[mpich2-dev] dataloop bug
David Gingold
david.gingold at sicortex.com
Thu Aug 7 20:51:46 CDT 2008
Rob Ross says that I should send this patch along. It's a bug that
shows up only when ALL_BYTES is turned on in the dataloop code. (In
the stock code it's not turned on.)
Thanks for the help today, Rob!
-dg
--- dataloop_create_indexed.c.~1~ 2008-08-05 15:09:54.619072000 -0400
+++ dataloop_create_indexed.c 2008-08-07 14:05:46.049021000 -0400
@@ -266,6 +266,8 @@
/* increase block lengths so they are in bytes */
tmp_blklen_array[i] *= old_extent;
+ new_dlp->loop_params.i_t.total_blocks *= old_extent;
*dlp_p = new_dlp;
More information about the mpich2-dev
