[mpich2-dev] mpix/armci libtool configuration
Anthony Chan
chan at mcs.anl.gov
Tue Jun 14 14:57:15 CDT 2011
Are you using maint/updatefiles to build configure or using autoreconf directly ?
----- Original Message -----
> Hello
> After a recent update, I get:
> autoreconf: configure.ac: not using Libtool
> autoreconf: running: /homes/wozniak/sfw/autoconf-2.68/bin/autoconf
> --force
> autoreconf: running: /homes/wozniak/sfw/autoconf-2.68/bin/autoheader
> --force
> autoreconf: running: automake --add-missing --copy --force-missing
> Makefile.am:8: Libtool library used but `LIBTOOL' is undefined
> Makefile.am:8: The usual way to define `LIBTOOL' is to add
> `AC_PROG_LIBTOOL'
> Makefile.am:8: to `configure.ac' and run `aclocal' and `autoconf'
> again.
> Makefile.am:8: If `AC_PROG_LIBTOOL' is in `configure.ac', make sure
> Makefile.am:8: its definition is in aclocal's search path.
> autoreconf: automake failed with exit status: 1
> Adding AC_PROG_LIBTOOL does not fix it.
> Is there a way to fix this?
> Thanks
> Justin M Wozniak
More information about the mpich2-dev
