[mpich2-dev] [PATCH 1/1] Issue 4120: Fix attr alignment check from MPI_Aint to long alignment - again
Douglas Miller dougmill at us.ibm.com
Fri Mar 21 14:01:54 CDT 2008
The (my) reasoning behind using "unsigned long" is that we are doing a
bitwise operation on something that is originally a pointer. So convention
for that would be treating it as unsigned for the purposes of the bitwise
AND. But it probably doesn't matter on all modern architectures.
Douglas Miller                  BlueGene Messaging Development
IBM Corp., Rochester, MN USA                     Bldg 030-2 C214
dougmill at us.ibm.com               Douglas Miller/Rochester/IBM
             Rob Ross
             <rross at mcs.anl.go
             v>                                                         To
             Sent by:                  mpich2-dev at mcs.anl.gov
             owner-mpich2-dev@                                          cc
             mcs.anl.gov               Jeff Parker/Rochester/IBM at IBMUS
        Subject
                                       Re: [mpich2-dev] [PATCH 1/1] Issue
             03/21/08 12:44 PM         4120: Fix attr alignment check from
             Please respond to
                   l.gov
I'm sort of coming in and out of the conversation, so maybe I'm
missing the point, but MPI_Aint has to be signed. Extents can be
negative. -- Rob
On Mar 21, 2008, at 11:23 AM, Jeff Parker wrote:
> One more time, Doug pointed out that the cast of the pointer to an
> MPI_Aint should be a
> cast to a long as well.  Also changed to unsigned long.
> Signed-off-by: Jeff Parker <jjparker at us.ibm.com>
> lib/mpi/mpich2/src/mpi/attr/attr_get.c      |    2 +-
> lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c |    2 +-
> lib/mpi/mpich2/src/mpi/attr/type_get_attr.c |    2 +-
> lib/mpi/mpich2/src/mpi/attr/win_get_attr.c  |    2 +-
> 4 files changed, 4 insertions(+), 4 deletions(-)
> diff --git a/lib/mpi/mpich2/src/mpi/attr/attr_get.c b/lib/mpi/mpich2/
> index cc39822..4527ba0 100644
> --- a/lib/mpi/mpich2/src/mpi/attr/attr_get.c
> +++ b/lib/mpi/mpich2/src/mpi/attr/attr_get.c
> @@ -97,7 +97,7 @@ int MPI_Attr_get(MPI_Comm comm, int keyval, void
> *attr_value, int *flag)
>                address sized int, but since this is configurable and
> could
>                be larger than a pointer, we use long for the check,
> since
>                long is expected to be the size of a pointer.*/
> -              if (MPI_VOID_PTR_CAST_TO_MPI_AINT attr_value &
> (sizeof(long)-1)) {
> +              if ( (unsigned long) attr_value & (sizeof(unsigned
long)-1)) {
MPIU_ERR_SET(mpi_errno,MPI_ERR_ARG,"**attrnotptr");
> #           endif
> diff --git a/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c b/lib/mpi/
> index b243968..8e6a88d 100644
> --- a/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c
> +++ b/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c
> @@ -89,7 +89,7 @@ int MPI_Comm_get_attr(MPI_Comm comm, int
> comm_keyval, void *attribute_val, int *
> could
> since
>                long is expected to be the size of a pointer. */
> -              if (MPI_VOID_PTR_CAST_TO_MPI_AINT attribute_val &
> (sizeof(long)-1)) {
> +              if ( (unsigned long) attribute_val & (sizeof(unsigned
> long)-1)) {
> #           endif
> diff --git a/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c b/lib/mpi/
> index 7a41051..fabfe6a 100644
> --- a/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c
> +++ b/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c
> @@ -91,7 +91,7 @@ int MPI_Type_get_attr(MPI_Datatype type, int
> type_keyval, void *attribute_val,
> could
> since
> (sizeof(long)-1)) {
> long)-1)) {
> #           endif
> diff --git a/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c b/lib/mpi/
> index 921f018..958d193 100644
> --- a/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
> +++ b/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
> @@ -87,7 +87,7 @@ int MPI_Win_get_attr(MPI_Win win, int win_keyval,
> could
> since
> (sizeof(long)-1)) {
> long)-1)) {
> #           endif
> 1.5.3.7
More information about the mpich2-dev mailing list
