[opa-nightly-tests] jam OPA_Daily_Tests_0824Mon_FAILED!!!
Neil Fortner nfortne2 at hdfgroup.org
Mon Aug 24 11:33:34 CDT 2009
On 08/24/2009 09:27 AM, Quincey Koziol wrote:
> On Aug 24, 2009, at 8:09 AM, Dave Goodell wrote:
>> It looks like we need a configure test for pthread_yield, since it
>> doesn't seem to be supported on SunOS 5.x.
>     Yes.  However, Neil's at a conference until Friday, so it might be
> a few days of failing tests until he gets back to fixing it.  If I can
> find some spare time, I'll see what I can do before then.
I'll try to get to it tonight.
-Neil
>     Quincey
>> -Dave
>> On Aug 24, 2009, at 6:04 AM, HDF Tester wrote:
>>> *** OPA Tests on 0824Mon ***
>>>  Tests Summary
>>> ****FAILED linew: runtest command failed ****
>>> ****FAILED linew: standard****
>>> PASSED colonelk: standard
>>> PASSED duty: standard
>>> PASSED jam: standard
>>> PASSED liberty: standard
>>> PASSED smirom: standard
>>>  Tests Time Summary
>>> linew: Ran 1(0/1/0) tests, Grand total test time =  0m 33s
>>> jam: Ran 1(1/0/0) tests, Grand total test time =  0m 49s
>>> smirom: Ran 1(1/0/0) tests, Grand total test time =  0m 59s
>>> liberty: Ran 1(1/0/0) tests, Grand total test time =  0m 55s
>>> colonelk: Ran 1(1/0/0) tests, Grand total test time =  1m 31s
>>> duty: Ran 1(1/0/0) tests, Grand total test time =  2m 6s
>>> jam: Ran 6(0/0/0) hosts, Grand total test time =  3m 4s
>>>  Timekeeper log
>>> Timekeeper started at Mon Aug 24 06:01:31 CDT 2009
>>> Timekeeper sleeping for 1800 seconds
>>>  Tests Failures
>>> Dumping logfile of linew: standard
>>> Last 30 lines of
>>> /mnt/scr1/SnapTest/snapshots-opa/log/linew_0824Mon_0601
>>> gmake[1]: warning: -jN forced in submake: disabling jobserver mode.
>>> gmake[1]: Leaving directory
>>> `/scr/hdftest/snapshots-opa/TestDir/linew/src'
>>> Making check in test
>>> gmake[1]: Entering directory
>>> `/scr/hdftest/snapshots-opa/TestDir/linew/test'
>>> gmake -j 2  sanity test_primitives test_barriers
>>> gmake[2]: Entering directory
>>> gmake[2]: warning: -jN forced in submake: disabling jobserver mode.
>>> gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test
>>> -I../src  -I/home/hdftest/snapshots-opa/current/src   -g -O2 -MT
>>> sanity.o -MD -MP -MF .deps/sanity.Tpo -c -o sanity.o
>>> /home/hdftest/snapshots-opa/current/test/sanity.c
>>> test_primitives.o -MD -MP -MF .deps/test_primitives.Tpo -c -o
>>> test_primitives.o
>>> /home/hdftest/snapshots-opa/current/test/test_primitives.c
>>> mv -f .deps/sanity.Tpo .deps/sanity.Po
>>> test_barriers.o -MD -MP -MF .deps/test_barriers.Tpo -c -o
>>> test_barriers.o
>>> /home/hdftest/snapshots-opa/current/test/test_barriers.c
>>> mv -f .deps/test_barriers.Tpo .deps/test_barriers.Po
>>> gcc  -g -O2   -o sanity sanity.o ../src/libopa.a -lpthread
>>> gcc  -g -O2   -o test_barriers test_barriers.o ../src/libopa.a
>>> -lpthread
>>> mv -f .deps/test_primitives.Tpo .deps/test_primitives.Po
>>> gcc  -g -O2   -o test_primitives test_primitives.o ../src/libopa.a
>>> -lpthread
>>> Undefined            first referenced
>>> symbol                  in file
>>> pthread_yield                       test_primitives.o
>>> ld: fatal: Symbol referencing errors. No output written to
>>> test_primitives
>>> collect2: ld returned 1 exit status
>>> gmake[2]: *** [test_primitives] Error 1
>>> gmake[2]: Leaving directory
>>> gmake[1]: *** [check-am] Error 2
>>> gmake: *** [check-recursive] Error 1
>>> Failed running make check
>>> ===== Exit bin/snapshot with status=0: Mon Aug 24 06:02:18 CDT 2009
>>> Dumping done
>>>  Watchers List
>>> OPA Daily test features/platforms watchers and procedure
>>> Procedure:
>>> The watcher will investigate and report the cause of failure by 11am.
