[mpich2-dev] [PATCH 1/1] Issue 4120: Fix attr alignment check from MPI_Aint to long alignment - again
Rob Ross
rross at mcs.anl.gov
Fri Mar 21 12:45:46 CDT 2008
Reading the email prior to this one, I think I can be safely ignored.
Sorry for the distraction. -- Rob
On Mar 21, 2008, at 12:44 PM, Rob Ross wrote:
> I'm sort of coming in and out of the conversation, so maybe I'm
> missing the point, but MPI_Aint has to be signed. Extents can be
> negative. -- Rob
> On Mar 21, 2008, at 11:23 AM, Jeff Parker wrote:
>> One more time, Doug pointed out that the cast of the pointer to an
>> MPI_Aint should be a
>> cast to a long as well. Also changed to unsigned long.
>> Signed-off-by: Jeff Parker <jjparker at us.ibm.com>
>> lib/mpi/mpich2/src/mpi/attr/attr_get.c | 2 +-
>> lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c | 2 +-
>> lib/mpi/mpich2/src/mpi/attr/type_get_attr.c | 2 +-
>> lib/mpi/mpich2/src/mpi/attr/win_get_attr.c | 2 +-
>> 4 files changed, 4 insertions(+), 4 deletions(-)
>> diff --git a/lib/mpi/mpich2/src/mpi/attr/attr_get.c b/lib/mpi/
>> index cc39822..4527ba0 100644
>> --- a/lib/mpi/mpich2/src/mpi/attr/attr_get.c
>> +++ b/lib/mpi/mpich2/src/mpi/attr/attr_get.c
>> @@ -97,7 +97,7 @@ int MPI_Attr_get(MPI_Comm comm, int keyval, void
>> *attr_value, int *flag)
>> address sized int, but since this is configurable and
>> could
>> be larger than a pointer, we use long for the check,
>> since
>> long is expected to be the size of a pointer.*/
>> - if (MPI_VOID_PTR_CAST_TO_MPI_AINT attr_value &
>> (sizeof(long)-1)) {
>> + if ( (unsigned long) attr_value & (sizeof(unsigned long)-1)) {
>> MPIU_ERR_SET(mpi_errno,MPI_ERR_ARG,"**attrnotptr");
>> # endif
>> diff --git a/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c b/lib/mpi/
>> index b243968..8e6a88d 100644
>> --- a/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c
>> +++ b/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c
>> @@ -89,7 +89,7 @@ int MPI_Comm_get_attr(MPI_Comm comm, int
>> comm_keyval, void *attribute_val, int *
>> could
>> since
>> long is expected to be the size of a pointer. */
>> - if (MPI_VOID_PTR_CAST_TO_MPI_AINT attribute_val &
>> (sizeof(long)-1)) {
>> + if ( (unsigned long) attribute_val & (sizeof(unsigned
>> long)-1)) {
>> # endif
>> diff --git a/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c b/lib/mpi/
>> index 7a41051..fabfe6a 100644
>> --- a/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c
>> +++ b/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c
>> @@ -91,7 +91,7 @@ int MPI_Type_get_attr(MPI_Datatype type, int
>> type_keyval, void *attribute_val,
>> could
>> since
>> (sizeof(long)-1)) {
>> long)-1)) {
>> # endif
>> diff --git a/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c b/lib/mpi/
>> index 921f018..958d193 100644
>> --- a/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
>> +++ b/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
>> @@ -87,7 +87,7 @@ int MPI_Win_get_attr(MPI_Win win, int win_keyval,
>> could
>> since
>> (sizeof(long)-1)) {
>> long)-1)) {
>> # endif
>> 1.5.3.7
More information about the mpich2-dev
