[opa-nightly-tests] honest4 OPA_Daily_Tests_1210Thu_FAILED!!!
HDFTEST Community User
hdftest at ncsa.uiuc.edu
Thu Dec 10 00:37:16 CST 2009
*** OPA Tests on 1210Thu ***
Tests Summary
****FAILED honest1: standard****
Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time = 1m 9s
honest4: Ran 1(0/0/0) hosts, Grand total test time = 1m 59s
Timekeeper log
Timekeeper started at Thu Dec 10 00:35:22 CST 2009
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_1210Thu_0035
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
1 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
make[2]: *** [check-TESTS] Error 1
make[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
make: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Thu Dec 10 00:36:46 CST 2009 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
00:35:06 up 7 days, 23:31, 43 users, load average: 1.26, 1.87, 2.53
Filesystem 1K-blocks Used Available Use% Mounted on
none 8218016 0 8218016 0% /dev/shm
abem1:/var/lib/perceus/
138916864 110819312 21040960 85% /var/lib/perceus
10.1.69.1:/usr/src 138916864 110819296 21040960 85% /usr/src
/dev/sda2 63013156 53512 62326844 1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
3385032528 534370892 2678711596 17% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
80761058784 50211631052 29728898592 63% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
55567516032 15251816060 37538061428 29% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
3385032528 114971212 3121037876 4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
242279901024 86818541480 147369164840 38% /cfs/scratch
abem5:/var/spool/torque/server_logs
961428816 110628016 801962960 13% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
73575600 52562288 17215504 76% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 58482120 8490840 88% /var/forward
mds03.uits.indiana.edu:/mds-wan/client
363327960768 342329842612 18737016948 95% /WAN/IU
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
/u/ac/hdftest/snapshots-opa/log/CVS_LOG_1210Thu
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.1210Thu.21503: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.1210Thu.21503': No such file or directory
*** launching tests from honest4 ***
TESTHOST is honest1
Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
Using configname option for -configname
opa
00:35:27 up 7 days, 23:32, 45 users, load average: 1.88, 1.58, 1.57
abem2:/var/lib/perceus/
74763440 62283744 8681888 88% /var/lib/perceus
/dev/sda2 63013156 67132 62313224 1% /tmp
80761058784 50210946452 29729523336 63% /cfs/projects
55567516032 15251970284 37537891472 29% /u
3385032528 114971216 3121037868 4% /usr/local
242279901024 86818162724 147369591608 38% /cfs/scratch
961428816 110628080 801962896 13% /var/spool/torque/server_logs
73575600 52562368 17215424 76% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 58482176 8490784 88% /var/forward
363327960768 342330424868 18736395728 95% /WAN/IU
TEST_TYPES=standard
Running standard
Thu Dec 10 00:35:37 CST 2009
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 9s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest4 ***
More information about the opa-nightly-tests
