[mpich2-dev] configuration problem
Pavan Balaji balaji at mcs.anl.gov
Sat Apr 17 11:09:48 CDT 2010
On 04/17/2010 11:05 AM, lagoun brahim wrote:
> when I have run mpiexec with the -all-print-exitcode option I had the
> following message but I could not interpret it:
> mpiexec -print-all-exitcodes -f host -np 3 abinit<tnlo.files
>   ABINIT
[snip]
> [mpiexec at br] Exit codes: [0]1,[1]0[2]1
> Terminated (signal 15)
Your application's process ranks 0 and 2 exited with an exit code 1. You
might want to look at what's happening with those processes.
> Another remark when I run mpiexec with a file  machine with the IP
> addresses of both PCs it works but it takes more time than a single machine
mpiexec does an ssh to each node to launch the proxy processes (which in
turn launch the MPI processes). Typically, for small number of nodes,
you shouldn't notice a difference unless your machine's ssh is very slow.
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
More information about the mpich2-dev mailing list
