[opa-nightly-tests] jam OPA_Daily_Tests_0824Mon_FAILED!!!
Quincey Koziol
koziol at hdfgroup.org
Mon Aug 24 09:27:35 CDT 2009
On Aug 24, 2009, at 8:09 AM, Dave Goodell wrote:
> It looks like we need a configure test for pthread_yield, since it
> doesn't seem to be supported on SunOS 5.x.
Yes. However, Neil's at a conference until Friday, so it might be a
few days of failing tests until he gets back to fixing it. If I can
find some spare time, I'll see what I can do before then.
Quincey
> -Dave
> On Aug 24, 2009, at 6:04 AM, HDF Tester wrote:
>> *** OPA Tests on 0824Mon ***
>> Tests Summary
>> ****FAILED linew: runtest command failed ****
>> ****FAILED linew: standard****
>> PASSED colonelk: standard
>> PASSED duty: standard
>> PASSED jam: standard
>> PASSED liberty: standard
>> PASSED smirom: standard
>> Tests Time Summary
>> linew: Ran 1(0/1/0) tests, Grand total test time = 0m 33s
>> jam: Ran 1(1/0/0) tests, Grand total test time = 0m 49s
>> smirom: Ran 1(1/0/0) tests, Grand total test time = 0m 59s
>> liberty: Ran 1(1/0/0) tests, Grand total test time = 0m 55s
>> colonelk: Ran 1(1/0/0) tests, Grand total test time = 1m 31s
>> duty: Ran 1(1/0/0) tests, Grand total test time = 2m 6s
>> jam: Ran 6(0/0/0) hosts, Grand total test time = 3m 4s
>> Timekeeper log
>> Timekeeper started at Mon Aug 24 06:01:31 CDT 2009
>> Timekeeper sleeping for 1800 seconds
>> Tests Failures
>> Dumping logfile of linew: standard
>> Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/
>> linew_0824Mon_0601
>> gmake[1]: warning: -jN forced in submake: disabling jobserver mode.
>> gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/
>> linew/src'
>> Making check in test
>> gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/
>> linew/test'
>> gmake -j 2 sanity test_primitives test_barriers
>> gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/
>> linew/test'
>> gmake[2]: warning: -jN forced in submake: disabling jobserver mode.
>> gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -
>> I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT
>> sanity.o -MD -MP -MF .deps/sanity.Tpo -c -o sanity.o /home/hdftest/
>> snapshots-opa/current/test/sanity.c
>> test_primitives.o -MD -MP -MF .deps/test_primitives.Tpo -c -o
>> test_primitives.o /home/hdftest/snapshots-opa/current/test/
>> test_primitives.c
>> mv -f .deps/sanity.Tpo .deps/sanity.Po
>> test_barriers.o -MD -MP -MF .deps/test_barriers.Tpo -c -o
>> test_barriers.o /home/hdftest/snapshots-opa/current/test/
>> test_barriers.c
>> mv -f .deps/test_barriers.Tpo .deps/test_barriers.Po
>> gcc -g -O2 -o sanity sanity.o ../src/libopa.a -lpthread
>> gcc -g -O2 -o test_barriers test_barriers.o ../src/libopa.a -
>> lpthread
>> mv -f .deps/test_primitives.Tpo .deps/test_primitives.Po
>> gcc -g -O2 -o test_primitives test_primitives.o ../src/libopa.a -
>> lpthread
>> Undefined first referenced
>> symbol in file
>> pthread_yield test_primitives.o
>> ld: fatal: Symbol referencing errors. No output written to
>> test_primitives
>> collect2: ld returned 1 exit status
>> gmake[2]: *** [test_primitives] Error 1
>> gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/
>> linew/test'
>> gmake[1]: *** [check-am] Error 2
>> linew/test'
>> gmake: *** [check-recursive] Error 1
>> Failed running make check
>> ===== Exit bin/snapshot with status=0: Mon Aug 24 06:02:18 CDT 2009
>> Dumping done
>> Watchers List
>> OPA Daily test features/platforms watchers and procedure
>> Procedure:
>> The watcher will investigate and report the cause of failure by 11am.
>> The developer who checked in the error code may report so by then
>> too.
>> The watcher or the developer should get the failure fixed and
>> report it
>> by 3pm.
>> Watcher for OPA: Neil
>> updated: 2009/05/05
>> Tests Details
>> Testing all hosts.
>> opa
>> 06:01:17 up 52 days, 21:25, 16 users, load average: 0.00, 0.00, 0.09
>> Filesystem 1K-blocks Used Available Use% Mounted on
>> /dev/sda3 31738420 3076808 27023384 11% /
>> /dev/sda1 101086 50879 44988 54% /boot
>> /dev/sda2 31738420 277972 29822220 1% /tmp
>> /dev/sda6 31738392 3779520 26320648 13% /var
>> /dev/sda7 31738392 14147728 15952440 48% /usr
>> /dev/sda8 124991068 14128420 104410948 12% /var/tmp
>> /dev/mapper/VolGroup00-home
>> 198351840 11678972 176434508 7% /home
>> /dev/sde1 565688764 28015584 508474244 6% /scr
>> /dev/sdc1 961432072 446910716 465683356 49% /mnt/scr1
>> /dev/sdd1 961432072 229095448 683498624 26% /mnt/hdf
>> tmpfs 1551408 0 1551408 0% /dev/shm
>> gumund:/data/ftp 480719072 178995072 277304800 40% /mnt/ftp
>> gumund:/data/web 480719072 178995072 277304800 40% /mnt/web
>> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
>> TEST_TYPES=standard
>> FTP flag is
>> Running CVS checkout with output saved in
>> /mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0824Mon
>> Checking MANIFEST file ...
>> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0824Mon.24480:
>> No such file or directory
>> rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.
>> 0824Mon.24480': No such file or directory
>> Mon Aug 24 06:01:30 CDT 2009
>> *** launching tests from jam ***
>> TESTHOST is linew
>> jam
>> smirom
>> colonelk
>> duty
>> liberty
>> Fork off timekeeper 30
>> Testing linew
>> ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
>> snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
>> Using configname option for -configname
>> opa
>> 6:01am up 4 day(s), 18 hr(s), 7 users, load average: 0.52, 1.01,
>> 1.08
>> / (/dev/dsk/c1t0d0s0 ):53286352 blocks 8032055
>> files
>> /devices (/devices ): 0 blocks 0
>> files
>> /system/contract (ctfs ): 0 blocks 2147483607
>> files
>> /proc (proc ): 0 blocks 29922
>> files
>> /etc/mnttab (mnttab ): 0 blocks 0
>> files
>> /etc/svc/volatile (swap ):16850944 blocks 1182899
>> files
>> /system/object (objfs ): 0 blocks 2147483484
>> files
>> /etc/dfs/sharetab (sharefs ): 0 blocks 2147483646
>> files
>> /platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/
>> libc_psr/libc_psr_hwcap1.so.1):53286352 blocks 8032055 files
>> /platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/
>> lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):53286352 blocks 8032055
>> files
>> /dev/fd (fd ): 0 blocks 0
>> files
>> /tmp (swap ):16850944 blocks 1182899
>> files
>> /var/run (swap ):16850944 blocks 1182899
>> files
>> /home (jam:/home ):373345736 blocks 51006775
>> files
>> /mnt/hdf (jam:/mnt/hdf ):1464673248 blocks 118079083
>> files
>> /mnt/scr1 (jam:/mnt/scr1 ):1029042664 blocks 117865286
>> files
>> /mnt/web (gumund:/mnt/web ):603447984 blocks 60659265
>> files
>> /mnt/ftp (gumund:/mnt/ftp ):603447984 blocks 60659265
>> files
>> TEST_TYPES=standard
>> Running standard
>> Mon Aug 24 06:01:46 CDT 2009
>> *** starting standard tests in linew ***
>> Uname -a: SunOS linew 5.10 Generic_141414-08 sun4u sparc SUNW,A70
>> /mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
>> SRCDIRNAME is linew
>> Running snapshot with output saved in
>> /mnt/scr1/SnapTest/snapshots-opa/log/linew_0824Mon_0601
>> SNAPCMD is srcdir test clean
>> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/
>> include,/usr/lib srcdirname linew
>> *** finished standard tests for linew ***
>> Total time = 0m 32s
>> *** finished tests in linew ***
>> ****FAILED linew: Abnormal exit from runtest ****
>> Mon Aug 24 06:04:31 CDT 2009
>> Testing jam
>> ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
>> snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
>> opa
>> 06:01:37 up 52 days, 21:25, 16 users, load average: 0.00, 0.00, 0.09
>> /dev/sda2 31738420 277976 29822216 1% /tmp
>> /dev/sdc1 961432072 446910748 465683324 49% /mnt/scr1
>> TEST_TYPES=standard
>> Running standard
>> Mon Aug 24 06:01:47 CDT 2009
>> *** starting standard tests in jam ***
>> Uname -a: Linux jam 2.6.18-128.1.16.el5 #1 SMP Tue Jun 30 06:10:28
>> EDT 2009 i686 i686 i386 GNU/Linux
>> SRCDIRNAME is jam
>> /mnt/scr1/SnapTest/snapshots-opa/log/jam_0824Mon_0601
>> include,/usr/lib srcdirname jam
>> *** finished standard tests for jam ***
>> Mon Aug 24 06:02:36 CDT 2009
>> Total time = 0m 49s
>> *** finished tests in jam ***
>> Testing smirom
>> ssh smirom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
>> snapshots-opa/bin/runtest -nodiff -nocvs -configname smirom
>> opa
>> 6:01am up 3 days 13:54, 4 users, load average: 0.01, 0.01, 0.11
>> /dev/hdb1 76920416 10081264 62931744 14% /
>> udev 1991252 116 1991136 1% /dev
>> /dev/sda2 129736964 31028332 98708632 24% /scr
>> /dev/sdb1 76920416 29621208 43391800 41% /usr
>> jam:/home 198351840 11678944 176434528 7% /home
>> jam:/mnt/hdf 961432096 229095456 683498624 26% /mnt/hdf
>> jam:/mnt/scr1 961432096 446910784 465683328 49% /mnt/scr1
>> TEST_TYPES=standard
>> Running standard
>> Mon Aug 24 06:01:53 CDT 2009
>> *** starting standard tests in smirom ***
>> Uname -a: Linux smirom 2.6.16.60-0.34-smp #1 SMP Fri Jan 16
