[mpich2-dev] issues Pack/Unpack_external with MPI_LONG and MPI_DOUBLE
Lisandro Dalcin dalcinl at gmail.com
Mon Dec 7 11:16:24 CST 2009
Sorry if this is a known issue. Also sorry for pasting Python code,
but no time right now to write proper testcase in C.
>From long time back, I'm having issues in mpi4py testsuite when using
Pack/Unpack_external. The following script should be enough to exhibit
all the issues I have on Linux 32 and 64.
This is the Python code I'm testing. Basically, for various MPI
datatypes, I do a pack/unpack of an array with 5 items and print them
at the end, expecting input/output arrays to be the same:
from mpi4py import MPI
import numpy
for typecode, datatype in [('i', MPI.INT),
                           ('l', MPI.LONG),
                           ('q', MPI.LONG_LONG),
                           ('f', MPI.FLOAT),
                           ('d', MPI.DOUBLE),
    # temp array for packing
    nbytes = datatype.Pack_external_size('external32', 5)
    tmpbuf = numpy.empty(nbytes, dtype='B') # unsigned char
    # pack input array
    iarray = numpy.arange(1,6, dtype=typecode)
    datatype.Pack_external('external32', iarray, tmpbuf, 0)
    # unpack output array
    oarray = numpy.zeros(5, dtype=typecode)
    datatype.Unpack_external('external32', tmpbuf, 0, oarray)
    print datatype.Get_name(), datatype.Get_size()
    print 'input: ', iarray
    print 'output:', oarray
    print 'buffer:', tmpbuf, len(tmpbuf)
Now I'll list my issues when I run the code above on Linux 32 and 64 bits:
1) Linux 32:
All but the MPI_DOUBLE iteration works. For the MPI_DOUBLE  case, the
pack/unpack seems to do the job, but memory is getting corrupted. A
run under valgrind shows this a few times (both invalid reads and
invalid writes):
==10399== Invalid read of size 4
==10399==    at 0x48736AA: external32_float_convert (mpid_ext32_segment.h:167)
==10399==    by 0x487435D: MPID_Segment_contig_pack_external32_to_buf
(mpid_ext32_segment.c:208)
==10399==    by 0x48E13ED: MPID_Segment_manipulate (segment.c:528)
==10399==    by 0x487326E: MPID_Segment_pack_external32
(mpid_ext32_segment.c:302)
==10399==    by 0x48B3088: PMPI_Pack_external (pack_external.c:140)
==10399==    by 0x469B16F:
__pyx_pf_6mpi4py_3MPI_8Datatype_Pack_external (mpi4py.MPI.c:34203)
==10399==    by 0x5533077: PyCFunction_Call (in /usr/lib/libpython2.6.so.1.0)
==10399==    by 0x558F072: PyEval_EvalFrameEx (in /usr/lib/libpython2.6.so.1.0)
==10399==    by 0x5590E49: PyEval_EvalCodeEx (in /usr/lib/libpython2.6.so.1.0)
==10399==    by 0x5590FB3: PyEval_EvalCode (in /usr/lib/libpython2.6.so.1.0)
==10399==    by 0x55AC25B: ??? (in /usr/lib/libpython2.6.so.1.0)
==10399==    by 0x55AC322: PyRun_FileExFlags (in /usr/lib/libpython2.6.so.1.0)
==10399==  Address 0x42e4b48 is 0 bytes after a block of size 40 alloc'd
==10399==    at 0x4005BDC: malloc (vg_replace_malloc.c:195)
==10399==    by 0x5222979: ??? (in
/usr/lib/python2.6/site-packages/numpy/core/multiarray.so)
==10399==    by 0x52365C0: ??? (in
==10399==    by 0x5236CAE: ??? (in
==10399==    by 0x54F280C: PyObject_Call (in /usr/lib/libpython2.6.so.1.0)
==10399==    by 0x558ED4F: PyEval_EvalFrameEx (in /usr/lib/libpython2.6.so.1.0)
==10399==    by 0x55AD8C0: PyRun_SimpleFileExFlags (in /usr/lib/libpython2.6.so.
2) Linux 64:
a) I have the same issue as before for MPI_DOUBLE.
b) Additionally, MPI_LONG does not seems to do the job. I get this output:
MPI_LONG 8
input:  [1 2 3 4 5]
output: [0 0 0 0 0]
buffer: [ 16  70 115   0   0   0   0   0 192 238 240  79   6  43   0
0 255 255 255 255] 20
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
More information about the mpich2-dev mailing list