>>> The developer who checked in the error code may report so by then too.
>>> The watcher or the developer should get the failure fixed and report it
>>> by 3pm.
>>> Watcher for OPA:         Neil
>>> updated: 2009/05/05
>>>  Tests Details
>>> Testing all hosts.
>>> opa
>>> 06:01:17 up 52 days, 21:25, 16 users,  load average: 0.00, 0.00, 0.09
>>> Filesystem           1K-blocks      Used Available Use% Mounted on
>>> /dev/sda3             31738420   3076808  27023384  11% /
>>> /dev/sda1               101086     50879     44988  54% /boot
>>> /dev/sda2             31738420    277972  29822220   1% /tmp
>>> /dev/sda6             31738392   3779520  26320648  13% /var
>>> /dev/sda7             31738392  14147728  15952440  48% /usr
>>> /dev/sda8            124991068  14128420 104410948  12% /var/tmp
>>> /dev/mapper/VolGroup00-home
>>>                    198351840  11678972 176434508   7% /home
>>> /dev/sde1            565688764  28015584 508474244   6% /scr
>>> /dev/sdc1            961432072 446910716 465683356  49% /mnt/scr1
>>> /dev/sdd1            961432072 229095448 683498624  26% /mnt/hdf
>>> tmpfs                  1551408         0   1551408   0% /dev/shm
>>> gumund:/data/ftp     480719072 178995072 277304800  40% /mnt/ftp
>>> gumund:/data/web     480719072 178995072 277304800  40% /mnt/web
>>> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
>>> TEST_TYPES=standard
>>> FTP flag is
>>> Running CVS checkout with output saved in
>>>  /mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0824Mon
>>> Checking MANIFEST file ...
>>> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0824Mon.24480: No
>>> such file or directory
>>> rm: cannot remove
>>> `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0824Mon.24480': No
>>> Mon Aug 24 06:01:30 CDT 2009
>>> *** launching tests from jam ***
>>> TESTHOST is linew
>>> jam
>>> smirom
>>> colonelk
>>> duty
>>> liberty
>>>   Fork off timekeeper 30
>>> Testing linew
>>> ssh linew -n cd
>>> /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest
>>> -nodiff -nocvs -configname linew
>>> Using configname option for -configname
>>> opa
>>> 6:01am  up 4 day(s), 18 hr(s),  7 users,  load average: 0.52, 1.01,
>>> 1.08
>>> /                  (/dev/dsk/c1t0d0s0 ):53286352 blocks  8032055 files
>>> /devices           (/devices          ):       0 blocks        0 files
>>> /system/contract   (ctfs              ):       0 blocks 2147483607
>>> files
>>> /proc              (proc              ):       0 blocks    29922 files
>>> /etc/mnttab        (mnttab            ):       0 blocks        0 files
>>> /etc/svc/volatile  (swap              ):16850944 blocks  1182899 files
>>> /system/object     (objfs             ):       0 blocks 2147483484
>>> files
>>> /etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646
>>> files
>>> /platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):53286352
>>> /platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):53286352
>>> /dev/fd            (fd                ):       0 blocks        0 files
>>> /tmp               (swap              ):16850944 blocks  1182899 files
>>> /var/run           (swap              ):16850944 blocks  1182899 files
>>> /home              (jam:/home         ):373345736 blocks 51006775 files
>>> /mnt/hdf           (jam:/mnt/hdf      ):1464673248 blocks 118079083
>>> files
>>> /mnt/scr1          (jam:/mnt/scr1     ):1029042664 blocks 117865286
>>> files
>>> /mnt/web           (gumund:/mnt/web   ):603447984 blocks 60659265 files
