[mpich2-dev] is there a gforker equivalent to the Windows mpich2?
Jayesh Krishna jayesh at mcs.anl.gov
Thu Feb 24 14:09:17 CST 2011
Carl,
 I am actually adding some code to MPICH2 which would take care of the Windows firewall issue for you. I will get back to you in a day or two regarding the same.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich2-dev at mcs.anl.gov
Sent: Thursday, February 24, 2011 1:27:18 PM
Subject: Re: [mpich2-dev] is there a gforker equivalent to the Windows mpich2?
thanks again - we're actually going to stick with your solution, we can
automatically launch smpd -d 0 in the background while the other MPI tasks are
running.  there doesn't seem to be a way around Microsoft's paranoia about even
local sockets as a firewall issue, so not much point in trying to do it in MinGW
(it would just bring up the same nag screens etc)!  the BOINC user will
hopefully just need to "Unblock" mpiexec etc once unless the paths change.
More information about the mpich2-dev mailing list
