[MPICH2-dev] implementing MPID_Wtick()
William Gropp
gropp at mcs.anl.gov
Fri Oct 12 13:17:15 CDT 2007
One more thing. It looks like the device will need to export the
datatype of the timer as
MPID_DEVICE_TIMER_TYPE
E.g.,
MPID_DEVICE_TIMER_TYPE=int64_t
This, as well as support for -with-timer=device, will be in my next
checkin.
Bill
On Oct 11, 2007, at 2:50 PM, David Gingold wrote:
> On Oct 11, 2007, at 3:36 PM, William Gropp wrote:
>> You should be able to just define the MPID_Wtime functions
>> (MPID_Wtime, MPID_Wtime_diff, MPID_Wtime_todouble, MPID_Wtime_acc,
>> and MPID_Wtick. However, it looks like we may need to change the
>> top level configure to allow you to specify "device provides
>> timer". Would that be ok?
> That sounds like the right idea. What I'd like specifically is to
> have the device provide its own version of what is in
> mpichtimer.h. That way I can inline some of the operations as
> appropriate, particularly when our kernel implements some timer
> mechanisms that are better than gettimeofday().
> If you want to provide an example of how this should be structured
> in the headers, etc., I'll follow that. Otherwise I can try to
> come up with something myself.
> -dg
More information about the mpich2-dev
