[opa-nightly-tests] jam OPA_Daily_Tests_0824Mon_FAILED!!!
Quincey Koziol koziol at hdfgroup.org
Mon Aug 24 11:57:21 CDT 2009
On Aug 24, 2009, at 11:33 AM, Neil Fortner wrote:
> On 08/24/2009 09:27 AM, Quincey Koziol wrote:
>> On Aug 24, 2009, at 8:09 AM, Dave Goodell wrote:
>>> It looks like we need a configure test for pthread_yield, since it
>>> doesn't seem to be supported on SunOS 5.x.
>>    Yes.  However, Neil's at a conference until Friday, so it might
>> be a few days of failing tests until he gets back to fixing it.  If
>> I can find some spare time, I'll see what I can do before then.
> I'll try to get to it tonight.
	Super!  Thanks,
		Quincey
> -Neil
>>    Quincey
>>> -Dave
>>> On Aug 24, 2009, at 6:04 AM, HDF Tester wrote:
>>>> *** OPA Tests on 0824Mon ***
>>>> Tests Summary
>>>> ****FAILED linew: runtest command failed ****
>>>> ****FAILED linew: standard****
>>>> PASSED colonelk: standard
>>>> PASSED duty: standard
>>>> PASSED jam: standard
>>>> PASSED liberty: standard
>>>> PASSED smirom: standard
>>>> Tests Time Summary
>>>> linew: Ran 1(0/1/0) tests, Grand total test time =  0m 33s
>>>> jam: Ran 1(1/0/0) tests, Grand total test time =  0m 49s
>>>> smirom: Ran 1(1/0/0) tests, Grand total test time =  0m 59s
>>>> liberty: Ran 1(1/0/0) tests, Grand total test time =  0m 55s
>>>> colonelk: Ran 1(1/0/0) tests, Grand total test time =  1m 31s
>>>> duty: Ran 1(1/0/0) tests, Grand total test time =  2m 6s
>>>> jam: Ran 6(0/0/0) hosts, Grand total test time =  3m 4s
>>>> Timekeeper log
>>>> Timekeeper started at Mon Aug 24 06:01:31 CDT 2009
>>>> Timekeeper sleeping for 1800 seconds
>>>> Tests Failures
>>>> Dumping logfile of linew: standard
>>>> Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/
>>>> linew_0824Mon_0601
>>>> gmake[1]: warning: -jN forced in submake: disabling jobserver mode.
>>>> gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/
>>>> linew/src'
>>>> Making check in test
>>>> gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/
>>>> linew/test'
>>>> gmake -j 2  sanity test_primitives test_barriers
>>>> gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/
>>>> linew/test'
>>>> gmake[2]: warning: -jN forced in submake: disabling jobserver mode.
>>>> gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/
>>>> test -I../src  -I/home/hdftest/snapshots-opa/current/src   -g -O2
>>>> -MT sanity.o -MD -MP -MF .deps/sanity.Tpo -c -o sanity.o /home/
>>>> hdftest/snapshots-opa/current/test/sanity.c
>>>> -MT test_primitives.o -MD -MP -MF .deps/test_primitives.Tpo -c -o
>>>> test_primitives.o /home/hdftest/snapshots-opa/current/test/
>>>> test_primitives.c
>>>> mv -f .deps/sanity.Tpo .deps/sanity.Po
>>>> -MT test_barriers.o -MD -MP -MF .deps/test_barriers.Tpo -c -o
>>>> test_barriers.o /home/hdftest/snapshots-opa/current/test/
>>>> test_barriers.c
>>>> mv -f .deps/test_barriers.Tpo .deps/test_barriers.Po
>>>> gcc  -g -O2   -o sanity sanity.o ../src/libopa.a -lpthread
>>>> gcc  -g -O2   -o test_barriers test_barriers.o ../src/libopa.a -
>>>> lpthread
>>>> mv -f .deps/test_primitives.Tpo .deps/test_primitives.Po
>>>> gcc  -g -O2   -o test_primitives test_primitives.o ../src/
>>>> libopa.a -lpthread
>>>> Undefined            first referenced
>>>> symbol                  in file
>>>> pthread_yield                       test_primitives.o
>>>> ld: fatal: Symbol referencing errors. No output written to
>>>> test_primitives
>>>> collect2: ld returned 1 exit status
>>>> gmake[2]: *** [test_primitives] Error 1
>>>> gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/
>>>> linew/test'
>>>> gmake[1]: *** [check-am] Error 2
>>>> linew/test'
>>>> gmake: *** [check-recursive] Error 1
>>>> Failed running make check
>>>> ===== Exit bin/snapshot with status=0: Mon Aug 24 06:02:18 CDT
>>>> 2009 =====
>>>> Mon Aug 24 06:02:18 CDT 2009
>>>> Dumping done
>>>> Watchers List
>>>> OPA Daily test features/platforms watchers and procedure
>>>> Procedure:
>>>> The watcher will investigate and report the cause of failure by
>>>> 11am.
