[mpich2-dev] [PATCH 1/1] Issue 4120: Fix attr alignment check from MPI_Aint to long alignment - again
Rob Ross
rross at mcs.anl.gov
Fri Mar 21 12:44:12 CDT 2008
I'm sort of coming in and out of the conversation, so maybe I'm
missing the point, but MPI_Aint has to be signed. Extents can be
negative. -- Rob
On Mar 21, 2008, at 11:23 AM, Jeff Parker wrote:
> One more time, Doug pointed out that the cast of the pointer to an
> MPI_Aint should be a
> cast to a long as well. Also changed to unsigned long.
> Signed-off-by: Jeff Parker <jjparker at us.ibm.com>
> lib/mpi/mpich2/src/mpi/attr/attr_get.c | 2 +-
> lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c | 2 +-
> lib/mpi/mpich2/src/mpi/attr/type_get_attr.c | 2 +-
> lib/mpi/mpich2/src/mpi/attr/win_get_attr.c | 2 +-
> 4 files changed, 4 insertions(+), 4 deletions(-)
> diff --git a/lib/mpi/mpich2/src/mpi/attr/attr_get.c b/lib/mpi/mpich2/
> index cc39822..4527ba0 100644
> --- a/lib/mpi/mpich2/src/mpi/attr/attr_get.c
> +++ b/lib/mpi/mpich2/src/mpi/attr/attr_get.c
> @@ -97,7 +97,7 @@ int MPI_Attr_get(MPI_Comm comm, int keyval, void
> *attr_value, int *flag)
> address sized int, but since this is configurable and
> could
> be larger than a pointer, we use long for the check,
> since
> long is expected to be the size of a pointer.*/
> - if (MPI_VOID_PTR_CAST_TO_MPI_AINT attr_value &
> (sizeof(long)-1)) {
> + if ( (unsigned long) attr_value & (sizeof(unsigned long)-1)) {
> MPIU_ERR_SET(mpi_errno,MPI_ERR_ARG,"**attrnotptr");
> # endif
> diff --git a/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c b/lib/mpi/
> index b243968..8e6a88d 100644
> --- a/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c
> +++ b/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c
> @@ -89,7 +89,7 @@ int MPI_Comm_get_attr(MPI_Comm comm, int
> comm_keyval, void *attribute_val, int *
> could
> since
> long is expected to be the size of a pointer. */
> - if (MPI_VOID_PTR_CAST_TO_MPI_AINT attribute_val &
> (sizeof(long)-1)) {
> + if ( (unsigned long) attribute_val & (sizeof(unsigned
> long)-1)) {
> # endif
> diff --git a/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c b/lib/mpi/
> index 7a41051..fabfe6a 100644
> --- a/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c
> +++ b/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c
> @@ -91,7 +91,7 @@ int MPI_Type_get_attr(MPI_Datatype type, int
> type_keyval, void *attribute_val,
> could
> since
> (sizeof(long)-1)) {
> long)-1)) {
> # endif
> diff --git a/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c b/lib/mpi/
> index 921f018..958d193 100644
> --- a/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
> +++ b/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
> @@ -87,7 +87,7 @@ int MPI_Win_get_attr(MPI_Win win, int win_keyval,
> could
> since
> (sizeof(long)-1)) {
> long)-1)) {
> # endif
> 1.5.3.7
More information about the mpich2-dev
