[opa-nightly-tests] jam OPA_Daily_Tests_0824Mon_FAILED!!!
Dave Goodell goodell at mcs.anl.gov
Mon Aug 24 08:09:15 CDT 2009
It looks like we need a configure test for pthread_yield, since it
doesn't seem to be supported on SunOS 5.x.
-Dave
On Aug 24, 2009, at 6:04 AM, HDF Tester wrote:
> *** OPA Tests on 0824Mon ***
>   Tests Summary
> ****FAILED linew: runtest command failed ****
> ****FAILED linew: standard****
> PASSED colonelk: standard
> PASSED duty: standard
> PASSED jam: standard
> PASSED liberty: standard
> PASSED smirom: standard
>   Tests Time Summary
> linew: Ran 1(0/1/0) tests, Grand total test time =  0m 33s
> jam: Ran 1(1/0/0) tests, Grand total test time =  0m 49s
> smirom: Ran 1(1/0/0) tests, Grand total test time =  0m 59s
> liberty: Ran 1(1/0/0) tests, Grand total test time =  0m 55s
> colonelk: Ran 1(1/0/0) tests, Grand total test time =  1m 31s
> duty: Ran 1(1/0/0) tests, Grand total test time =  2m 6s
> jam: Ran 6(0/0/0) hosts, Grand total test time =  3m 4s
>   Timekeeper log
> Timekeeper started at Mon Aug 24 06:01:31 CDT 2009
> Timekeeper sleeping for 1800 seconds
>   Tests Failures
> Dumping logfile of linew: standard
> Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/
> linew_0824Mon_0601
> gmake[1]: warning: -jN forced in submake: disabling jobserver mode.
> gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/
> linew/src'
> Making check in test
> gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/
> linew/test'
> gmake -j 2  sanity test_primitives test_barriers
> gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/
> linew/test'
> gmake[2]: warning: -jN forced in submake: disabling jobserver mode.
> gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -
> I../src  -I/home/hdftest/snapshots-opa/current/src   -g -O2 -MT
> sanity.o -MD -MP -MF .deps/sanity.Tpo -c -o sanity.o /home/hdftest/
> snapshots-opa/current/test/sanity.c
> test_primitives.o -MD -MP -MF .deps/test_primitives.Tpo -c -o
> test_primitives.o /home/hdftest/snapshots-opa/current/test/
> test_primitives.c
> mv -f .deps/sanity.Tpo .deps/sanity.Po
> test_barriers.o -MD -MP -MF .deps/test_barriers.Tpo -c -o
> test_barriers.o /home/hdftest/snapshots-opa/current/test/
> test_barriers.c
> mv -f .deps/test_barriers.Tpo .deps/test_barriers.Po
> gcc  -g -O2   -o sanity sanity.o ../src/libopa.a -lpthread
> gcc  -g -O2   -o test_barriers test_barriers.o ../src/libopa.a -
> lpthread
> mv -f .deps/test_primitives.Tpo .deps/test_primitives.Po
> gcc  -g -O2   -o test_primitives test_primitives.o ../src/libopa.a -
> lpthread
> Undefined			first referenced
> symbol  			    in file
> pthread_yield                       test_primitives.o
> ld: fatal: Symbol referencing errors. No output written to
> test_primitives
> collect2: ld returned 1 exit status
> gmake[2]: *** [test_primitives] Error 1
> gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/
> linew/test'
> gmake[1]: *** [check-am] Error 2
> linew/test'
> gmake: *** [check-recursive] Error 1
> Failed running make check
> ===== Exit bin/snapshot with status=0: Mon Aug 24 06:02:18 CDT 2009
> Dumping done
>   Watchers List
> OPA Daily test features/platforms watchers and procedure
> Procedure:
> The watcher will investigate and report the cause of failure by 11am.
> The developer who checked in the error code may report so by then too.
> The watcher or the developer should get the failure fixed and report
> it
> by 3pm.
> Watcher for OPA:	 	Neil
> updated: 2009/05/05
>   Tests Details
> Testing all hosts.
> opa
> 06:01:17 up 52 days, 21:25, 16 users,  load average: 0.00, 0.00, 0.09
> Filesystem           1K-blocks      Used Available Use% Mounted on
> /dev/sda3             31738420   3076808  27023384  11% /
> /dev/sda1               101086     50879     44988  54% /boot
> /dev/sda2             31738420    277972  29822220   1% /tmp
> /dev/sda6             31738392   3779520  26320648  13% /var
> /dev/sda7             31738392  14147728  15952440  48% /usr
> /dev/sda8            124991068  14128420 104410948  12% /var/tmp
> /dev/mapper/VolGroup00-home
>                     198351840  11678972 176434508   7% /home
> /dev/sde1            565688764  28015584 508474244   6% /scr
> /dev/sdc1            961432072 446910716 465683356  49% /mnt/scr1
> /dev/sdd1            961432072 229095448 683498624  26% /mnt/hdf
> tmpfs                  1551408         0   1551408   0% /dev/shm
> gumund:/data/ftp     480719072 178995072 277304800  40% /mnt/ftp
> gumund:/data/web     480719072 178995072 277304800  40% /mnt/web
> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
> TEST_TYPES=standard
> FTP flag is
> Running CVS checkout with output saved in
>   /mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0824Mon
> Checking MANIFEST file ...
> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0824Mon.24480: No
> such file or directory
> rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.
> 0824Mon.24480': No such file or directory
> Mon Aug 24 06:01:30 CDT 2009
> *** launching tests from jam ***
> TESTHOST is linew
> jam
> smirom
> colonelk
> duty
> liberty
>    Fork off timekeeper 30
> Testing linew
> ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
> snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
> Using configname option for -configname
> opa
>  6:01am  up 4 day(s), 18 hr(s),  7 users,  load average: 0.52, 1.01,
> 1.08
> /                  (/dev/dsk/c1t0d0s0 ):53286352 blocks  8032055 files
> /devices           (/devices          ):       0 blocks        0 files
> /system/contract   (ctfs              ):       0 blocks 2147483607
> files
> /proc              (proc              ):       0 blocks    29922 files
> /etc/mnttab        (mnttab            ):       0 blocks        0 files
> /etc/svc/volatile  (swap              ):16850944 blocks  1182899 files
> /system/object     (objfs             ):       0 blocks 2147483484
> files
> /etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646
> files
> /platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/
> libc_psr/libc_psr_hwcap1.so.1):53286352 blocks  8032055 files
> /platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/
> lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):53286352 blocks  8032055
> files
> /dev/fd            (fd                ):       0 blocks        0 files
> /tmp               (swap              ):16850944 blocks  1182899 files
> /var/run           (swap              ):16850944 blocks  1182899 files
> /home              (jam:/home         ):373345736 blocks 51006775
> files
> /mnt/hdf           (jam:/mnt/hdf      ):1464673248 blocks 118079083
> files
> /mnt/scr1          (jam:/mnt/scr1     ):1029042664 blocks 117865286
> files
> /mnt/web           (gumund:/mnt/web   ):603447984 blocks 60659265
> files
> /mnt/ftp           (gumund:/mnt/ftp   ):603447984 blocks 60659265
> files
> TEST_TYPES=standard
> Running standard
> Mon Aug 24 06:01:46 CDT 2009
> *** starting standard tests in linew ***
> Uname -a: SunOS linew 5.10 Generic_141414-08 sun4u sparc SUNW,A70
> /mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
> SRCDIRNAME is linew
> Running snapshot with output saved in
>   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0824Mon_0601
> SNAPCMD is srcdir test clean
> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/
> include,/usr/lib srcdirname linew
> *** finished standard tests for linew ***
> Total time = 0m 32s
> *** finished tests in linew ***
> ****FAILED linew: Abnormal exit from runtest ****
> 	Mon Aug 24 06:04:31 CDT 2009
> Testing jam
> ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
> snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
> opa
> 06:01:37 up 52 days, 21:25, 16 users,  load average: 0.00, 0.00, 0.09
> /dev/sda2             31738420    277976  29822216   1% /tmp
> /dev/sdc1            961432072 446910748 465683324  49% /mnt/scr1
> TEST_TYPES=standard
> Running standard
> Mon Aug 24 06:01:47 CDT 2009
> *** starting standard tests in jam ***
> Uname -a: Linux jam 2.6.18-128.1.16.el5 #1 SMP Tue Jun 30 06:10:28
> EDT 2009 i686 i686 i386 GNU/Linux
> SRCDIRNAME is jam
>   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0824Mon_0601
> include,/usr/lib srcdirname jam
> *** finished standard tests for jam ***
> Mon Aug 24 06:02:36 CDT 2009
> Total time = 0m 49s
> *** finished tests in jam ***
> Testing smirom
> ssh smirom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
> snapshots-opa/bin/runtest -nodiff -nocvs -configname smirom
> opa
>  6:01am  up 3 days 13:54,  4 users,  load average: 0.01, 0.01, 0.11
> /dev/hdb1             76920416  10081264  62931744  14% /
> udev                   1991252       116   1991136   1% /dev
> /dev/sda2            129736964  31028332  98708632  24% /scr
> /dev/sdb1             76920416  29621208  43391800  41% /usr
> jam:/home            198351840  11678944 176434528   7% /home
> jam:/mnt/hdf         961432096 229095456 683498624  26% /mnt/hdf
> jam:/mnt/scr1        961432096 446910784 465683328  49% /mnt/scr1
> TEST_TYPES=standard
> Running standard
> Mon Aug 24 06:01:53 CDT 2009
> *** starting standard tests in smirom ***
> Uname -a: Linux smirom 2.6.16.60-0.34-smp #1 SMP Fri Jan 16 14:59:01
> UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
