[opa-nightly-tests] jam OPA_Daily_Tests_0824Mon_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Mon Aug 24 06:04:31 CDT 2009
*** OPA Tests on 0824Mon ***
   Tests Summary
****FAILED linew: runtest command failed ****
****FAILED linew: standard****
PASSED colonelk: standard
PASSED duty: standard
PASSED jam: standard
PASSED liberty: standard
PASSED smirom: standard
   Tests Time Summary
linew: Ran 1(0/1/0) tests, Grand total test time =  0m 33s
jam: Ran 1(1/0/0) tests, Grand total test time =  0m 49s
smirom: Ran 1(1/0/0) tests, Grand total test time =  0m 59s
liberty: Ran 1(1/0/0) tests, Grand total test time =  0m 55s
colonelk: Ran 1(1/0/0) tests, Grand total test time =  1m 31s
duty: Ran 1(1/0/0) tests, Grand total test time =  2m 6s
jam: Ran 6(0/0/0) hosts, Grand total test time =  3m 4s
   Timekeeper log
Timekeeper started at Mon Aug 24 06:01:31 CDT 2009
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of linew: standard
Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/linew_0824Mon_0601
gmake[1]: warning: -jN forced in submake: disabling jobserver mode.
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/src'
Making check in test
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake -j 2  sanity test_primitives test_barriers
gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake[2]: warning: -jN forced in submake: disabling jobserver mode.
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src  -I/home/hdftest/snapshots-opa/current/src   -g -O2 -MT sanity.o -MD -MP -MF .deps/sanity.Tpo -c -o sanity.o /home/hdftest/snapshots-opa/current/test/sanity.c
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src  -I/home/hdftest/snapshots-opa/current/src   -g -O2 -MT test_primitives.o -MD -MP -MF .deps/test_primitives.Tpo -c -o test_primitives.o /home/hdftest/snapshots-opa/current/test/test_primitives.c
mv -f .deps/sanity.Tpo .deps/sanity.Po
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src  -I/home/hdftest/snapshots-opa/current/src   -g -O2 -MT test_barriers.o -MD -MP -MF .deps/test_barriers.Tpo -c -o test_barriers.o /home/hdftest/snapshots-opa/current/test/test_barriers.c
mv -f .deps/test_barriers.Tpo .deps/test_barriers.Po
gcc  -g -O2   -o sanity sanity.o ../src/libopa.a -lpthread
gcc  -g -O2   -o test_barriers test_barriers.o ../src/libopa.a -lpthread
mv -f .deps/test_primitives.Tpo .deps/test_primitives.Po
gcc  -g -O2   -o test_primitives test_primitives.o ../src/libopa.a -lpthread
Undefined			first referenced
 symbol  			    in file
pthread_yield                       test_primitives.o
ld: fatal: Symbol referencing errors. No output written to test_primitives
collect2: ld returned 1 exit status
gmake[2]: *** [test_primitives] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=0: Mon Aug 24 06:02:18 CDT 2009 =====
Dumping done
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 06:01:17 up 52 days, 21:25, 16 users,  load average: 0.00, 0.00, 0.09
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3076808  27023384  11% /
/dev/sda1               101086     50879     44988  54% /boot
/dev/sda2             31738420    277972  29822220   1% /tmp
/dev/sda6             31738392   3779520  26320648  13% /var
/dev/sda7             31738392  14147728  15952440  48% /usr
/dev/sda8            124991068  14128420 104410948  12% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  11678972 176434508   7% /home
/dev/sde1            565688764  28015584 508474244   6% /scr
/dev/sdc1            961432072 446910716 465683356  49% /mnt/scr1
/dev/sdd1            961432072 229095448 683498624  26% /mnt/hdf
tmpfs                  1551408         0   1551408   0% /dev/shm
gumund:/data/ftp     480719072 178995072 277304800  40% /mnt/ftp
gumund:/data/web     480719072 178995072 277304800  40% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
FTP flag is
Running CVS checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0824Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0824Mon.24480: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0824Mon.24480': No such file or directory
Mon Aug 24 06:01:30 CDT 2009
*** launching tests from jam ***
TESTHOST is linew
jam
smirom
colonelk
duty
liberty
    Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
Using configname option for -configname
opa
  6:01am  up 4 day(s), 18 hr(s),  7 users,  load average: 0.52, 1.01, 1.08
/                  (/dev/dsk/c1t0d0s0 ):53286352 blocks  8032055 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483607 files
/proc              (proc              ):       0 blocks    29922 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):16850944 blocks  1182899 files
/system/object     (objfs             ):       0 blocks 2147483484 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):53286352 blocks  8032055 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):53286352 blocks  8032055 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):16850944 blocks  1182899 files
/var/run           (swap              ):16850944 blocks  1182899 files
/home              (jam:/home         ):373345736 blocks 51006775 files
/mnt/hdf           (jam:/mnt/hdf      ):1464673248 blocks 118079083 files
/mnt/scr1          (jam:/mnt/scr1     ):1029042664 blocks 117865286 files
/mnt/web           (gumund:/mnt/web   ):603447984 blocks 60659265 files
/mnt/ftp           (gumund:/mnt/ftp   ):603447984 blocks 60659265 files
TEST_TYPES=standard
Running standard
Mon Aug 24 06:01:46 CDT 2009
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_141414-08 sun4u sparc SUNW,A70
