[mpich2-dev] running mpich2 single pc dual core machine
Rajeev Thakur
thakur at mcs.anl.gov
Fri Jul 11 13:37:56 CDT 2008
On a single PC, you just need to do "mpd &". Only a single mpd daemon is
needed for all processes on that machine.
Rajeev
_____
From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-dev at mcs.anl.gov] On
Behalf Of Alexandre Souza
Sent: Friday, July 11, 2008 9:46 AM
To: mpich2-dev at mcs.anl.gov
Subject: [mpich2-dev] running mpich2 single pc dual core machine
Hi All,
I have one question regarding running 2 processes in a single pc dual core
machine:
if I have two (one core) pcs I start the mpich with : mpdboot -n 2 -f
~/mpd.hosts
with mpd.hosts contents: node0
node1
How can I use mpdboot in a single pc with dual core in order to have the
same effect above.
Is using : mpdboot -n 1 ~/mpd.hosts -ncpus=2 a correct approach ?
(in the last case mpd.hosts contents is just : node0).
Any comment would be very helpful.
Alex
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080711/e2a0560c/attachment.htm>
More information about the mpich2-dev
