[MPICH2-dev] implementing MPID_Wtick()
William Gropp
gropp at mcs.anl.gov
Fri Oct 12 13:12:33 CDT 2007
I don't have an example handy, though the intent was that a simple
definition of the MPID_Wtime functions should suffice (this would go
into mpidpre.h (or mpidpost.h if necessary). If that doesn't work,
then we need to fix something.
Bill
On Oct 11, 2007, at 2:50 PM, David Gingold wrote:
> On Oct 11, 2007, at 3:36 PM, William Gropp wrote:
>> You should be able to just define the MPID_Wtime functions
>> (MPID_Wtime, MPID_Wtime_diff, MPID_Wtime_todouble, MPID_Wtime_acc,
>> and MPID_Wtick. However, it looks like we may need to change the
>> top level configure to allow you to specify "device provides
>> timer". Would that be ok?
> That sounds like the right idea. What I'd like specifically is to
> have the device provide its own version of what is in
> mpichtimer.h. That way I can inline some of the operations as
> appropriate, particularly when our kernel implements some timer
> mechanisms that are better than gettimeofday().
> If you want to provide an example of how this should be structured
> in the headers, etc., I'll follow that. Otherwise I can try to
> come up with something myself.
> -dg
More information about the mpich2-dev
