[mpich2-dev] Simplemake is not available
Jeff Hammond jhammond at alcf.anl.gov
Fri Feb 3 13:13:50 CST 2012
I am an idiot for using ./test/mpi/maint/updatefiles instead of
./maint/updatefiles.  Sorry for not noticing this before.
Jeff
On Fri, Feb 3, 2012 at 12:40 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> I'll work on fixing this for you as soon as I can.  The test/mpi/configure.in script has needed work for a while now and I had been putting it off because I was a bit burned out by the build system.
> In the short run, can you just run the top level "./maint/updatefiles" instead?  It should run all of the autotools appropriately for the "test/mpi" directory.
> -Dave
> On Feb 3, 2012, at 11:03 AM CST, Jeff Hammond wrote:
>> Did I do something wrong or is this expected?  I don't object to
>> following the directions about copying simplemake.in to simplemake,
>> but I don't want to blindly do this is the error is indicative of some
>> larger issue.
>> Thanks,
>> Jeff
>> jeff at megatron:~/eclipse/MPICH2> ./test/mpi/maint/updatefiles
>> You have autoconf version 2.62.
>> checking for perl... /usr/bin/perl
>> configure: creating ./config.status
>> config.status: creating simplemake
>> config.status: creating checkbuilds
>> config.status: creating getcoverage
>> config.status: creating genstates
>> config.status: creating clmake
>> config.status: creating f77tof90
>> config.status: creating extractstrings
>> config.status: creating extractstates
>> config.status: creating extractfixme
>> config.status: creating createcoverage
>> config.status: creating gcovmerge
>> config.status: executing default-1 commands
>> You can copy simplemake.in to simplemake, replacing @PERL@ with the
>> path to Perl (version5).  Make sure the resulting file has
>> execute permissions set.
>> Jeff Hammond
>> Argonne Leadership Computing Facility
>> University of Chicago Computation Institute
>> jhammond at alcf.anl.gov / (630) 252-5381
>> http://www.linkedin.com/in/jeffhammond
>> https://wiki.alcf.anl.gov/old/index.php/User:Jhammond
Jeff Hammond
More information about the mpich2-dev mailing list
