[mpich2-dev] issues Pack/Unpack_external with MPI_LONG and MPI_DOUBLE
Dave Goodell goodell at mcs.anl.gov
Mon Dec 7 14:34:25 CST 2009
Thanks for the bug report.  I've filed this as a ticket in our bug
tracking system and CCed you on it: https://trac.mcs.anl.gov/projects/mpich2/ticket/967
AFAIK, external32 is not fully implemented and it is not surprising
that it does not work.  We do not have any near-term plans to
implement it.
We will update the status of that ticket as the status of external32
support in MPICH2 changes.
-Dave
On Dec 7, 2009, at 11:16 AM, Lisandro Dalcin wrote:
> Sorry if this is a known issue. Also sorry for pasting Python code,
> but no time right now to write proper testcase in C.
>> From long time back, I'm having issues in mpi4py testsuite when using
> Pack/Unpack_external. The following script should be enough to exhibit
> all the issues I have on Linux 32 and 64.
> This is the Python code I'm testing. Basically, for various MPI
> datatypes, I do a pack/unpack of an array with 5 items and print them
> at the end, expecting input/output arrays to be the same:
> from mpi4py import MPI
> import numpy
> for typecode, datatype in [('i', MPI.INT),
>                           ('l', MPI.LONG),
>                           ('q', MPI.LONG_LONG),
>                           ('f', MPI.FLOAT),
>                           ('d', MPI.DOUBLE),
>    # temp array for packing
>    nbytes = datatype.Pack_external_size('external32', 5)
>    tmpbuf = numpy.empty(nbytes, dtype='B') # unsigned char
>    # pack input array
>    iarray = numpy.arange(1,6, dtype=typecode)
>    datatype.Pack_external('external32', iarray, tmpbuf, 0)
>    # unpack output array
>    oarray = numpy.zeros(5, dtype=typecode)
>    datatype.Unpack_external('external32', tmpbuf, 0, oarray)
>    print datatype.Get_name(), datatype.Get_size()
>    print 'input: ', iarray
>    print 'output:', oarray
>    print 'buffer:', tmpbuf, len(tmpbuf)
> Now I'll list my issues when I run the code above on Linux 32 and 64
> bits:
> 1) Linux 32:
> All but the MPI_DOUBLE iteration works. For the MPI_DOUBLE  case, the
> pack/unpack seems to do the job, but memory is getting corrupted. A
> run under valgrind shows this a few times (both invalid reads and
> invalid writes):
> ==10399== Invalid read of size 4
> ==10399==    at 0x48736AA: external32_float_convert
> (mpid_ext32_segment.h:167)
> ==10399==    by 0x487435D: MPID_Segment_contig_pack_external32_to_buf
> (mpid_ext32_segment.c:208)
> ==10399==    by 0x48E13ED: MPID_Segment_manipulate (segment.c:528)
> ==10399==    by 0x487326E: MPID_Segment_pack_external32
> (mpid_ext32_segment.c:302)
> ==10399==    by 0x48B3088: PMPI_Pack_external (pack_external.c:140)
> ==10399==    by 0x469B16F:
> __pyx_pf_6mpi4py_3MPI_8Datatype_Pack_external (mpi4py.MPI.c:34203)
> ==10399==    by 0x5533077: PyCFunction_Call (in /usr/lib/
> libpython2.6.so.1.0)
> ==10399==    by 0x558F072: PyEval_EvalFrameEx (in /usr/lib/
> ==10399==    by 0x5590E49: PyEval_EvalCodeEx (in /usr/lib/
> ==10399==    by 0x5590FB3: PyEval_EvalCode (in /usr/lib/
> ==10399==    by 0x55AC25B: ??? (in /usr/lib/libpython2.6.so.1.0)
> ==10399==    by 0x55AC322: PyRun_FileExFlags (in /usr/lib/
> ==10399==  Address 0x42e4b48 is 0 bytes after a block of size 40
> alloc'd
> ==10399==    at 0x4005BDC: malloc (vg_replace_malloc.c:195)
> ==10399==    by 0x5222979: ??? (in
> /usr/lib/python2.6/site-packages/numpy/core/multiarray.so)
> ==10399==    by 0x52365C0: ??? (in
> ==10399==    by 0x5236CAE: ??? (in
> ==10399==    by 0x54F280C: PyObject_Call (in /usr/lib/
> ==10399==    by 0x558ED4F: PyEval_EvalFrameEx (in /usr/lib/
> ==10399==    by 0x55AD8C0: PyRun_SimpleFileExFlags (in /usr/lib/
> libpython2.6.so.
> 2) Linux 64:
> a) I have the same issue as before for MPI_DOUBLE.
> b) Additionally, MPI_LONG does not seems to do the job. I get this
> output:
> MPI_LONG 8
> input:  [1 2 3 4 5]
> output: [0 0 0 0 0]
> buffer: [ 16  70 115   0   0   0   0   0 192 238 240  79   6  43   0
> 0 255 255 255 255] 20
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
More information about the mpich2-dev mailing list