>>>> The developer who checked in the error code may report so by then
>>>> too.
>>>> The watcher or the developer should get the failure fixed and
>>>> report it
>>>> by 3pm.
>>>> Watcher for OPA:         Neil
>>>> updated: 2009/05/05
>>>> Tests Details
>>>> Testing all hosts.
>>>> opa
>>>> 06:01:17 up 52 days, 21:25, 16 users,  load average: 0.00, 0.00,
>>>> 0.09
>>>> Filesystem           1K-blocks      Used Available Use% Mounted on
>>>> /dev/sda3             31738420   3076808  27023384  11% /
>>>> /dev/sda1               101086     50879     44988  54% /boot
>>>> /dev/sda2             31738420    277972  29822220   1% /tmp
>>>> /dev/sda6             31738392   3779520  26320648  13% /var
>>>> /dev/sda7             31738392  14147728  15952440  48% /usr
>>>> /dev/sda8            124991068  14128420 104410948  12% /var/tmp
>>>> /dev/mapper/VolGroup00-home
>>>>                   198351840  11678972 176434508   7% /home
>>>> /dev/sde1            565688764  28015584 508474244   6% /scr
>>>> /dev/sdc1            961432072 446910716 465683356  49% /mnt/scr1
>>>> /dev/sdd1            961432072 229095448 683498624  26% /mnt/hdf
>>>> tmpfs                  1551408         0   1551408   0% /dev/shm
>>>> gumund:/data/ftp     480719072 178995072 277304800  40% /mnt/ftp
>>>> gumund:/data/web     480719072 178995072 277304800  40% /mnt/web
>>>> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
>>>> TEST_TYPES=standard
>>>> FTP flag is
>>>> Running CVS checkout with output saved in
>>>> /mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0824Mon
>>>> Checking MANIFEST file ...
>>>> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0824Mon.24480:
>>>> No such file or directory
>>>> rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.
>>>> 0824Mon.24480': No such file or directory
>>>> Mon Aug 24 06:01:30 CDT 2009
>>>> *** launching tests from jam ***
>>>> TESTHOST is linew
>>>> jam
>>>> smirom
>>>> colonelk
>>>> duty
>>>> liberty
>>>>  Fork off timekeeper 30
>>>> Testing linew
>>>> ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
>>>> snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
>>>> Using configname option for -configname
>>>> opa
>>>> 6:01am  up 4 day(s), 18 hr(s),  7 users,  load average: 0.52,
>>>> 1.01, 1.08
>>>> /                  (/dev/dsk/c1t0d0s0 ):53286352 blocks  8032055
>>>> files
>>>> /devices           (/devices          ):       0 blocks        0
>>>> files
>>>> /system/contract   (ctfs              ):       0 blocks
>>>> 2147483607 files
>>>> /proc              (proc              ):       0 blocks    29922
>>>> files
>>>> /etc/mnttab        (mnttab            ):       0 blocks        0
>>>> files
>>>> /etc/svc/volatile  (swap              ):16850944 blocks  1182899
>>>> files
>>>> /system/object     (objfs             ):       0 blocks
>>>> 2147483484 files
>>>> /etc/dfs/sharetab  (sharefs           ):       0 blocks
>>>> 2147483646 files
>>>> /platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/
>>>> libc_psr/libc_psr_hwcap1.so.1):53286352 blocks  8032055 files
>>>> /platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/
>>>> lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):53286352 blocks
>>>> 8032055 files
>>>> /dev/fd            (fd                ):       0 blocks        0
>>>> files
>>>> /tmp               (swap              ):16850944 blocks  1182899
>>>> files
>>>> /var/run           (swap              ):16850944 blocks  1182899
>>>> files
>>>> /home              (jam:/home         ):373345736 blocks 51006775
>>>> files
>>>> /mnt/hdf           (jam:/mnt/hdf      ):1464673248 blocks
>>>> 118079083 files
>>>> /mnt/scr1          (jam:/mnt/scr1     ):1029042664 blocks
>>>> 117865286 files
