[opa-nightly-tests] jam OPA_Daily_Tests_0824Mon_FAILED!!!
Neil Fortner
nfortne2 at hdfgroup.org
Tue Aug 25 18:28:01 CDT 2009
On 08/24/2009 11:57 AM, Quincey Koziol wrote:
> On Aug 24, 2009, at 11:33 AM, Neil Fortner wrote:
>> On 08/24/2009 09:27 AM, Quincey Koziol wrote:
>>> On Aug 24, 2009, at 8:09 AM, Dave Goodell wrote:
>>>> It looks like we need a configure test for pthread_yield, since it
>>>> doesn't seem to be supported on SunOS 5.x.
>>> Yes. However, Neil's at a conference until Friday, so it might
>>> be a few days of failing tests until he gets back to fixing it. If
>>> I can find some spare time, I'll see what I can do before then.
>> I'll try to get to it tonight.
> Super! Thanks,
Should be fixed now. Sorry about that.
-Neil
> Quincey
>> -Neil
>>> Quincey
>>>> -Dave
>>>> On Aug 24, 2009, at 6:04 AM, HDF Tester wrote:
>>>>> *** OPA Tests on 0824Mon ***
>>>>> Tests Summary
>>>>> ****FAILED linew: runtest command failed ****
>>>>> ****FAILED linew: standard****
>>>>> PASSED colonelk: standard
>>>>> PASSED duty: standard
>>>>> PASSED jam: standard
>>>>> PASSED liberty: standard
>>>>> PASSED smirom: standard
>>>>> Tests Time Summary
>>>>> linew: Ran 1(0/1/0) tests, Grand total test time = 0m 33s
>>>>> jam: Ran 1(1/0/0) tests, Grand total test time = 0m 49s
>>>>> smirom: Ran 1(1/0/0) tests, Grand total test time = 0m 59s
>>>>> liberty: Ran 1(1/0/0) tests, Grand total test time = 0m 55s
>>>>> colonelk: Ran 1(1/0/0) tests, Grand total test time = 1m 31s
>>>>> duty: Ran 1(1/0/0) tests, Grand total test time = 2m 6s
>>>>> jam: Ran 6(0/0/0) hosts, Grand total test time = 3m 4s
>>>>> Timekeeper log
>>>>> Timekeeper started at Mon Aug 24 06:01:31 CDT 2009
>>>>> Timekeeper sleeping for 1800 seconds
>>>>> Tests Failures
>>>>> Dumping logfile of linew: standard
>>>>> Last 30 lines of
>>>>> /mnt/scr1/SnapTest/snapshots-opa/log/linew_0824Mon_0601
>>>>> gmake[1]: warning: -jN forced in submake: disabling jobserver mode.
>>>>> gmake[1]: Leaving directory
>>>>> `/scr/hdftest/snapshots-opa/TestDir/linew/src'
>>>>> Making check in test
>>>>> gmake[1]: Entering directory
>>>>> `/scr/hdftest/snapshots-opa/TestDir/linew/test'
>>>>> gmake -j 2 sanity test_primitives test_barriers
>>>>> gmake[2]: Entering directory
>>>>> gmake[2]: warning: -jN forced in submake: disabling jobserver mode.
>>>>> gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test
>>>>> -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT
>>>>> sanity.o -MD -MP -MF .deps/sanity.Tpo -c -o sanity.o
>>>>> /home/hdftest/snapshots-opa/current/test/sanity.c
>>>>> test_primitives.o -MD -MP -MF .deps/test_primitives.Tpo -c -o
>>>>> test_primitives.o
>>>>> /home/hdftest/snapshots-opa/current/test/test_primitives.c
>>>>> mv -f .deps/sanity.Tpo .deps/sanity.Po
>>>>> test_barriers.o -MD -MP -MF .deps/test_barriers.Tpo -c -o
>>>>> test_barriers.o
>>>>> /home/hdftest/snapshots-opa/current/test/test_barriers.c
>>>>> mv -f .deps/test_barriers.Tpo .deps/test_barriers.Po
>>>>> gcc -g -O2 -o sanity sanity.o ../src/libopa.a -lpthread
>>>>> gcc -g -O2 -o test_barriers test_barriers.o ../src/libopa.a
>>>>> -lpthread
>>>>> mv -f .deps/test_primitives.Tpo .deps/test_primitives.Po
>>>>> gcc -g -O2 -o test_primitives test_primitives.o ../src/libopa.a
>>>>> -lpthread
>>>>> Undefined first referenced
>>>>> symbol in file
>>>>> pthread_yield test_primitives.o
>>>>> ld: fatal: Symbol referencing errors. No output written to
>>>>> test_primitives
>>>>> collect2: ld returned 1 exit status
>>>>> gmake[2]: *** [test_primitives] Error 1
>>>>> gmake[2]: Leaving directory
>>>>> gmake[1]: *** [check-am] Error 2
>>>>> gmake: *** [check-recursive] Error 1
>>>>> Failed running make check
>>>>> ===== Exit bin/snapshot with status=0: Mon Aug 24 06:02:18 CDT
>>>>> 2009 =====
>>>>> Mon Aug 24 06:02:18 CDT 2009
>>>>> Dumping done
>>>>> Watchers List
>>>>> OPA Daily test features/platforms watchers and procedure
>>>>> Procedure:
>>>>> The watcher will investigate and report the cause of failure by 11am.
