[MPICH2-dev] implementing MPID_Wtick()
William Gropp
gropp at mcs.anl.gov
Thu Oct 11 14:36:52 CDT 2007
David,
You should be able to just define the MPID_Wtime functions
(MPID_Wtime, MPID_Wtime_diff, MPID_Wtime_todouble, MPID_Wtime_acc,
and MPID_Wtick. However, it looks like we may need to change the top
level configure to allow you to specify "device provides timer".
Would that be ok?
Bill
On Oct 11, 2007, at 1:50 PM, David Gingold wrote:
> Bill --
> I agree that it would be cleaner just to supply our own
> implementations of those MPID functions, but I don't see how to do
> it easily within the existing structure of the MPICH2 code. The
> code in src/mpi/timer/mpidtime.c is always built into the library
> (I think), but in our case I'd like to override that with device-
> specific code in src/mpid/sc, where our MPID implementation lives.
> You see what I'm saying? Am I missing a way to do this?
> -dg
> On Oct 10, 2007, at 2:57 PM, William Gropp wrote:
>> David,
>> The original thinking was that the device would provide its own
>> MPID_Wtime/MPID_Wtick implementation, overriding the default
>> implementations. That's what I'd prefer, rather than adding yet
>> another option to configure :) . Let us know if that won't work
>> for you.
>> Bill
>> On Oct 10, 2007, at 1:09 PM, David Gingold wrote:
>>> Here is a question about implementing MPID_Wtick() in MPICH2:
>>> We're presently using gettimeofday() on our system to implement
>>> MPI_Wtime(). As far as I know, there is no way to ask Linux what
>>> the resolution of gettimeofday() is, but I happen to know the
>>> answer in our case: 1 microsecond. The "generic" implementation
>>> of MPID_Wtick() tries to determine this, but now and then it
>>> returns different values for different ranks.
>>> To solve this, I'm inclined to add a parameter to configure.in
>>> that lets me specify, at build time, the value that MPI_Wtick()
>>> should return. Is there a better way? Is it expected, for
>>> example, that an ADI3 implementation might provide its own
>>> versions of the functions in src/mpid/timer/mpidtime.c, replacing
>>> or overriding what is there?
>>> -dg
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20071011/5fda57f3/attachment.htm>
More information about the mpich2-dev