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
SRCDIRNAME is linew
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname linew
*** finished standard tests for linew ***
Total time = 0m 32s
*** finished tests in linew ***
****FAILED linew: Abnormal exit from runtest ****
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
opa
 06:01:37 up 52 days, 21:25, 16 users,  load average: 0.00, 0.00, 0.09
/dev/sda2             31738420    277976  29822216   1% /tmp
/dev/sdc1            961432072 446910748 465683324  49% /mnt/scr1
TEST_TYPES=standard
Running standard
Mon Aug 24 06:01:47 CDT 2009
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-128.1.16.el5 #1 SMP Tue Jun 30 06:10:28 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is jam
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0824Mon_0601
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname jam
*** finished standard tests for jam ***
Mon Aug 24 06:02:36 CDT 2009
Total time = 0m 49s
*** finished tests in jam ***
Testing smirom
ssh smirom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname smirom
opa
  6:01am  up 3 days 13:54,  4 users,  load average: 0.01, 0.01, 0.11
/dev/hdb1             76920416  10081264  62931744  14% /
udev                   1991252       116   1991136   1% /dev
/dev/sda2            129736964  31028332  98708632  24% /scr
/dev/sdb1             76920416  29621208  43391800  41% /usr
jam:/home            198351840  11678944 176434528   7% /home
jam:/mnt/hdf         961432096 229095456 683498624  26% /mnt/hdf
jam:/mnt/scr1        961432096 446910784 465683328  49% /mnt/scr1
TEST_TYPES=standard
Running standard
Mon Aug 24 06:01:53 CDT 2009
*** starting standard tests in smirom ***
Uname -a: Linux smirom 2.6.16.60-0.34-smp #1 SMP Fri Jan 16 14:59:01 UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is smirom
   /mnt/scr1/SnapTest/snapshots-opa/log/smirom_0824Mon_0601
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname smirom
*** finished standard tests for smirom ***
Mon Aug 24 06:02:52 CDT 2009
Total time = 0m 59s
*** finished tests in smirom ***
Testing colonelk
ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
opa
 06:01:42 up 5 days, 16:56,  0 users,  load average: 0.00, 0.00, 0.00
/dev/hda3             29753588   3608728  24609048  13% /
/dev/hda2             49961020   2445196  44936992   6% /tmp
/dev/hda6              9920592    673524   8735000   8% /var
/dev/hda5             19840892  10006060   8810692  54% /scr
/dev/hda1               101086     33315     62552  35% /boot
tmpfs                   517644         0    517644   0% /dev/shm
TEST_TYPES=standard
Running standard
Mon Aug 24 06:01:52 CDT 2009
*** starting standard tests in colonelk ***
Uname -a: Linux colonelk 2.6.18-128.4.1.el5 #1 SMP Tue Aug 4 20:23:34 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is colonelk
   /mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0824Mon_0601
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname colonelk
*** finished standard tests for colonelk ***
Mon Aug 24 06:03:23 CDT 2009
Total time = 1m 31s
*** finished tests in colonelk ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
opa
 6:01AM  up 89 days, 17:57, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60994    406026    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 120649098  52709278    70%    /data
/dev/aacd0s1g     32494668  23018730   6876366    77%    /local_home
/dev/aacd0s1f     12186190   2770778   8440518    25%    /usr
/dev/aacd0s1d       507630     46158    420862    10%    /var
/dev/aacd0s1e       253678       334    233050     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  11678972 176434508     6%    /home
jam:/mnt/scr1    961432072 446910772 465683300    49%    /mnt/scr1
gumund:/data/web 480719056 178995064 277304792    39%    /mnt/web
gumund:/data/ftp 480719056 178995064 277304792    39%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702        46    116520     0%    /tmp
jam:/mnt/hdf     961432072 229095448 683498624    25%    /mnt/hdf
TEST_TYPES=standard
Running standard
Mon Aug 24 06:01:55 CDT 2009
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
SRCDIRNAME is duty
   /mnt/scr1/SnapTest/snapshots-opa/log/duty_0824Mon_0601
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname duty
*** finished standard tests for duty ***
Mon Aug 24 06:04:01 CDT 2009
Total time = 2m 6s
*** finished tests in duty ***
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
opa
 6:01AM  up 89 days, 17:59, 9 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a       507630     86918    380102    19%    /
/dev/aacd0s1g     47047830  20595098  22688906    48%    /local_home
/dev/aacd0s1f     12186190   4133002   7078294    37%    /usr
/dev/aacd0s1d      1012974     99016    832922    11%    /var
/dev/aacd0s1e       507630    336490    130530    72%    /var/tmp
jam:/mnt/scr1    961432072 446910780 465683292    49%    /mnt/scr1
/dev/md0            126702        54    116512     0%    /tmp
TEST_TYPES=standard
Running standard
Mon Aug 24 06:01:57 CDT 2009
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008     sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY  amd64
SRCDIRNAME is liberty
   /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0824Mon_0601
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname liberty
*** finished standard tests for liberty ***
Total time = 0m 55s
*** finished tests in liberty ***
More information about the opa-nightly-tests mailing list