>>>> /mnt/web           (gumund:/mnt/web   ):603447984 blocks 60659265
>>>> files
>>>> /mnt/ftp           (gumund:/mnt/ftp   ):603447984 blocks 60659265
>>>> files
>>>> TEST_TYPES=standard
>>>> Running standard
>>>> Mon Aug 24 06:01:46 CDT 2009
>>>> *** starting standard tests in linew ***
>>>> Uname -a: SunOS linew 5.10 Generic_141414-08 sun4u sparc SUNW,A70
>>>> /mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
>>>> SRCDIRNAME is linew
>>>> Running snapshot with output saved in
>>>> /mnt/scr1/SnapTest/snapshots-opa/log/linew_0824Mon_0601
>>>> SNAPCMD is srcdir test clean
>>>> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/
>>>> include,/usr/lib srcdirname linew
>>>> *** finished standard tests for linew ***
>>>> Total time = 0m 32s
>>>> *** finished tests in linew ***
>>>> ****FAILED linew: Abnormal exit from runtest ****
>>>>    Mon Aug 24 06:04:31 CDT 2009
>>>> Testing jam
>>>> ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
>>>> snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
>>>> opa
>>>> 06:01:37 up 52 days, 21:25, 16 users,  load average: 0.00, 0.00,
>>>> 0.09
>>>> /dev/sda2             31738420    277976  29822216   1% /tmp
>>>> /dev/sdc1            961432072 446910748 465683324  49% /mnt/scr1
>>>> TEST_TYPES=standard
>>>> Running standard
>>>> Mon Aug 24 06:01:47 CDT 2009
>>>> *** starting standard tests in jam ***
>>>> Uname -a: Linux jam 2.6.18-128.1.16.el5 #1 SMP Tue Jun 30
>>>> 06:10:28 EDT 2009 i686 i686 i386 GNU/Linux
>>>> SRCDIRNAME is jam
>>>> /mnt/scr1/SnapTest/snapshots-opa/log/jam_0824Mon_0601
>>>> include,/usr/lib srcdirname jam
>>>> *** finished standard tests for jam ***
>>>> Mon Aug 24 06:02:36 CDT 2009
>>>> Total time = 0m 49s
>>>> *** finished tests in jam ***
>>>> Testing smirom
>>>> ssh smirom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
>>>> snapshots-opa/bin/runtest -nodiff -nocvs -configname smirom
>>>> opa
>>>> 6:01am  up 3 days 13:54,  4 users,  load average: 0.01, 0.01, 0.11
>>>> /dev/hdb1             76920416  10081264  62931744  14% /
>>>> udev                   1991252       116   1991136   1% /dev
>>>> /dev/sda2            129736964  31028332  98708632  24% /scr
>>>> /dev/sdb1             76920416  29621208  43391800  41% /usr
>>>> jam:/home            198351840  11678944 176434528   7% /home
>>>> jam:/mnt/hdf         961432096 229095456 683498624  26% /mnt/hdf
>>>> jam:/mnt/scr1        961432096 446910784 465683328  49% /mnt/scr1
>>>> TEST_TYPES=standard
>>>> Running standard
>>>> Mon Aug 24 06:01:53 CDT 2009
>>>> *** starting standard tests in smirom ***
>>>> Uname -a: Linux smirom 2.6.16.60-0.34-smp #1 SMP Fri Jan 16
>>>> 14:59:01 UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
>>>> SRCDIRNAME is smirom
>>>> /mnt/scr1/SnapTest/snapshots-opa/log/smirom_0824Mon_0601
>>>> include,/usr/lib srcdirname smirom
>>>> *** finished standard tests for smirom ***
>>>> Mon Aug 24 06:02:52 CDT 2009
>>>> Total time = 0m 59s
>>>> *** finished tests in smirom ***
>>>> Testing colonelk
>>>> ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
>>>> snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
>>>> opa
>>>> 06:01:42 up 5 days, 16:56,  0 users,  load average: 0.00, 0.00,
>>>> 0.00
>>>> /dev/hda3             29753588   3608728  24609048  13% /
>>>> /dev/hda2             49961020   2445196  44936992   6% /tmp
>>>> /dev/hda6              9920592    673524   8735000   8% /var
>>>> /dev/hda5             19840892  10006060   8810692  54% /scr
>>>> /dev/hda1               101086     33315     62552  35% /boot
>>>> tmpfs                   517644         0    517644   0% /dev/shm
>>>> TEST_TYPES=standard
>>>> Running standard
>>>> Mon Aug 24 06:01:52 CDT 2009
>>>> *** starting standard tests in colonelk ***
