[mpich2-dev] running mpich2 single pc dual core machine
Alexandre Souza costamfix at gmail.com
Fri Jul 11 09:46:23 CDT 2008
Hi All,
I have one question regarding running 2 processes in a single pc dual core
machine:
if I have two (one core) pcs I start the mpich with : mpdboot -n 2 -f
~/mpd.hosts
with mpd.hosts contents: node0
                                      node1
How can I use mpdboot in a single pc with dual core in order to have the
same effect above.
Is using : mpdboot -n 1 ~/mpd.hosts -ncpus=2 a correct approach ?
 (in the last case mpd.hosts contents is just : node0).
Any comment would be very helpful.
Alex
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080711/7b0f77d7/attachment.htm>
More information about the mpich2-dev mailing list
