[mpich2-dev] Simplemake is not available
Dave Goodell
goodell at mcs.anl.gov
Fri Feb 3 12:40:17 CST 2012
I'll work on fixing this for you as soon as I can. The test/mpi/configure.in script has needed work for a while now and I had been putting it off because I was a bit burned out by the build system.
In the short run, can you just run the top level "./maint/updatefiles" instead? It should run all of the autotools appropriately for the "test/mpi" directory.
-Dave
On Feb 3, 2012, at 11:03 AM CST, Jeff Hammond wrote:
> Did I do something wrong or is this expected? I don't object to
> following the directions about copying simplemake.in to simplemake,
> but I don't want to blindly do this is the error is indicative of some
> larger issue.
> Thanks,
> Jeff
> jeff at megatron:~/eclipse/MPICH2> ./test/mpi/maint/updatefiles
> You have autoconf version 2.62.
> checking for perl... /usr/bin/perl
> configure: creating ./config.status
> config.status: creating simplemake
> config.status: creating checkbuilds
> config.status: creating getcoverage
> config.status: creating genstates
> config.status: creating clmake
> config.status: creating f77tof90
> config.status: creating extractstrings
> config.status: creating extractstates
> config.status: creating extractfixme
> config.status: creating createcoverage
> config.status: creating gcovmerge
> config.status: executing default-1 commands
> You can copy simplemake.in to simplemake, replacing @PERL@ with the
> path to Perl (version5). Make sure the resulting file has
> execute permissions set.
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute
> jhammond at alcf.anl.gov / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
> https://wiki.alcf.anl.gov/old/index.php/User:Jhammond
More information about the mpich2-dev
