[opa-nightly-tests] honest4 OPA_Daily_Tests_1210Thu_FAILED!!!
Dave Goodell goodell at mcs.anl.gov
Thu Dec 10 09:24:49 CST 2009
The failure lines are where the threads are created.  Did something
change on this system that prevents 100 threads from being created?
If so, why didn't the configure check catch it first?
-Dave
On Dec 10, 2009, at 12:37 AM, HDFTEST Community User wrote:
> *** OPA Tests on 1210Thu ***
>   Tests Summary
> ****FAILED honest1: standard****
>   Tests Time Summary
> honest1: Ran 1(0/1/0) tests, Grand total test time =  1m 9s
> honest4: Ran 1(0/0/0) hosts, Grand total test time =  1m 59s
>   Timekeeper log
> Timekeeper started at Thu Dec 10 00:35:22 CST 2009
> Timekeeper sleeping for 1800 seconds
>   Tests Failures
> Dumping logfile of honest1: standard
> Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_1210Thu_0035
> Testing memory barrier
> sanity                                          PASSED
> Testing memory barriers with linear array with 2
> threads               PASSED
> Testing memory barriers with local variables with 2
> threads            PASSED
> Testing memory barriers with scattered array with 2
> threads            PASSED
> Testing memory barriers with linear array with 4
> threads               PASSED
> Testing memory barriers with local variables with 4
> threads            PASSED
> Testing memory barriers with scattered array with 4
> threads            PASSED
> Testing memory barriers with linear array with 10
> threads              PASSED
> Testing memory barriers with local variables with 10
> threads           PASSED
> Testing memory barriers with scattered array with 10
> threads           PASSED
> Testing memory barriers with linear array with 100
> threads            *FAILED*
>        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:
> 304 in test_barriers_linear_array()...
> Testing memory barriers with local variables with 100
> threads         *FAILED*
> 558 in test_barriers_variables()...
> Testing memory barriers with scattered array with 100
> threads         *FAILED*
> 660 in test_barriers_scattered_array()...
> ***** 3 BARRIERS TESTS FAILED! *****
> FAIL: test_barriers
> 1 of 3 tests failed
> Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
> make[2]: *** [check-TESTS] Error 1
> make[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/
> honest1/test'
> make[1]: *** [check-am] Error 2
> make[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/
> honest1/test'
> make: *** [check-recursive] Error 1
> Failed running make check
> ===== Exit bin/snapshot with status=2: Thu Dec 10 00:36:46 CST 2009
> Dumping done
> Runtest did not exit normally.
>   Watchers List
> OPA Daily test features/platforms watchers and procedure
> Procedure:
> The watcher will investigate and report the cause of failure by 11am.
> The developer who checked in the error code may report so by then too.
> The watcher or the developer should get the failure fixed and report
> it
> by 3pm.
> Watcher for OPA:	 	Neil
> updated: 2009/05/05
>   Tests Details
> Testing all hosts.
> opa
> 00:35:06 up 7 days, 23:31, 43 users,  load average: 1.26, 1.87, 2.53
> Filesystem           1K-blocks      Used Available Use% Mounted on
> none                   8218016         0   8218016   0% /dev/shm
> abem1:/var/lib/perceus/
>                     138916864 110819312  21040960  85% /var/lib/
> perceus
> 10.1.69.1:/usr/src   138916864 110819296  21040960  85% /usr/src
> /dev/sda2             63013156     53512  62326844   1% /tmp
> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
>                     3385032528 534370892 2678711596  17% /usr/apps
> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
>                     80761058784 50211631052 29728898592  63% /cfs/
> projects
> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
>                     55567516032 15251816060 37538061428  29% /u
> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
>                     3385032528 114971212 3121037876   4% /usr/local
> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
>                     242279901024 86818541480 147369164840  38% /cfs/
> scratch
> abem5:/var/spool/torque/server_logs
>                     961428816 110628016 801962960  13% /var/spool/
> torque/server_logs
> abem5:/var/spool/torque/server_priv/accounting
>                      73575600  52562288  17215504  76% /var/spool/
> pop:/var/forward      70557056  58482120   8490840  88% /var/forward
> mds03.uits.indiana.edu:/mds-wan/client
>                     363327960768 342329842612 18737016948  95% /WAN/IU
> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
> TEST_TYPES=standard
> Running CVS checkout with output saved in
>   /u/ac/hdftest/snapshots-opa/log/CVS_LOG_1210Thu
> Checking MANIFEST file ...
> cat: /u/ac/hdftest/snapshots-opa/log/#runtest.1210Thu.21503: No such
> file or directory
> rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.1210Thu.
> 21503': No such file or directory
> *** launching tests from honest4 ***
> TESTHOST is honest1
>    Fork off timekeeper 30
> Testing honest1
> ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/
> snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
> Using configname option for -configname
> opa
> 00:35:27 up 7 days, 23:32, 45 users,  load average: 1.88, 1.58, 1.57
> abem2:/var/lib/perceus/
>                      74763440  62283744   8681888  88% /var/lib/
> perceus
> /dev/sda2             63013156     67132  62313224   1% /tmp
>                     80761058784 50210946452 29729523336  63% /cfs/
> projects
>                     55567516032 15251970284 37537891472  29% /u
>                     3385032528 114971216 3121037868   4% /usr/local
>                     242279901024 86818162724 147369591608  38% /cfs/
> scratch
>                     961428816 110628080 801962896  13% /var/spool/
> torque/server_logs
>                      73575600  52562368  17215424  76% /var/spool/
> pop:/var/forward      70557056  58482176   8490784  88% /var/forward
>                     363327960768 342330424868 18736395728  95% /WAN/IU
> TEST_TYPES=standard
> Running standard
> Thu Dec 10 00:35:37 CST 2009
> *** starting standard tests in honest1 ***
> Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.
> 1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64
> x86_64 GNU/Linux
> SRCDIRNAME is honest1
> Running snapshot with output saved in
> SNAPCMD is srcdir test clean
> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/
> local/include,/usr/local/lib srcdirname honest1
> *** finished standard tests for honest1 ***
> Total time = 1m 9s
> *** finished tests in honest1 ***
> ****SYSTEM ERROR honest1: Abnormal exit from runtest ****
> 	Thu Dec 10 00:37:16 CST 2009
> 	****SYSTEM ERROR honest1: runtest command failed ****
> *** finished tests in honest4 ***
> opa-nightly-tests mailing list
> opa-nightly-tests at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