>>>>> The developer who checked in the error code may report so by then
>>>>> too.
>>>>> The watcher or the developer should get the failure fixed and
>>>>> report it
>>>>> by 3pm.
>>>>> Watcher for OPA: Neil
>>>>> updated: 2009/05/05
>>>>> Tests Details
>>>>> Testing all hosts.
>>>>> opa
>>>>> 06:01:17 up 52 days, 21:25, 16 users, load average: 0.00, 0.00, 0.09
>>>>> Filesystem 1K-blocks Used Available Use% Mounted on
>>>>> /dev/sda3 31738420 3076808 27023384 11% /
>>>>> /dev/sda1 101086 50879 44988 54% /boot
>>>>> /dev/sda2 31738420 277972 29822220 1% /tmp
>>>>> /dev/sda6 31738392 3779520 26320648 13% /var
>>>>> /dev/sda7 31738392 14147728 15952440 48% /usr
>>>>> /dev/sda8 124991068 14128420 104410948 12% /var/tmp
>>>>> /dev/mapper/VolGroup00-home
>>>>> 198351840 11678972 176434508 7% /home
>>>>> /dev/sde1 565688764 28015584 508474244 6% /scr
>>>>> /dev/sdc1 961432072 446910716 465683356 49% /mnt/scr1
>>>>> /dev/sdd1 961432072 229095448 683498624 26% /mnt/hdf
>>>>> tmpfs 1551408 0 1551408 0% /dev/shm
>>>>> gumund:/data/ftp 480719072 178995072 277304800 40% /mnt/ftp
>>>>> gumund:/data/web 480719072 178995072 277304800 40% /mnt/web
>>>>> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
>>>>> TEST_TYPES=standard
>>>>> FTP flag is
>>>>> Running CVS checkout with output saved in
>>>>> /mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0824Mon
>>>>> Checking MANIFEST file ...
>>>>> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0824Mon.24480:
>>>>> No such file or directory
>>>>> rm: cannot remove
>>>>> `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0824Mon.24480': No
>>>>> Mon Aug 24 06:01:30 CDT 2009
>>>>> *** launching tests from jam ***
>>>>> TESTHOST is linew
>>>>> jam
>>>>> smirom
>>>>> colonelk
>>>>> duty
>>>>> liberty
>>>>> Fork off timekeeper 30
>>>>> Testing linew
>>>>> ssh linew -n cd
>>>>> /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest
>>>>> -nodiff -nocvs -configname linew
>>>>> Using configname option for -configname
>>>>> opa
>>>>> 6:01am up 4 day(s), 18 hr(s), 7 users, load average: 0.52,
>>>>> 1.01, 1.08
>>>>> / (/dev/dsk/c1t0d0s0 ):53286352 blocks 8032055
>>>>> files
>>>>> /devices (/devices ): 0 blocks 0
>>>>> files
>>>>> /system/contract (ctfs ): 0 blocks 2147483607
>>>>> files
>>>>> /proc (proc ): 0 blocks 29922
>>>>> files
>>>>> /etc/mnttab (mnttab ): 0 blocks 0
>>>>> files
>>>>> /etc/svc/volatile (swap ):16850944 blocks 1182899
>>>>> files
>>>>> /system/object (objfs ): 0 blocks 2147483484
>>>>> files
>>>>> /etc/dfs/sharetab (sharefs ): 0 blocks 2147483646
>>>>> files
>>>>> /platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):53286352
>>>>> blocks 8032055 files
>>>>> /platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):53286352
>>>>> /dev/fd (fd ): 0 blocks 0
>>>>> files
>>>>> /tmp (swap ):16850944 blocks 1182899
>>>>> files
>>>>> /var/run (swap ):16850944 blocks 1182899
>>>>> files
>>>>> /home (jam:/home ):373345736 blocks 51006775
>>>>> files
>>>>> /mnt/hdf (jam:/mnt/hdf ):1464673248 blocks
>>>>> 118079083 files
>>>>> /mnt/scr1 (jam:/mnt/scr1 ):1029042664 blocks
>>>>> 117865286 files
>>>>> /mnt/web (gumund:/mnt/web ):603447984 blocks 60659265
>>>>> files
>>>>> /mnt/ftp (gumund:/mnt/ftp ):603447984 blocks 60659265
>>>>> files