>>> /mnt/ftp           (gumund:/mnt/ftp   ):603447984 blocks 60659265 files
>>> TEST_TYPES=standard
>>> Running standard
>>> Mon Aug 24 06:01:46 CDT 2009
>>> *** starting standard tests in linew ***
>>> Uname -a: SunOS linew 5.10 Generic_141414-08 sun4u sparc SUNW,A70
>>> /mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
>>> SRCDIRNAME is linew
>>> Running snapshot with output saved in
>>> SNAPCMD is srcdir test clean
>>> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib
>>> /usr/include,/usr/lib srcdirname linew
>>> *** finished standard tests for linew ***
>>> Total time = 0m 32s
>>> *** finished tests in linew ***
>>> ****FAILED linew: Abnormal exit from runtest ****
>>>     Mon Aug 24 06:04:31 CDT 2009
>>> Testing jam
>>> ssh jam -n cd
>>> -nodiff -nocvs -configname jam
>>> opa
>>> 06:01:37 up 52 days, 21:25, 16 users,  load average: 0.00, 0.00, 0.09
>>> /dev/sda2             31738420    277976  29822216   1% /tmp
>>> /dev/sdc1            961432072 446910748 465683324  49% /mnt/scr1
>>> TEST_TYPES=standard
>>> Running standard
>>> Mon Aug 24 06:01:47 CDT 2009
>>> *** starting standard tests in jam ***
>>> Uname -a: Linux jam 2.6.18-128.1.16.el5 #1 SMP Tue Jun 30 06:10:28
>>> EDT 2009 i686 i686 i386 GNU/Linux
>>> SRCDIRNAME is jam
>>>  /mnt/scr1/SnapTest/snapshots-opa/log/jam_0824Mon_0601
>>> /usr/include,/usr/lib srcdirname jam
>>> *** finished standard tests for jam ***
>>> Mon Aug 24 06:02:36 CDT 2009
>>> Total time = 0m 49s
>>> *** finished tests in jam ***
>>> Testing smirom
>>> ssh smirom -n cd
>>> -nodiff -nocvs -configname smirom
>>> opa
>>> 6:01am  up 3 days 13:54,  4 users,  load average: 0.01, 0.01, 0.11
>>> /dev/hdb1             76920416  10081264  62931744  14% /
>>> udev                   1991252       116   1991136   1% /dev
>>> /dev/sda2            129736964  31028332  98708632  24% /scr
>>> /dev/sdb1             76920416  29621208  43391800  41% /usr
>>> jam:/home            198351840  11678944 176434528   7% /home
>>> jam:/mnt/hdf         961432096 229095456 683498624  26% /mnt/hdf
>>> jam:/mnt/scr1        961432096 446910784 465683328  49% /mnt/scr1
>>> TEST_TYPES=standard
>>> Running standard
>>> Mon Aug 24 06:01:53 CDT 2009
>>> *** starting standard tests in smirom ***
>>> Uname -a: Linux smirom 2.6.16.60-0.34-smp #1 SMP Fri Jan 16 14:59:01
>>> UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
>>> SRCDIRNAME is smirom
>>>  /mnt/scr1/SnapTest/snapshots-opa/log/smirom_0824Mon_0601
>>> /usr/include,/usr/lib srcdirname smirom
>>> *** finished standard tests for smirom ***
>>> Mon Aug 24 06:02:52 CDT 2009
>>> Total time = 0m 59s
>>> *** finished tests in smirom ***
>>> Testing colonelk
>>> ssh colonelk -n cd
>>> -nodiff -nocvs -configname colonelk
>>> opa
>>> 06:01:42 up 5 days, 16:56,  0 users,  load average: 0.00, 0.00, 0.00
>>> /dev/hda3             29753588   3608728  24609048  13% /
>>> /dev/hda2             49961020   2445196  44936992   6% /tmp
>>> /dev/hda6              9920592    673524   8735000   8% /var
>>> /dev/hda5             19840892  10006060   8810692  54% /scr
>>> /dev/hda1               101086     33315     62552  35% /boot
>>> tmpfs                   517644         0    517644   0% /dev/shm
>>> TEST_TYPES=standard
>>> Running standard
>>> Mon Aug 24 06:01:52 CDT 2009
>>> *** starting standard tests in colonelk ***
>>> Uname -a: Linux colonelk 2.6.18-128.4.1.el5 #1 SMP Tue Aug 4
>>> 20:23:34 EDT 2009 i686 i686 i386 GNU/Linux
