[mpich2-dev] configuration problem
lagoun brahim
lag17_brahim at yahoo.fr
Sat Apr 17 11:05:04 CDT 2010
thank you again
when I have run mpiexec with the -all-print-exitcode option I had the following message but I could not interpret it:
mpiexec -print-all-exitcodes -f host -np 3 abinit<tnlo.files
ABINIT
Give name for formatted input file:
tnlo2.in
Give name for formatted output file:
tnlo2.out
Give root name for generic input files:
tnlo2i
Give root name for generic output files:
tnlo2o
Give root name for generic temporary files:
tnlo2
Fatal error in PMPI_Barrier: Other MPI error, error stack:
PMPI_Barrier(476).................: MPI_Barrier(MPI_COMM_WORLD) failed
MPIR_Barrier(82)..................:
MPIC_Sendrecv(161)................:
MPIC_Wait(513)....................:
MPIDI_CH3I_Progress(150)..........:
MPID_nem_mpich2_blocking_recv(948):
MPID_nem_tcp_connpoll(1709).......: Communication error
[mpiexec at br] Exit codes: [0]1,[1]0[2]1
Terminated (signal 15)
Another
remark when I run mpiexec with a file machine with the IP addresses of
both PCs it works but it takes more time than a single machine
thank you
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20100417/05aedf03/attachment.htm>
More information about the mpich2-dev