>>>>> TEST_TYPES=standard
>>>>> Running standard
>>>>> Mon Aug 24 06:01:46 CDT 2009
>>>>> *** starting standard tests in linew ***
>>>>> Uname -a: SunOS linew 5.10 Generic_141414-08 sun4u sparc SUNW,A70
>>>>> /mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
>>>>> SRCDIRNAME is linew
>>>>> Running snapshot with output saved in
>>>>> SNAPCMD is srcdir test clean
>>>>> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib
>>>>> /usr/include,/usr/lib srcdirname linew
>>>>> *** finished standard tests for linew ***
>>>>> Total time = 0m 32s
>>>>> *** finished tests in linew ***
>>>>> ****FAILED linew: Abnormal exit from runtest ****
>>>>> Mon Aug 24 06:04:31 CDT 2009
>>>>> Testing jam
>>>>> ssh jam -n cd
>>>>> -nodiff -nocvs -configname jam
>>>>> opa
>>>>> 06:01:37 up 52 days, 21:25, 16 users, load average: 0.00, 0.00, 0.09
>>>>> /dev/sda2 31738420 277976 29822216 1% /tmp
>>>>> /dev/sdc1 961432072 446910748 465683324 49% /mnt/scr1
>>>>> TEST_TYPES=standard
>>>>> Running standard
>>>>> Mon Aug 24 06:01:47 CDT 2009
>>>>> *** starting standard tests in jam ***
>>>>> Uname -a: Linux jam 2.6.18-128.1.16.el5 #1 SMP Tue Jun 30 06:10:28
>>>>> EDT 2009 i686 i686 i386 GNU/Linux
>>>>> SRCDIRNAME is jam
>>>>> /mnt/scr1/SnapTest/snapshots-opa/log/jam_0824Mon_0601
>>>>> /usr/include,/usr/lib srcdirname jam
>>>>> *** finished standard tests for jam ***
>>>>> Mon Aug 24 06:02:36 CDT 2009
>>>>> Total time = 0m 49s
>>>>> *** finished tests in jam ***
>>>>> Testing smirom
>>>>> ssh smirom -n cd
>>>>> -nodiff -nocvs -configname smirom
>>>>> opa
>>>>> 6:01am up 3 days 13:54, 4 users, load average: 0.01, 0.01, 0.11
>>>>> /dev/hdb1 76920416 10081264 62931744 14% /
>>>>> udev 1991252 116 1991136 1% /dev
>>>>> /dev/sda2 129736964 31028332 98708632 24% /scr
>>>>> /dev/sdb1 76920416 29621208 43391800 41% /usr
>>>>> jam:/home 198351840 11678944 176434528 7% /home
>>>>> jam:/mnt/hdf 961432096 229095456 683498624 26% /mnt/hdf
>>>>> jam:/mnt/scr1 961432096 446910784 465683328 49% /mnt/scr1
>>>>> TEST_TYPES=standard
>>>>> Running standard
>>>>> Mon Aug 24 06:01:53 CDT 2009
>>>>> *** starting standard tests in smirom ***
>>>>> Uname -a: Linux smirom 2.6.16.60-0.34-smp #1 SMP Fri Jan 16
>>>>> 14:59:01 UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
>>>>> SRCDIRNAME is smirom
>>>>> /mnt/scr1/SnapTest/snapshots-opa/log/smirom_0824Mon_0601
>>>>> /usr/include,/usr/lib srcdirname smirom
>>>>> *** finished standard tests for smirom ***
>>>>> Mon Aug 24 06:02:52 CDT 2009
>>>>> Total time = 0m 59s
>>>>> *** finished tests in smirom ***
>>>>> Testing colonelk
>>>>> ssh colonelk -n cd
>>>>> -nodiff -nocvs -configname colonelk
>>>>> opa
>>>>> 06:01:42 up 5 days, 16:56, 0 users, load average: 0.00, 0.00, 0.00
>>>>> /dev/hda3 29753588 3608728 24609048 13% /
>>>>> /dev/hda2 49961020 2445196 44936992 6% /tmp
>>>>> /dev/hda6 9920592 673524 8735000 8% /var
>>>>> /dev/hda5 19840892 10006060 8810692 54% /scr
>>>>> /dev/hda1 101086 33315 62552 35% /boot
>>>>> tmpfs 517644 0 517644 0% /dev/shm
>>>>> TEST_TYPES=standard
>>>>> Running standard
>>>>> Mon Aug 24 06:01:52 CDT 2009
>>>>> *** starting standard tests in colonelk ***
>>>>> Uname -a: Linux colonelk 2.6.18-128.4.1.el5 #1 SMP Tue Aug 4
>>>>> 20:23:34 EDT 2009 i686 i686 i386 GNU/Linux