>> 14:59:01 UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
>> SRCDIRNAME is smirom
>> /mnt/scr1/SnapTest/snapshots-opa/log/smirom_0824Mon_0601
>> include,/usr/lib srcdirname smirom
>> *** finished standard tests for smirom ***
>> Mon Aug 24 06:02:52 CDT 2009
>> Total time = 0m 59s
>> *** finished tests in smirom ***
>> Testing colonelk
>> ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
>> snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
>> opa
>> 06:01:42 up 5 days, 16:56, 0 users, load average: 0.00, 0.00, 0.00
>> /dev/hda3 29753588 3608728 24609048 13% /
>> /dev/hda2 49961020 2445196 44936992 6% /tmp
>> /dev/hda6 9920592 673524 8735000 8% /var
>> /dev/hda5 19840892 10006060 8810692 54% /scr
>> /dev/hda1 101086 33315 62552 35% /boot
>> tmpfs 517644 0 517644 0% /dev/shm
>> TEST_TYPES=standard
>> Running standard
>> Mon Aug 24 06:01:52 CDT 2009
>> *** starting standard tests in colonelk ***
>> Uname -a: Linux colonelk 2.6.18-128.4.1.el5 #1 SMP Tue Aug 4
>> 20:23:34 EDT 2009 i686 i686 i386 GNU/Linux
>> SRCDIRNAME is colonelk
>> /mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0824Mon_0601
>> include,/usr/lib srcdirname colonelk
>> *** finished standard tests for colonelk ***
>> Mon Aug 24 06:03:23 CDT 2009
>> Total time = 1m 31s
>> *** finished tests in colonelk ***
>> Testing duty
>> ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
>> snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
>> opa
>> 6:01AM up 89 days, 17:57, 0 users, load averages: 0.00, 0.00, 0.00
>> Filesystem 1K-blocks Used Avail Capacity Mounted on
>> /dev/aacd0s1a 507630 60994 406026 13% /
>> devfs 1 1 0 100% /dev
>> /dev/aacd0s1h 188433016 120649098 52709278 70% /data
>> /dev/aacd0s1g 32494668 23018730 6876366 77% /local_home
>> /dev/aacd0s1f 12186190 2770778 8440518 25% /usr
>> /dev/aacd0s1d 507630 46158 420862 10% /var
>> /dev/aacd0s1e 253678 334 233050 0% /var/tmp
>> procfs 4 4 0 100% /proc
>> jam:/home 198351840 11678972 176434508 6% /home
>> jam:/mnt/scr1 961432072 446910772 465683300 49% /mnt/scr1
>> gumund:/data/web 480719056 178995064 277304792 39% /mnt/web
>> gumund:/data/ftp 480719056 178995064 277304792 39% /mnt/ftp
>> devfs 1 1 0 100% /var/named/
>> dev
>> /dev/md0 126702 46 116520 0% /tmp
>> jam:/mnt/hdf 961432072 229095448 683498624 25% /mnt/hdf
>> TEST_TYPES=standard
>> Running standard
>> Mon Aug 24 06:01:55 CDT 2009
>> *** starting standard tests in duty ***
>> Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-
>> STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu
>> :/usr/obj/usr/src/sys/DUTY i386
>> SRCDIRNAME is duty
>> /mnt/scr1/SnapTest/snapshots-opa/log/duty_0824Mon_0601
>> include,/usr/lib srcdirname duty
>> *** finished standard tests for duty ***
>> Mon Aug 24 06:04:01 CDT 2009
>> Total time = 2m 6s
>> *** finished tests in duty ***
>> Testing liberty
>> ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
>> snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
>> opa
>> 6:01AM up 89 days, 17:59, 9 users, load averages: 0.00, 0.00, 0.00
>> /dev/aacd0s1a 507630 86918 380102 19% /
>> /dev/aacd0s1g 47047830 20595098 22688906 48% /local_home
>> /dev/aacd0s1f 12186190 4133002 7078294 37% /usr
>> /dev/aacd0s1d 1012974 99016 832922 11% /var
>> /dev/aacd0s1e 507630 336490 130530 72% /var/tmp
>> jam:/mnt/scr1 961432072 446910780 465683292 49% /mnt/scr1
>> dev
>> /dev/md0 126702 54 116512 0% /tmp
>> TEST_TYPES=standard
>> Running standard
>> Mon Aug 24 06:01:57 CDT 2009
>> *** starting standard tests in liberty ***
>> Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-
>> STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu
>> :/usr/obj/usr/src/sys/LIBERTY amd64
>> SRCDIRNAME is liberty
>> /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0824Mon_0601
>> include,/usr/lib srcdirname liberty
>> *** finished standard tests for liberty ***
>> Total time = 0m 55s
>> *** finished tests in liberty ***
>> opa-nightly-tests mailing list
>> opa-nightly-tests at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests
