[mpich2-dev] mpix/armci libtool configuration
Justin M Wozniak wozniak at mcs.anl.gov
Tue Jun 14 15:42:32 CDT 2011
I use maint/updatefiles.  I went back to r8600 to get things going
again...
On Tue, 14 Jun 2011, Anthony Chan wrote:
> Are you using maint/updatefiles to build configure or using autoreconf directly ?
>> Hello
>> After a recent update, I get:
>> autoreconf: configure.ac: not using Libtool
>> autoreconf: running: /homes/wozniak/sfw/autoconf-2.68/bin/autoconf
>> --force
>> autoreconf: running: /homes/wozniak/sfw/autoconf-2.68/bin/autoheader
>> --force
>> autoreconf: running: automake --add-missing --copy --force-missing
>> Makefile.am:8: Libtool library used but `LIBTOOL' is undefined
>> Makefile.am:8: The usual way to define `LIBTOOL' is to add
>> `AC_PROG_LIBTOOL'
>> Makefile.am:8: to `configure.ac' and run `aclocal' and `autoconf'
>> again.
>> Makefile.am:8: If `AC_PROG_LIBTOOL' is in `configure.ac', make sure
>> Makefile.am:8: its definition is in aclocal's search path.
>> autoreconf: automake failed with exit status: 1
>> Adding AC_PROG_LIBTOOL does not fix it.
>> Is there a way to fix this?
>> Thanks
>> Justin M Wozniak
Justin M Wozniak
More information about the mpich2-dev mailing list
