[mpich2-dev] running mpich2 single pc dual core machine
Alexandre Souza
costamfix at gmail.com
Fri Jul 11 14:47:24 CDT 2008
I am confused.. So there is no advantage in using mpich2 in a single pc dual
core machine ?
Alex
On 7/11/08, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> On a single PC, you just need to do "mpd &". Only a single mpd daemon is
> needed for all processes on that machine.
> Rajeev
> *From:* owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-dev at mcs.anl.gov]
> *On Behalf Of *Alexandre Souza
> *Sent:* Friday, July 11, 2008 9:46 AM
> *To:* mpich2-dev at mcs.anl.gov
> *Subject:* [mpich2-dev] running mpich2 single pc dual core machine
> Hi All,
> I have one question regarding running 2 processes in a single pc dual core
> machine:
> if I have two (one core) pcs I start the mpich with : mpdboot -n 2 -f
> ~/mpd.hosts
> with mpd.hosts contents: node0
> node1
> How can I use mpdboot in a single pc with dual core in order to have the
> same effect above.
> Is using : mpdboot -n 1 ~/mpd.hosts -ncpus=2 a correct approach ?
> (in the last case mpd.hosts contents is just : node0).
> Any comment would be very helpful.
> Alex
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080711/90492290/attachment.htm>
More information about the mpich2-dev
