[mpich2-dev] Simplemake is not available
Jeff Hammond jhammond at alcf.anl.gov
Fri Feb 3 11:03:26 CST 2012
Did I do something wrong or is this expected?  I don't object to
following the directions about copying simplemake.in to simplemake,
but I don't want to blindly do this is the error is indicative of some
larger issue.
Jeff
jeff at megatron:~/eclipse/MPICH2> ./test/mpi/maint/updatefiles
You have autoconf version 2.62.
checking for perl... /usr/bin/perl
configure: creating ./config.status
config.status: creating simplemake
config.status: creating checkbuilds
config.status: creating getcoverage
config.status: creating genstates
config.status: creating clmake
config.status: creating f77tof90
config.status: creating extractstrings
config.status: creating extractstates
config.status: creating extractfixme
config.status: creating createcoverage
config.status: creating gcovmerge
config.status: executing default-1 commands
You can copy simplemake.in to simplemake, replacing @PERL@ with the
path to Perl (version5).  Make sure the resulting file has
execute permissions set.
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki.alcf.anl.gov/old/index.php/User:Jhammond
More information about the mpich2-dev mailing list
