[mpich2-dev] Re configuration problem
lagoun brahim
lag17_brahim at yahoo.fr
Mon Apr 19 20:32:02 CDT 2010
HI PAVAN and thanks a gain for your help
now i have execut the mpiexec with verbose option i have this message but i don't now where is my problem:(machine contain the ip adress of my two PC)
mpiexec -verbose -f machine -n 2 cpi
mpiexec options:
Base path: /home/work/mpi/bin/
Proxy port: 9899
Bootstrap server: ssh
Debug level: 1
Enable X: -1
Working dir: /home/work
Global environment:
LESSKEY=/etc/lesskey.bin
INFODIR=/usr/local/info:/usr/share/info:/usr/info
MANPATH=/usr/share/man:/usr/local/man
NNTPSERVER=news
KDE_MULTIHEAD=false
SSH_AGENT_PID=2795
HOSTNAME=dft
DM_CONTROL=/var/run/xdmctl
XKEYSYMDB=/usr/share/X11/XKeysymDB
GPG_AGENT_INFO=/tmp/gpg-F5BqTB/S.gpg-agent:2761:1
HOST=dft
SHELL=/bin/bash
TERM=xterm
PROFILEREAD=true
HISTSIZE=1000
XDM_MANAGED=/var/run/xdmctl/xdmctl-:0,maysd,mayfn,sched,rsvd,method
XDG_SESSION_COOKIE=2f73c63cfc4871419a511f004bbe4b00-1271716286.310337-131425
5710
TMPDIR=/tmp
GTK2_RC_FILES=/etc/gtk-2.0/gtkrc:/usr/share/themes//QtCurve/gtk-2.0/gtkrc:/r
oot/.gtkrc-2.0-qtengine:/root/.gtkrc-2.0:/root/.kde/share/config/gtkrc-2.0
GTK_RC_FILES=/etc/gtk/gtkrc:/root/.gtkrc:/root/.kde/share/config/gtkrc
GS_LIB=/root/.fonts
WINDOWID=46137352
PDFREADER=acroread
MORE=-sl
XSESSION_IS_UP=yes
KDE_FULL_SESSION=true
GROFF_NO_SGR=yes
JRE_HOME=/usr/lib64/jvm/jre
USER=root
LS_COLORS=no
DESKTOP_LAUNCH=kde-open
XNLSPATH=/usr/share/X11/nls
ENV=/etc/bash.bashrc
SSH_AUTH_SOCK=/tmp/ssh-dPPkG2625/agent.2625
HOSTTYPE=x86_64
SESSION_MANAGER=local/dft:/tmp/.ICE-unix/3077
FROM_HEADER=(null)
PAGER=less
CSHEDIT=emacs
XDG_CONFIG_DIRS=:/etc/xdg
KONSOLE_DCOP=DCOPRef(konsole-4128,konsole)
MINICOM=-c on
MAIL=/var/spool/mail/root
PATH=/opt/kde3/bin:/sbin:/usr/sbin:/usr/local/sbin:/root/bin:/usr/local/bin:
/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr
/lib/mit/bin:/usr/lib/mit/sbin:/home/wien:.:/home/work/mpi/bin:/home/work/abinit
/bin:/home/wien:.:/home/work/mpi/bin:/home/work/abinit/bin
DESKTOP_SESSION=default
CPU=x86_64
JAVA_BINDIR=/usr/lib64/jvm/jre/bin
KONSOLE_DCOP_SESSION=DCOPRef(konsole-4128,session-1)
INPUTRC=/etc/inputrc
PWD=/home/work
JAVA_HOME=/usr/lib64/jvm/jre
XMODIFIERS=@im
EDITOR=emacs
LANG=POSIX
KDE_SESSION_UID=0
PYTHONSTARTUP=/etc/pythonstart
SSH_ASKPASS=/usr/lib64/ssh/x11-ssh-askpass
TEXINPUTS=:/root/.TeX:/usr/share/doc/.TeX:/usr/doc/.TeX
QT_SYSTEM_DIR=/usr/share/desktop-data
HOME=/root
SHLVL=2
LESS_ADVANCED_PREPROCESSOR=no
OSTYPE=linux
LS_OPTIONS=-A -N --color
XCURSOR_THEME=DMZ
WINDOWMANAGER=/usr/bin/dbus-launch --sh-syntax --exit-with-session /usr/bin/
kde
GTK_PATH=/usr/local/lib/gtk-2.0:/usr/lib/gtk-2.0
LESS=-M -I
MACHTYPE=x86_64-suse-linux
LOGNAME=root
GTK_PATH64=/usr/local/lib64/gtk-2.0:/usr/lib64/gtk-2.0
XDG_DATA_DIRS=/usr/share:/etc/opt/kde3/share:/opt/kde3/share
LC_CTYPE=fr_FR.UTF-8
DBUS_SESSION_BUS_ADDRESS=unix:abstract
LESSOPEN=lessopen.sh %s
