[mpich2-dev] running mpich2 single pc dual core machine
Darius Buntinas
buntinas at mcs.anl.gov
Fri Jul 11 14:51:21 CDT 2008
You only need one mpd running per host. Once you start mpd,
mpiexec -n 2 ./myjob
will start two processes on the same host.
-d
On 07/11/2008 02:47 PM, Alexandre Souza wrote:
> Hi,
> I am confused.. So there is no advantage in using mpich2 in a single pc
> dual core machine ?
> Thanks,
> Alex
> On 7/11/08, *Rajeev Thakur* <thakur at mcs.anl.gov
> <mailto:thakur at mcs.anl.gov>> wrote:
> On a single PC, you just need to do "mpd &". Only a single mpd
> daemon is needed for all processes on that machine.
> Rajeev
> *From:* owner-mpich2-dev at mcs.anl.gov
> <mailto:owner-mpich2-dev at mcs.anl.gov>
> [mailto:owner-mpich2-dev at mcs.anl.gov
> <mailto:owner-mpich2-dev at mcs.anl.gov>] *On Behalf Of *Alexandre
> Souza
> *Sent:* Friday, July 11, 2008 9:46 AM
> *To:* mpich2-dev at mcs.anl.gov <mailto:mpich2-dev at mcs.anl.gov>
> *Subject:* [mpich2-dev] running mpich2 single pc dual core machine
> Hi All,
> I have one question regarding running 2 processes in a single pc
> dual core machine:
> if I have two (one core) pcs I start the mpich with : mpdboot -n
> 2 -f ~/mpd.hosts
> with mpd.hosts contents: node0
> node1
> How can I use mpdboot in a single pc with dual core in order to
> have the same effect above.
> Is using : mpdboot -n 1 ~/mpd.hosts -ncpus=2 a correct approach ?
> (in the last case mpd.hosts contents is just : node0).
> Any comment would be very helpful.
> Alex
More information about the mpich2-dev
