[mpich2-dev] mpix/armci libtool configuration
Anthony Chan
chan at mcs.anl.gov
Tue Jun 14 15:52:26 CDT 2011
I just used maint/updatefiles + autoconf-2.68 to successfully configure
mpich2 (r8662). What directory where configure.ac failed with autoreconf ?
----- Original Message -----
> I use maint/updatefiles. I went back to r8600 to get things going
> again...
> On Tue, 14 Jun 2011, Anthony Chan wrote:
> > Are you using maint/updatefiles to build configure or using
> > autoreconf directly ?
> >> Hello
> >> After a recent update, I get:
> >> autoreconf: configure.ac: not using Libtool
> >> autoreconf: running: /homes/wozniak/sfw/autoconf-2.68/bin/autoconf
> >> --force
> >> /homes/wozniak/sfw/autoconf-2.68/bin/autoheader
> >> --force
> >> autoreconf: running: automake --add-missing --copy --force-missing
> >> Makefile.am:8: Libtool library used but `LIBTOOL' is undefined
> >> Makefile.am:8: The usual way to define `LIBTOOL' is to add
> >> `AC_PROG_LIBTOOL'
> >> Makefile.am:8: to `configure.ac' and run `aclocal' and `autoconf'
> >> again.
> >> Makefile.am:8: If `AC_PROG_LIBTOOL' is in `configure.ac', make sure
> >> Makefile.am:8: its definition is in aclocal's search path.
> >> autoreconf: automake failed with exit status: 1
> >> Adding AC_PROG_LIBTOOL does not fix it.
> >> Is there a way to fix this?
> >> Thanks
> >> Justin M Wozniak
> Justin M Wozniak
More information about the mpich2-dev