>>> SRCDIRNAME is colonelk
>>>  /mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0824Mon_0601
>>> /usr/include,/usr/lib srcdirname colonelk
>>> *** finished standard tests for colonelk ***
>>> Mon Aug 24 06:03:23 CDT 2009
>>> Total time = 1m 31s
>>> *** finished tests in colonelk ***
>>> Testing duty
>>> ssh duty -n cd
>>> -nodiff -nocvs -configname duty
>>> opa
>>> 6:01AM  up 89 days, 17:57, 0 users, load averages: 0.00, 0.00, 0.00
>>> Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
>>> /dev/aacd0s1a       507630     60994    406026    13%    /
>>> devfs                    1         1         0   100%    /dev
>>> /dev/aacd0s1h    188433016 120649098  52709278    70%    /data
>>> /dev/aacd0s1g     32494668  23018730   6876366    77%    /local_home
>>> /dev/aacd0s1f     12186190   2770778   8440518    25%    /usr
>>> /dev/aacd0s1d       507630     46158    420862    10%    /var
>>> /dev/aacd0s1e       253678       334    233050     0%    /var/tmp
>>> procfs                   4         4         0   100%    /proc
>>> jam:/home        198351840  11678972 176434508     6%    /home
>>> jam:/mnt/scr1    961432072 446910772 465683300    49%    /mnt/scr1
>>> gumund:/data/web 480719056 178995064 277304792    39%    /mnt/web
>>> gumund:/data/ftp 480719056 178995064 277304792    39%    /mnt/ftp
>>> devfs                    1         1         0   100%    /var/named/dev
>>> /dev/md0            126702        46    116520     0%    /tmp
>>> jam:/mnt/hdf     961432072 229095448 683498624    25%    /mnt/hdf
>>> TEST_TYPES=standard
>>> Running standard
>>> Mon Aug 24 06:01:55 CDT 2009
>>> *** starting standard tests in duty ***
>>> Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD
>>> 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008
>>> sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
>>> SRCDIRNAME is duty
>>>  /mnt/scr1/SnapTest/snapshots-opa/log/duty_0824Mon_0601
>>> /usr/include,/usr/lib srcdirname duty
>>> *** finished standard tests for duty ***
>>> Mon Aug 24 06:04:01 CDT 2009
>>> Total time = 2m 6s
>>> *** finished tests in duty ***
>>> Testing liberty
>>> ssh liberty -n cd
>>> -nodiff -nocvs -configname liberty
>>> opa
>>> 6:01AM  up 89 days, 17:59, 9 users, load averages: 0.00, 0.00, 0.00
>>> /dev/aacd0s1a       507630     86918    380102    19%    /
>>> /dev/aacd0s1g     47047830  20595098  22688906    48%    /local_home
>>> /dev/aacd0s1f     12186190   4133002   7078294    37%    /usr
>>> /dev/aacd0s1d      1012974     99016    832922    11%    /var
>>> /dev/aacd0s1e       507630    336490    130530    72%    /var/tmp
>>> jam:/mnt/scr1    961432072 446910780 465683292    49%    /mnt/scr1
>>> /dev/md0            126702        54    116512     0%    /tmp
>>> TEST_TYPES=standard
>>> Running standard
>>> Mon Aug 24 06:01:57 CDT 2009
>>> *** starting standard tests in liberty ***
>>> Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD
>>> 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008
>>> sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY  amd64
>>> SRCDIRNAME is liberty
>>>  /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0824Mon_0601
>>> /usr/include,/usr/lib srcdirname liberty
>>> *** finished standard tests for liberty ***
>>> Total time = 0m 55s
>>> *** finished tests in liberty ***
>>> _______________________________________________
>>> opa-nightly-tests mailing list
>>> opa-nightly-tests at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
