31738420 228656 29871536 1% /tmp
/dev/sda6 31738392 4441092 25659076 15% /var
/dev/sda7 31738392 25627644 4472524 86% /usr
/dev/sda8 124991068 9040684 109498684 8% /var/tmp
/dev/mapper/VolGroup00-home
198351840 10543264 177570216 6% /home
/dev/sde1 565688764 67950244 468539584 13% /scr
/dev/sdc1 961432072 624205308 288388764 69% /mnt/scr1
/dev/sdd1 961432072 643342776 269251296 71% /mnt/hdf
tmpfs 8313860 0 8313860 0% /dev/shm
gumund:/data/web 480719072 247460704 208839168 55% /mnt/web
gumund:/data/ftp/pub 480719072 247460704 208839168 55% /mnt/ftp
pegdub:/mnt/rw-src 288451232 178794496 95004256 66% /mnt/ro-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0817Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0817Tue.10518: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0817Tue.10518': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
duty
liberty
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
Using configname option for -configname
opa
12:10am up 5 day(s), 6:40, 3 users, load average: 1.19, 0.97, 0.53
/ (/dev/dsk/c1t0d0s0 ):80618694 blocks 8321573 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483603 files
/proc (proc ): 0 blocks 29929 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20977472 blocks 1182444 files
/system/object (objfs ): 0 blocks 2147483486 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):80618694 blocks 8321573 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):80618694 blocks 8321573 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20977472 blocks 1182444 files
/var/run (swap ):20977472 blocks 1182444 files
/scr (/dev/dsk/c1t1d0s0 ):254603484 blocks 18219554 files
/home (jam:/home ):375617152 blocks 50976686 files
/mnt/hdf (jam:/mnt/hdf ):636178592 blocks 115744178 files
/mnt/scr1 (jam:/mnt/scr1 ):674453504 blocks 118316417 files
/mnt/web (gumund:/mnt/web ):466516688 blocks 60893328 files
/mnt/ftp (gumund:/mnt/ftp ):466516688 blocks 60893328 files
TEST_TYPES=standard
Running standard
Tue Aug 17 00:10:57 CDT 2010
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_142900-15 sun4u sparc SUNW,A70
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
SRCDIRNAME is linew
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname linew
Tue Aug 17 00:11:40 CDT 2010
*** finished standard tests for linew ***
Total time = 0m 44s
*** finished tests in linew ***
Tue Aug 17 00:11:41 CDT 2010
****SYSTEM ERROR linew: Abnormal exit from runtest ****
****SYSTEM ERROR linew: runtest command failed ****
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
opa
00:10:36 up 56 days, 13:19, 34 users, load average: 1.13, 1.12, 0.90
/dev/sda2 31738420 228700 29871492 1% /tmp
/dev/sda6 31738392 4441096 25659072 15% /var
/dev/sdc1 961432072 624205328 288388744 69% /mnt/scr1
TEST_TYPES=standard
Running standard
Tue Aug 17 00:10:46 CDT 2010
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-164.11.1.el5PAE #1 SMP Wed Jan 20 08:16:13 EST 2010 i686 i686 i386 GNU/Linux
SRCDIRNAME is jam
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname jam
*** finished standard tests for jam ***
Total time = 0m 3s
*** finished tests in jam ***
****SYSTEM ERROR jam: Abnormal exit from runtest ****
****SYSTEM ERROR jam: runtest command failed ****
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
opa
12:10AM up 61 days, 2:07, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60990 406030 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 121324224 52034152 70% /data
/dev/aacd0s1g 32494668 23209566 6685530 78% /local_home
/dev/aacd0s1f 12186190 4124148 7087148 37% /usr
/dev/aacd0s1d 507630 48508 418512 10% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 10543264 177570216 6% /home
jam:/mnt/hdf 961432072 643342776 269251296 70% /mnt/hdf
jam:/mnt/scr1 961432072 624205336 288388736 68% /mnt/scr1
gumund:/data/web 480719056 247460712 208839144 54% /mnt/web
gumund:/data/ftp 480719056 247460712 208839144 54% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 122 116444 0% /tmp
TEST_TYPES=standard
Running standard
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
SRCDIRNAME is duty
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname duty
*** finished standard tests for duty ***
Total time = 0m 4s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname liberty
opa
12:10AM up 61 days, 2:09, 4 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a 507630 86912 380108 19% /
/dev/aacd0s1g 47047830 30687244 12596760 71% /local_home
/dev/aacd0s1f 12186190 7418612 3792684 66% /usr
/dev/aacd0s1d 1012974 103870 828068 11% /var
/dev/aacd0s1e 507630 62724 404296 13% /var/tmp
jam:/mnt/scr1 961432072 624205340 288388732 68% /mnt/scr1
/dev/md0 126702 126 116440 0% /tmp
TEST_TYPES=standard
Running standard
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
SRCDIRNAME is liberty
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname liberty
*** finished standard tests for liberty ***
Total time = 0m 4s
*** finished tests in liberty ***
****SYSTEM ERROR liberty: Abnormal exit from runtest ****
****SYSTEM ERROR liberty: runtest command failed ****
More information about the opa-nightly-tests