>>>>> SRCDIRNAME is colonelk
>>>>> /mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0824Mon_0601
>>>>> /usr/include,/usr/lib srcdirname colonelk
>>>>> *** finished standard tests for colonelk ***
>>>>> Mon Aug 24 06:03:23 CDT 2009
>>>>> Total time = 1m 31s
>>>>> *** finished tests in colonelk ***
>>>>> Testing duty
>>>>> ssh duty -n cd
>>>>> -nodiff -nocvs -configname duty
>>>>> opa
>>>>> 6:01AM up 89 days, 17:57, 0 users, load averages: 0.00, 0.00, 0.00
>>>>> Filesystem 1K-blocks Used Avail Capacity Mounted on
>>>>> /dev/aacd0s1a 507630 60994 406026 13% /
>>>>> devfs 1 1 0 100% /dev
>>>>> /dev/aacd0s1h 188433016 120649098 52709278 70% /data
>>>>> /dev/aacd0s1g 32494668 23018730 6876366 77% /local_home
>>>>> /dev/aacd0s1f 12186190 2770778 8440518 25% /usr
>>>>> /dev/aacd0s1d 507630 46158 420862 10% /var
>>>>> /dev/aacd0s1e 253678 334 233050 0% /var/tmp
>>>>> procfs 4 4 0 100% /proc
>>>>> jam:/home 198351840 11678972 176434508 6% /home
>>>>> jam:/mnt/scr1 961432072 446910772 465683300 49% /mnt/scr1
>>>>> gumund:/data/web 480719056 178995064 277304792 39% /mnt/web
>>>>> gumund:/data/ftp 480719056 178995064 277304792 39% /mnt/ftp
>>>>> devfs 1 1 0 100%
>>>>> /var/named/dev
>>>>> /dev/md0 126702 46 116520 0% /tmp
>>>>> jam:/mnt/hdf 961432072 229095448 683498624 25% /mnt/hdf
>>>>> TEST_TYPES=standard
>>>>> Running standard
>>>>> Mon Aug 24 06:01:55 CDT 2009
>>>>> *** starting standard tests in duty ***
>>>>> Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD
>>>>> 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008
>>>>> sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
>>>>> SRCDIRNAME is duty
>>>>> /mnt/scr1/SnapTest/snapshots-opa/log/duty_0824Mon_0601
>>>>> /usr/include,/usr/lib srcdirname duty
>>>>> *** finished standard tests for duty ***
>>>>> Mon Aug 24 06:04:01 CDT 2009
>>>>> Total time = 2m 6s
>>>>> *** finished tests in duty ***
>>>>> Testing liberty
>>>>> ssh liberty -n cd
>>>>> -nodiff -nocvs -configname liberty
>>>>> opa
>>>>> 6:01AM up 89 days, 17:59, 9 users, load averages: 0.00, 0.00, 0.00
>>>>> /dev/aacd0s1a 507630 86918 380102 19% /
>>>>> /dev/aacd0s1g 47047830 20595098 22688906 48% /local_home
>>>>> /dev/aacd0s1f 12186190 4133002 7078294 37% /usr
>>>>> /dev/aacd0s1d 1012974 99016 832922 11% /var
>>>>> /dev/aacd0s1e 507630 336490 130530 72% /var/tmp
>>>>> jam:/mnt/scr1 961432072 446910780 465683292 49% /mnt/scr1
>>>>> devfs 1 1 0 100%
>>>>> /var/named/dev
>>>>> /dev/md0 126702 54 116512 0% /tmp
>>>>> TEST_TYPES=standard
>>>>> Running standard
>>>>> Mon Aug 24 06:01:57 CDT 2009
>>>>> *** starting standard tests in liberty ***
>>>>> Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD
>>>>> 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008
>>>>> sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY
>>>>> amd64
>>>>> SRCDIRNAME is liberty
>>>>> /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0824Mon_0601
>>>>> /usr/include,/usr/lib srcdirname liberty
>>>>> *** finished standard tests for liberty ***
>>>>> Total time = 0m 55s
>>>>> *** finished tests in liberty ***
>>>>> _______________________________________________
>>>>> opa-nightly-tests mailing list
>>>>> opa-nightly-tests at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests
