[mpich2-dev] [opa-core] Problem with MPICH2 1.1 during MPI_Init() on PPC Linux 32bit
Joe Ratterman jratt0 at gmail.com
Tue Jun 9 16:28:26 CDT 2009
Yes, that patch works fine.  It might not be the final solution, but it does
make the assert pass, and I can run my app.  I think it is a very good idea.
What about this part of the comment:
"Also, we don't support compilers which add random padding to the start of
the structure."
Essentially, the compiler added 4 bytes to the *end* of a different
structure that you are using in your new structure.  Might that be a
concern?
On Tue, Jun 9, 2009 at 4:06 PM, Darius Buntinas <buntinas at mcs.anl.gov>wrote:
> Joe, can you check if this patch works for you?
> Thanks,
> -d
> Index: src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_init.c
> --- src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_init.c   (revision
> 4676)
> +++ src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_init.c   (working
> copy)
> @@ -86,7 +86,7 @@
>       * should only contain a pointer. Also, we don't support compilers
>      * which add random padding to the start of the structure. The
>      * below assert should blow up if any of these happens. */
> -    MPIU_Assert(sizeof(MPID_nem_cell_rel_ptr_t) == SIZEOF_VOID_P);
> +    MPIU_Assert(sizeof(MPID_nem_cell_rel_ptr_t) == sizeof(OPA_ptr_t));
>     /* Make sure the cell structure looks like it should */
>     MPIU_Assert(MPID_NEM_CELL_PAYLOAD_LEN + MPID_NEM_CELL_HEAD_LEN ==
> sizeof(MPID_nem_cell_t));
> On 06/09/2009 03:58 PM, Darius Buntinas wrote:
> > I believe it should be exactly the size of an OPA_ptr_t.  I'm checking
> > this right now.
> > -d
> >> I think the bigger question is whether or not the assertion is
> >> sensible.  I don't know why the cell rel pointer structure needs to be
> >> exactly the same size as a pointer as long as it contains a pointer
> >> value...
> opa-core mailing list
> opa-core at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/opa-core
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20090609/731666c4/attachment-0001.htm>
More information about the mpich2-dev mailing list
