[mpich2-dev] mpix/armci libtool configuration
Justin M Wozniak
wozniak at mcs.anl.gov
Tue Jun 14 14:19:41 CDT 2011
Hello
After a recent update, I get:
autoreconf: configure.ac: not using Libtool
autoreconf: running: /homes/wozniak/sfw/autoconf-2.68/bin/autoconf --force
autoreconf: running: /homes/wozniak/sfw/autoconf-2.68/bin/autoheader
--force
autoreconf: running: automake --add-missing --copy --force-missing
Makefile.am:8: Libtool library used but `LIBTOOL' is undefined
Makefile.am:8: The usual way to define `LIBTOOL' is to add
`AC_PROG_LIBTOOL'
Makefile.am:8: to `configure.ac' and run `aclocal' and `autoconf' again.
Makefile.am:8: If `AC_PROG_LIBTOOL' is in `configure.ac', make sure
Makefile.am:8: its definition is in aclocal's search path.
autoreconf: automake failed with exit status: 1
Adding AC_PROG_LIBTOOL does not fix it.
Is there a way to fix this?
Thanks
Justin M Wozniak
More information about the mpich2-dev