>>>> Uname -a: Linux colonelk 2.6.18-128.4.1.el5 #1 SMP Tue Aug 4
>>>> 20:23:34 EDT 2009 i686 i686 i386 GNU/Linux
>>>> SRCDIRNAME is colonelk
>>>> /mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0824Mon_0601
>>>> include,/usr/lib srcdirname colonelk
>>>> *** finished standard tests for colonelk ***
>>>> Mon Aug 24 06:03:23 CDT 2009
>>>> Total time = 1m 31s
>>>> *** finished tests in colonelk ***
>>>> Testing duty
>>>> ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
>>>> snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
>>>> opa
>>>> 6:01AM  up 89 days, 17:57, 0 users, load averages: 0.00, 0.00, 0.00
>>>> Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
>>>> /dev/aacd0s1a       507630     60994    406026    13%    /
>>>> devfs                    1         1         0   100%    /dev
>>>> /dev/aacd0s1h    188433016 120649098  52709278    70%    /data
>>>> /dev/aacd0s1g     32494668  23018730   6876366    77%    /
>>>> local_home
>>>> /dev/aacd0s1f     12186190   2770778   8440518    25%    /usr
>>>> /dev/aacd0s1d       507630     46158    420862    10%    /var
>>>> /dev/aacd0s1e       253678       334    233050     0%    /var/tmp
>>>> procfs                   4         4         0   100%    /proc
>>>> jam:/home        198351840  11678972 176434508     6%    /home
>>>> jam:/mnt/scr1    961432072 446910772 465683300    49%    /mnt/scr1
>>>> gumund:/data/web 480719056 178995064 277304792    39%    /mnt/web
>>>> gumund:/data/ftp 480719056 178995064 277304792    39%    /mnt/ftp
>>>> devfs                    1         1         0   100%    /var/
>>>> named/dev
>>>> /dev/md0            126702        46    116520     0%    /tmp
>>>> jam:/mnt/hdf     961432072 229095448 683498624    25%    /mnt/hdf
>>>> TEST_TYPES=standard
>>>> Running standard
>>>> Mon Aug 24 06:01:55 CDT 2009
>>>> *** starting standard tests in duty ***
>>>> Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-
>>>> STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu
>>>> :/usr/obj/usr/src/sys/DUTY  i386
>>>> SRCDIRNAME is duty
>>>> /mnt/scr1/SnapTest/snapshots-opa/log/duty_0824Mon_0601
>>>> include,/usr/lib srcdirname duty
>>>> *** finished standard tests for duty ***
>>>> Mon Aug 24 06:04:01 CDT 2009
>>>> Total time = 2m 6s
>>>> *** finished tests in duty ***
>>>> Testing liberty
>>>> ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
>>>> snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
>>>> opa
>>>> 6:01AM  up 89 days, 17:59, 9 users, load averages: 0.00, 0.00, 0.00
>>>> /dev/aacd0s1a       507630     86918    380102    19%    /
>>>> /dev/aacd0s1g     47047830  20595098  22688906    48%    /
>>>> local_home
>>>> /dev/aacd0s1f     12186190   4133002   7078294    37%    /usr
>>>> /dev/aacd0s1d      1012974     99016    832922    11%    /var
>>>> /dev/aacd0s1e       507630    336490    130530    72%    /var/tmp
>>>> jam:/mnt/scr1    961432072 446910780 465683292    49%    /mnt/scr1
>>>> named/dev
>>>> /dev/md0            126702        54    116512     0%    /tmp
>>>> TEST_TYPES=standard
>>>> Running standard
>>>> Mon Aug 24 06:01:57 CDT 2009
>>>> *** starting standard tests in liberty ***
>>>> Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD
>>>> 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008     sukoziol at liberty.hdfgroup.uiuc.edu
>>>> :/usr/obj/usr/src/sys/LIBERTY  amd64
>>>> SRCDIRNAME is liberty
>>>> /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0824Mon_0601
>>>> include,/usr/lib srcdirname liberty
>>>> *** finished standard tests for liberty ***
>>>> Total time = 0m 55s
>>>> *** finished tests in liberty ***
>>>> _______________________________________________
>>>> opa-nightly-tests mailing list
>>>> opa-nightly-tests at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
