[mpich2-dev] running mpich2 single pc dual core machine
Rajeev Thakur
thakur at mcs.anl.gov
Fri Jul 11 14:50:14 CDT 2008
You can run multiple application processes. For example:
% mpd &
% mpiexec -n 4 a.out
will run 4 a.out processes on the same machine.
For best performance, configure MPICH2 with --with-device=ch3:nemesis and
rerun make, make install.
Rajeev
_____
From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-dev at mcs.anl.gov] On
Behalf Of Alexandre Souza
Sent: Friday, July 11, 2008 2:47 PM
To: mpich2-dev at mcs.anl.gov
Subject: Re: [mpich2-dev] running mpich2 single pc dual core machine
I am confused.. So there is no advantage in using mpich2 in a single pc dual
core machine ?
Alex
On 7/11/08, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
On a single PC, you just need to do "mpd &". Only a single mpd daemon is
needed for all processes on that machine.
Rajeev
_____
Sent: Friday, July 11, 2008 9:46 AM
Subject: [mpich2-dev] running mpich2 single pc dual core machine
Hi All,
I have one question regarding running 2 processes in a single pc dual core
machine:
if I have two (one core) pcs I start the mpich with : mpdboot -n 2 -f
~/mpd.hosts
with mpd.hosts contents: node0
node1
How can I use mpdboot in a single pc with dual core in order to have the
same effect above.
Is using : mpdboot -n 1 ~/mpd.hosts -ncpus=2 a correct approach ?
(in the last case mpd.hosts contents is just : node0).
Any comment would be very helpful.
Alex
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080711/33dbb9d5/attachment.htm>
More information about the mpich2-dev
