[mpich2-dev] MPICH2 BGQ src/mpix/armci autoconf fails
Anthony Chan chan at mcs.anl.gov
Thu Aug 16 19:25:37 CDT 2012
See http://trac.mcs.anl.gov/projects/mpich2/changeset/9911/mpich2/trunk/src/mpix/armci/configure.ac
You are using automake 1.12, try either downgrading it to 1.11 or
add the m4 ifdef in armci's configure.ac.
PS.  I suppose you ain't using autoreconf directly or maint/updatefiles.
Does BGQ's mpich2 come with a build script ?
----- Original Message -----
> I am having a deja vu feeling about this, but can someone help me
> solve this. This is the BGQ V1R1M1 version of MPICH2.
> In the worst case I will just delete armci and build it externally.
> Thanks,
> Jeff
> running third-party initialization in src/mpix/armci
> autoreconf: Entering directory `.'
> autoreconf: configure.ac: not using Gettext
> autoreconf: running: aclocal --force -I m4
> autoreconf: configure.ac: tracing
> autoreconf: running: libtoolize --copy --force
> libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `m4'.
> libtoolize: copying file `m4/ltmain.sh'
> libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `m4'.
> libtoolize: copying file `m4/libtool.m4'
> libtoolize: copying file `m4/ltoptions.m4'
> libtoolize: copying file `m4/ltsugar.m4'
> libtoolize: copying file `m4/ltversion.m4'
> libtoolize: copying file `m4/lt~obsolete.m4'
> autoreconf: running: /home/jhammond/TOOLS/24may2012/bin/autoconf
> --force
> autoreconf: running: /home/jhammond/TOOLS/24may2012/bin/autoheader
> --force
> autoreconf: running: automake --add-missing --copy --force-missing
> configure.ac:21: installing 'm4/config.guess'
> configure.ac:21: installing 'm4/config.sub'
> configure.ac:10: installing 'm4/install-sh'
> configure.ac:10: installing 'm4/missing'
> automake: warnings are treated as errors
> /home/jhammond/TOOLS/24may2012/share/automake-1.12/am/ltlibrary.am:
> warning: 'libarmci.la': linking libtool libraries using a non-POSIX
> archiver requires 'AM_PROG_AR' in 'configure.ac'
> Makefile.am:8: while processing Libtool library 'libarmci.la'
> warning: 'libarmcii.la': linking libtool libraries using a non-POSIX
> Makefile.am:9: while processing Libtool library 'libarmcii.la'
> Makefile.am: installing 'm4/depcomp'
> configure.ac:10: installing 'm4/test-driver'
> autoreconf: automake failed with exit status: 1
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute
> jhammond at alcf.anl.gov / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
More information about the mpich2-dev mailing list
