[mpich2-dev] [PATCH 1/1] Issue 4120: Fix attr alignment check from MPI_Aint to long alignment - again
Jeff Parker
jjparker at us.ibm.com
Fri Mar 21 11:23:51 CDT 2008
One more time, Doug pointed out that the cast of the pointer to an MPI_Aint should be a
cast to a long as well. Also changed to unsigned long.
Signed-off-by: Jeff Parker <jjparker at us.ibm.com>
lib/mpi/mpich2/src/mpi/attr/attr_get.c | 2 +-
lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c | 2 +-
lib/mpi/mpich2/src/mpi/attr/type_get_attr.c | 2 +-
lib/mpi/mpich2/src/mpi/attr/win_get_attr.c | 2 +-
4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/lib/mpi/mpich2/src/mpi/attr/attr_get.c b/lib/mpi/mpich2/src/mpi/attr/attr_get.c
index cc39822..4527ba0 100644
--- a/lib/mpi/mpich2/src/mpi/attr/attr_get.c
+++ b/lib/mpi/mpich2/src/mpi/attr/attr_get.c
@@ -97,7 +97,7 @@ int MPI_Attr_get(MPI_Comm comm, int keyval, void *attr_value, int *flag)
address sized int, but since this is configurable and could
be larger than a pointer, we use long for the check, since
long is expected to be the size of a pointer.*/
- if (MPI_VOID_PTR_CAST_TO_MPI_AINT attr_value & (sizeof(long)-1)) {
+ if ( (unsigned long) attr_value & (sizeof(unsigned long)-1)) {
MPIU_ERR_SET(mpi_errno,MPI_ERR_ARG,"**attrnotptr");
# endif
diff --git a/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c b/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c
index b243968..8e6a88d 100644
--- a/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c
+++ b/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c
@@ -89,7 +89,7 @@ int MPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *
long is expected to be the size of a pointer. */
- if (MPI_VOID_PTR_CAST_TO_MPI_AINT attribute_val & (sizeof(long)-1)) {
+ if ( (unsigned long) attribute_val & (sizeof(unsigned long)-1)) {
# endif
diff --git a/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c b/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c
index 7a41051..fabfe6a 100644
--- a/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c
+++ b/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c
@@ -91,7 +91,7 @@ int MPI_Type_get_attr(MPI_Datatype type, int type_keyval, void *attribute_val,
# endif
diff --git a/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c b/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
index 921f018..958d193 100644
--- a/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
+++ b/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
@@ -87,7 +87,7 @@ int MPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val,
# endif
1.5.3.7
More information about the mpich2-dev