> SRCDIRNAME is smirom
>   /mnt/scr1/SnapTest/snapshots-opa/log/smirom_0824Mon_0601
> include,/usr/lib srcdirname smirom
> *** finished standard tests for smirom ***
> Mon Aug 24 06:02:52 CDT 2009
> Total time = 0m 59s
> *** finished tests in smirom ***
> Testing colonelk
> ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
> snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
> opa
> 06:01:42 up 5 days, 16:56,  0 users,  load average: 0.00, 0.00, 0.00
> /dev/hda3             29753588   3608728  24609048  13% /
> /dev/hda2             49961020   2445196  44936992   6% /tmp
> /dev/hda6              9920592    673524   8735000   8% /var
> /dev/hda5             19840892  10006060   8810692  54% /scr
> /dev/hda1               101086     33315     62552  35% /boot
> tmpfs                   517644         0    517644   0% /dev/shm
> TEST_TYPES=standard
> Running standard
> Mon Aug 24 06:01:52 CDT 2009
> *** starting standard tests in colonelk ***
> Uname -a: Linux colonelk 2.6.18-128.4.1.el5 #1 SMP Tue Aug 4
> 20:23:34 EDT 2009 i686 i686 i386 GNU/Linux
> SRCDIRNAME is colonelk
>   /mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0824Mon_0601
> include,/usr/lib srcdirname colonelk
> *** finished standard tests for colonelk ***
> Mon Aug 24 06:03:23 CDT 2009
> Total time = 1m 31s
> *** finished tests in colonelk ***
> Testing duty
> ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
> snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
> opa
> 6:01AM  up 89 days, 17:57, 0 users, load averages: 0.00, 0.00, 0.00
> Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
> /dev/aacd0s1a       507630     60994    406026    13%    /
> devfs                    1         1         0   100%    /dev
> /dev/aacd0s1h    188433016 120649098  52709278    70%    /data
> /dev/aacd0s1g     32494668  23018730   6876366    77%    /local_home
> /dev/aacd0s1f     12186190   2770778   8440518    25%    /usr
> /dev/aacd0s1d       507630     46158    420862    10%    /var
> /dev/aacd0s1e       253678       334    233050     0%    /var/tmp
> procfs                   4         4         0   100%    /proc
> jam:/home        198351840  11678972 176434508     6%    /home
> jam:/mnt/scr1    961432072 446910772 465683300    49%    /mnt/scr1
> gumund:/data/web 480719056 178995064 277304792    39%    /mnt/web
> gumund:/data/ftp 480719056 178995064 277304792    39%    /mnt/ftp
> devfs                    1         1         0   100%    /var/named/
> dev
> /dev/md0            126702        46    116520     0%    /tmp
> jam:/mnt/hdf     961432072 229095448 683498624    25%    /mnt/hdf
> TEST_TYPES=standard
> Running standard
> Mon Aug 24 06:01:55 CDT 2009
> *** starting standard tests in duty ***
> Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-
> STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu
> :/usr/obj/usr/src/sys/DUTY  i386
> SRCDIRNAME is duty
>   /mnt/scr1/SnapTest/snapshots-opa/log/duty_0824Mon_0601
> include,/usr/lib srcdirname duty
> *** finished standard tests for duty ***
> Mon Aug 24 06:04:01 CDT 2009
> Total time = 2m 6s
> *** finished tests in duty ***
> Testing liberty
> ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/
> snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
> opa
> 6:01AM  up 89 days, 17:59, 9 users, load averages: 0.00, 0.00, 0.00
> /dev/aacd0s1a       507630     86918    380102    19%    /
> /dev/aacd0s1g     47047830  20595098  22688906    48%    /local_home
> /dev/aacd0s1f     12186190   4133002   7078294    37%    /usr
> /dev/aacd0s1d      1012974     99016    832922    11%    /var
> /dev/aacd0s1e       507630    336490    130530    72%    /var/tmp
> jam:/mnt/scr1    961432072 446910780 465683292    49%    /mnt/scr1
> dev
> /dev/md0            126702        54    116512     0%    /tmp
> TEST_TYPES=standard
> Running standard
> Mon Aug 24 06:01:57 CDT 2009
> *** starting standard tests in liberty ***
> Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-
> STABLE #1: Fri Jul 25 17:21:46 CDT 2008     sukoziol at liberty.hdfgroup.uiuc.edu
> :/usr/obj/usr/src/sys/LIBERTY  amd64
> SRCDIRNAME is liberty
>   /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0824Mon_0601
> include,/usr/lib srcdirname liberty
> *** finished standard tests for liberty ***
> Total time = 0m 55s
> *** finished tests in liberty ***
> opa-nightly-tests mailing list
> opa-nightly-tests at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
