[mpich2-dev] MPICH2 BGQ src/mpix/armci autoconf fails
Jeff Hammond
jhammond at alcf.anl.gov
Thu Aug 16 17:30:47 CDT 2012
I am having a deja vu feeling about this, but can someone help me
solve this. This is the BGQ V1R1M1 version of MPICH2.
In the worst case I will just delete armci and build it externally.
Jeff
running third-party initialization in src/mpix/armci
autoreconf: Entering directory `.'
autoreconf: configure.ac: not using Gettext
autoreconf: running: aclocal --force -I m4
autoreconf: configure.ac: tracing
autoreconf: running: libtoolize --copy --force
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `m4'.
libtoolize: copying file `m4/ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `m4'.
libtoolize: copying file `m4/libtool.m4'
libtoolize: copying file `m4/ltoptions.m4'
libtoolize: copying file `m4/ltsugar.m4'
libtoolize: copying file `m4/ltversion.m4'
libtoolize: copying file `m4/lt~obsolete.m4'
autoreconf: running: /home/jhammond/TOOLS/24may2012/bin/autoconf --force
autoreconf: running: /home/jhammond/TOOLS/24may2012/bin/autoheader --force
autoreconf: running: automake --add-missing --copy --force-missing
configure.ac:21: installing 'm4/config.guess'
configure.ac:21: installing 'm4/config.sub'
configure.ac:10: installing 'm4/install-sh'
configure.ac:10: installing 'm4/missing'
automake: warnings are treated as errors
/home/jhammond/TOOLS/24may2012/share/automake-1.12/am/ltlibrary.am:
warning: 'libarmci.la': linking libtool libraries using a non-POSIX
archiver requires 'AM_PROG_AR' in 'configure.ac'
Makefile.am:8: while processing Libtool library 'libarmci.la'
warning: 'libarmcii.la': linking libtool libraries using a non-POSIX
Makefile.am:9: while processing Libtool library 'libarmcii.la'
Makefile.am: installing 'm4/depcomp'
configure.ac:10: installing 'm4/test-driver'
autoreconf: automake failed with exit status: 1
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
More information about the mpich2-dev