USE_FAM=(null)
WIENROOT=/home/wien
INFOPATH=/usr/local/info:/usr/share/info:/usr/info
DISPLAY=:0.0
XAUTHLOCALHOSTNAME=dft
LESSCLOSE=lessclose.sh %s %s
SCRATCH=./
G_BROKEN_FILENAMES=1
JAVA_ROOT=/usr/lib64/jvm/jre
COLORTERM=(null)
mc=() { . /usr/share/mc/bin/mc-wrapper.sh
_=/home/work/mpi/bin/mpiexec
Executable information:
Executable ID: 1
Process count: 2
Executable: cpi
Proxy information:
Proxy ID: 1
Proxy name: 192.168.1.2
Process count: 1
Start PID: 0
Proxy exec list:
Exec: cpi; Process count: 1
Proxy ID: 2
Proxy name: 192.168.1.1
Process count: 1
Start PID: 1
Proxy exec list:
[mpiexec at dft] Timeout set to -1 (-1 means infinite)
[mpiexec at dft] Got a PMI port string of dft:26191
[mpiexec at dft] Got a proxy port string of dft:20682
Arguments being passed to proxy 0:
--version 1.2.1 --hostname 192.168.1.2 --global-core-count 2 --wdir /home/work -
-pmi-port-str dft:26191 --binding HYDRA_NULL --bindlib plpa --ckpointlib none --
ckpoint-prefix HYDRA_NULL --global-inherited-env 87 'LESSKEY=/etc/lesskey.bin' '
INFODIR=/usr/local/info:/usr/share/info:/usr/info' 'MANPATH=/usr/share/man:/usr/
local/man' 'NNTPSERVER=news' 'KDE_MULTIHEAD=false' 'SSH_AGENT_PID=2795' 'HOSTNAM
E=dft' 'DM_CONTROL=/var/run/xdmctl' 'XKEYSYMDB=/usr/share/X11/XKeysymDB' 'GPG_AG
ENT_INFO=/tmp/gpg-F5BqTB/S.gpg-agent:2761:1' 'HOST=dft' 'SHELL=/bin/bash' 'TERM=
xterm' 'PROFILEREAD=true' 'HISTSIZE=1000' 'XDM_MANAGED=/var/run/xdmctl/xdmctl-:0
,maysd,mayfn,sched,rsvd,method' 'XDG_SESSION_COOKIE=2f73c63cfc4871419a511f004bbe
4b00-1271716286.310337-1314255710' 'TMPDIR=/tmp' 'GTK2_RC_FILES=/etc/gtk-2.0/gtk
rc:/usr/share/themes//QtCurve/gtk-2.0/gtkrc:/root/.gtkrc-2.0-qtengine:/root/.gtk
rc-2.0:/root/.kde/share/config/gtkrc-2.0' 'GTK_RC_FILES=/etc/gtk/gtkrc:/root/.gt
krc:/root/.kde/share/config/gtkrc' 'GS_LIB=/root/.fonts' 'WINDOWID=46137352' 'PD
FREADER=acroread' 'MORE=-sl' 'XSESSION_IS_UP=yes' 'KDE_FULL_SESSION=true' 'GROFF
_NO_SGR=yes' 'JRE_HOME=/usr/lib64/jvm/jre' 'USER=root' 'LS_COLORS=no' 'DESKTOP_L
AUNCH=kde-open' 'XNLSPATH=/usr/share/X11/nls' 'ENV=/etc/bash.bashrc' 'SSH_AUTH_S
OCK=/tmp/ssh-dPPkG2625/agent.2625' 'HOSTTYPE=x86_64' 'SESSION_MANAGER=local/dft:
/tmp/.ICE-unix/3077' 'FROM_HEADER=' 'PAGER=less' 'CSHEDIT=emacs' 'XDG_CONFIG_DIR
S=:/etc/xdg' 'KONSOLE_DCOP=DCOPRef(konsole-4128,konsole)' 'MINICOM=-c on' 'MAIL=
/var/spool/mail/root' 'PATH=/opt/kde3/bin:/sbin:/usr/sbin:/usr/local/sbin:/root/
bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib
64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/home/wien:.:/home/work/mpi/bi
n:/home/work/abinit/bin:/home/wien:.:/home/work/mpi/bin:/home/work/abinit/bin' '
DESKTOP_SESSION=default' 'CPU=x86_64' 'JAVA_BINDIR=/usr/lib64/jvm/jre/bin' 'KONS
OLE_DCOP_SESSION=DCOPRef(konsole-4128,session-1)' 'INPUTRC=/etc/inputrc' 'PWD=/h
ome/work' 'JAVA_HOME=/usr/lib64/jvm/jre' 'XMODIFIERS=@im' 'EDITOR=emacs' 'LANG=P
OSIX' 'KDE_SESSION_UID=0' 'PYTHONSTARTUP=/etc/pythonstart' 'SSH_ASKPASS=/usr/lib
