[Nek5000-users] Tripping mechanism
Mon Feb 26 10:20:43 CST 2018
Dear Philipp,
Thank you for your response. So if I understand correctly, first you generate a random signal as a function of Z and then use a low-pass filter to obtain h^i(z). Thinking about how to implement this in Nek5000, I guess one could impose random numbers at each node (collocation point) and then apply some kind of filter. Is this correct?
Also, could you please clarify what you mean by: make sure that you have the same random numbers for the whole spanwise extent? Since h(z) is a function of z, I'm not sure I understand this statement.
Thank you very much for you help.
Juan Diego Colmenares
PhD Candidate
Department of Mechanical Engineering
University of New Mexico
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180226/a86d44da/attachment.html>
