[Nek5000-users] Tripping mechanism
nek5000-users at lists.mcs.anl.gov
Mon Feb 26 11:39:35 CST 2018
Hi Juan Diego,
yes, first you create a random signal in Z with the appropriate spatial
characteristics (in our case a low-pass filtered signal, but this could
potentially be created in any other way). So the way you suggest should
be fine, however, you just need to make sure that you signal does not
depend on the mesh, i.e. give smaller scales close to element boundaries
for instance.
Regarding the second point. Essentially you just want to be able to
restart your simulation. If you use the Lagrange-interpolants p as
described in our paper, you would need to be able to re-create the same
two h(z) you had when you stopped the simulation. That's what I meant.
Best regards,
Philipp
On 2018-02-26 17:20, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Philipp,
> Thank you for your response. So if I understand correctly, first you
> generate a random signal as a function of Z and then use a low-pass
> filter to obtain h^i(z). Thinking about how to implement this in
> Nek5000, I guess one could impose random numbers at each node
> (collocation point) and then apply some kind of filter. Is this correct?
> Also, could you please clarify what you mean by: make sure that you have
> the same random numbers for the whole spanwise extent? Since h(z) is a
> function of z, I'm not sure I understand this statement.
> Thank you very much for you help.
> Juan Diego Colmenares
> PhD Candidate
> Department of Mechanical Engineering
> University of New Mexico
> Nek5000-users mailing list
More information about the Nek5000-users