64/ssh/x11-ssh-askpass' 'TEXINPUTS=:/root/.TeX:/usr/share/doc/.TeX:/usr/doc/.TeX
' 'QT_SYSTEM_DIR=/usr/share/desktop-data' 'HOME=/root' 'SHLVL=2' 'LESS_ADVANCED_
PREPROCESSOR=no' 'OSTYPE=linux' 'LS_OPTIONS=-A -N --color' 'XCURSOR_THEME=DMZ' '
WINDOWMANAGER=/usr/bin/dbus-launch --sh-syntax --exit-with-session /usr/bin/kde'
'GTK_PATH=/usr/local/lib/gtk-2.0:/usr/lib/gtk-2.0' 'LESS=-M -I' 'MACHTYPE=x86_6
4-suse-linux' 'LOGNAME=root' 'GTK_PATH64=/usr/local/lib64/gtk-2.0:/usr/lib64/gtk
-2.0' 'XDG_DATA_DIRS=/usr/share:/etc/opt/kde3/share:/opt/kde3/share' 'LC_CTYPE=f
r_FR.UTF-8' 'DBUS_SESSION_BUS_ADDRESS=unix:abstract' 'LESSOPEN=lessopen.sh %s' '
USE_FAM=' 'WIENROOT=/home/wien' 'INFOPATH=/usr/local/info:/usr/share/info:/usr/i
nfo' 'DISPLAY=:0.0' 'XAUTHLOCALHOSTNAME=dft' 'LESSCLOSE=lessclose.sh %s %s' 'SCR
ATCH=./' 'G_BROKEN_FILENAMES=1' 'JAVA_ROOT=/usr/lib64/jvm/jre' 'COLORTERM=' 'mc=
}' '_=/home/work/mpi/bin/mpiexec' --global-user-env 0 --global-system-env 0 --ge
nv-prop all --start-pid 0 --proxy-core-count 1 --exec --exec-proc-count 1 --exec
-local-env 0 --exec-env-prop HYDRA_NULL cpi
Arguments being passed to proxy 1:
--version 1.2.1 --hostname 192.168.1.1 --global-core-count 2 --wdir /home/work -
64/ssh/x11-ssh-askpass' 'TEXINPUTS=:/root/.TeX:/usr/share/doc/.TeX:/usr/doc/.TeX ' 'QT_SYSTEM_DIR=/usr/share/desktop-data' 'HOME=/root' 'SHLVL=2' 'LESS_ADVANCED_ PREPROCESSOR=no' 'OSTYPE=linux' 'LS_OPTIONS=-A -N --color' 'XCURSOR_THEME=DMZ' ' WINDOWMANAGER=/usr/bin/dbus-launch --sh-syntax --exit-with-session /usr/bin/kde' 'GTK_PATH=/usr/local/lib/gtk-2.0:/usr/lib/gtk-2.0' 'LESS=-M -I' 'MACHTYPE=x86_6 4-suse-linux' 'LOGNAME=root' 'GTK_PATH64=/usr/local/lib64/gtk-2.0:/usr/lib64/gtk -2.0' 'XDG_DATA_DIRS=/usr/share:/etc/opt/kde3/share:/opt/kde3/share' 'LC_CTYPE=f r_FR.UTF-8' 'DBUS_SESSION_BUS_ADDRESS=unix:abstract' 'LESSOPEN=lessopen.sh %s' ' USE_FAM=' 'WIENROOT=/home/wien' 'INFOPATH=/usr/local/info:/usr/share/info:/usr/i nfo' 'DISPLAY=:0.0' 'XAUTHLOCALHOSTNAME=dft' 'LESSCLOSE=lessclose.sh %s %s' 'SCR ATCH=./' 'G_BROKEN_FILENAMES=1'
'JAVA_ROOT=/usr/lib64/jvm/jre' 'COLORTERM=' 'mc= () { . /usr/share/mc/bin/mc-wrapper.sh
}' '_=/home/work/mpi/bin/mpiexec' --global-user-env 0 --global-system-env 0 --ge nv-prop all --start-pid 1 --proxy-core-count 1 --exec --exec-proc-count 1 --exec -local-env 0 --exec-env-prop HYDRA_NULL cpi
[mpiexec at dft] Launching process: /usr/bin/ssh -x 192.168.1.2 /home/work/mpi/bin/ pmi_proxy --launch-mode 1 --proxy-port dft:20682 --debug --bootstrap ssh --proxy -id 0
[mpiexec at dft] Launching process: /usr/bin/ssh -x 192.168.1.1 /home/work/mpi/bin/ pmi_proxy --launch-mode 1 --proxy-port dft:20682 --debug --bootstrap ssh --proxy -id 1
bash: /home/work/mpi/bin/pmi_proxy: No such file or directory
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20100420/05f29acc/attachment.htm>
More information about the mpich2-dev
