[opa-nightly-tests] honest4 OPA_Daily_Tests_1210Thu_FAILED!!!
Neil Fortner nfortne2 at hdfgroup.org
Thu Dec 10 10:16:48 CST 2009
Dave,
This looks like an issue with parallel make.  I will ask Larry about
it.  Note that the primitives tests with 100 threads passed.
-Neil
On 12/10/2009 09:24 AM, Dave Goodell wrote:
> The failure lines are where the threads are created.  Did something
> change on this system that prevents 100 threads from being created?
> If so, why didn't the configure check catch it first?
> -Dave
> On Dec 10, 2009, at 12:37 AM, HDFTEST Community User wrote:
>> *** OPA Tests on 1210Thu ***
>>   Tests Summary
>> ****FAILED honest1: standard****
>>   Tests Time Summary
>> honest1: Ran 1(0/1/0) tests, Grand total test time =  1m 9s
>> honest4: Ran 1(0/0/0) hosts, Grand total test time =  1m 59s
>>   Timekeeper log
>> Timekeeper started at Thu Dec 10 00:35:22 CST 2009
>> Timekeeper sleeping for 1800 seconds
>>   Tests Failures
>> Dumping logfile of honest1: standard
>> Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_1210Thu_0035
>> Testing memory barrier
>> sanity                                          PASSED
>> Testing memory barriers with linear array with 2
>> threads               PASSED
>> Testing memory barriers with local variables with 2
>> threads            PASSED
>> Testing memory barriers with scattered array with 2
>> threads            PASSED
>> Testing memory barriers with linear array with 4
>> threads               PASSED
>> Testing memory barriers with local variables with 4
>> threads            PASSED
>> Testing memory barriers with scattered array with 4
>> threads            PASSED
>> Testing memory barriers with linear array with 10
>> threads              PASSED
>> Testing memory barriers with local variables with 10
>> threads           PASSED
>> Testing memory barriers with scattered array with 10
>> threads           PASSED
>> Testing memory barriers with linear array with 100 threads
>> *FAILED*
>>        at
>> /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in
>> test_barriers_linear_array()...
>> Testing memory barriers with local variables with 100 threads
>> *FAILED*
>>        at
>> /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in
>> test_barriers_variables()...
>> Testing memory barriers with scattered array with 100 threads
>> *FAILED*
>>        at
>> /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in
>> test_barriers_scattered_array()...
>> ***** 3 BARRIERS TESTS FAILED! *****
>> FAIL: test_barriers
>> 1 of 3 tests failed
>> Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
>> make[2]: *** [check-TESTS] Error 1
>> make[2]: Leaving directory
>> `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
>> make[1]: *** [check-am] Error 2
>> make[1]: Leaving directory
>> make: *** [check-recursive] Error 1
>> Failed running make check
>> ===== Exit bin/snapshot with status=2: Thu Dec 10 00:36:46 CST 2009
>> Dumping done
>> Runtest did not exit normally.
>>   Watchers List
>> OPA Daily test features/platforms watchers and procedure
>> Procedure:
>> The watcher will investigate and report the cause of failure by 11am.
>> The developer who checked in the error code may report so by then too.
>> The watcher or the developer should get the failure fixed and report it
>> by 3pm.
>> Watcher for OPA:         Neil
>> updated: 2009/05/05
>>   Tests Details
>> Testing all hosts.
>> opa
>> 00:35:06 up 7 days, 23:31, 43 users,  load average: 1.26, 1.87, 2.53
>> Filesystem           1K-blocks      Used Available Use% Mounted on
>> none                   8218016         0   8218016   0% /dev/shm
>> abem1:/var/lib/perceus/
>>                     138916864 110819312  21040960  85% /var/lib/perceus
>> 10.1.69.1:/usr/src   138916864 110819296  21040960  85% /usr/src
>> /dev/sda2             63013156     53512  62326844   1% /tmp
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
>>                     3385032528 534370892 2678711596  17% /usr/apps
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
>>                     80761058784 50211631052 29728898592  63%
>> /cfs/projects
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
>>                     55567516032 15251816060 37538061428  29% /u
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
>>                     3385032528 114971212 3121037876   4% /usr/local
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
>>                     242279901024 86818541480 147369164840  38%
>> /cfs/scratch
>> abem5:/var/spool/torque/server_logs
>>                     961428816 110628016 801962960  13%
>> abem5:/var/spool/torque/server_priv/accounting
>>                      73575600  52562288  17215504  76%
>> pop:/var/forward      70557056  58482120   8490840  88% /var/forward
>> mds03.uits.indiana.edu:/mds-wan/client
>>                     363327960768 342329842612 18737016948  95% /WAN/IU
>> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
>> TEST_TYPES=standard
>> Running CVS checkout with output saved in
>>   /u/ac/hdftest/snapshots-opa/log/CVS_LOG_1210Thu
>> Checking MANIFEST file ...
>> cat: /u/ac/hdftest/snapshots-opa/log/#runtest.1210Thu.21503: No such
>> file or directory
>> rm: cannot remove
>> `/u/ac/hdftest/snapshots-opa/log/#runtest.1210Thu.21503': No such
>> file or directory
>> *** launching tests from honest4 ***
>> TESTHOST is honest1
>>    Fork off timekeeper 30
>> Testing honest1
>> ssh honest1 -n cd
>> /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest
>> -nodiff -nocvs -configname honest1
>> Using configname option for -configname
>> opa
>> 00:35:27 up 7 days, 23:32, 45 users,  load average: 1.88, 1.58, 1.57
>> abem2:/var/lib/perceus/
>>                      74763440  62283744   8681888  88% /var/lib/perceus
>> /dev/sda2             63013156     67132  62313224   1% /tmp
>>                     80761058784 50210946452 29729523336  63%
>> /cfs/projects
>>                     55567516032 15251970284 37537891472  29% /u
>>                     3385032528 114971216 3121037868   4% /usr/local
>>                     242279901024 86818162724 147369591608  38%
>> /cfs/scratch
>>                     961428816 110628080 801962896  13%
>>                      73575600  52562368  17215424  76%
>> pop:/var/forward      70557056  58482176   8490784  88% /var/forward
>>                     363327960768 342330424868 18736395728  95% /WAN/IU
>> TEST_TYPES=standard
>> Running standard
>> Thu Dec 10 00:35:37 CST 2009
>> *** starting standard tests in honest1 ***
>> Uname -a: Linux honest1.ncsa.uiuc.edu
>> 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00
>> CST 2009 x86_64 x86_64 x86_64 GNU/Linux
>> SRCDIRNAME is honest1
>> Running snapshot with output saved in
>> SNAPCMD is srcdir test clean
>> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib
>> /usr/local/include,/usr/local/lib srcdirname honest1
>> *** finished standard tests for honest1 ***
>> Total time = 1m 9s
>> *** finished tests in honest1 ***
>> ****SYSTEM ERROR honest1: Abnormal exit from runtest ****
>>     Thu Dec 10 00:37:16 CST 2009
>>     ****SYSTEM ERROR honest1: runtest command failed ****
>> *** finished tests in honest4 ***
>> opa-nightly-tests mailing list
>> opa-nightly-tests at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
