[MPICH2-dev] implementing MPID_Wtick()
David Gingold
david.gingold at sicortex.com
Thu Oct 11 13:50:09 CDT 2007
Bill --
I agree that it would be cleaner just to supply our own
implementations of those MPID functions, but I don't see how to do it
easily within the existing structure of the MPICH2 code. The code in
src/mpi/timer/mpidtime.c is always built into the library (I think),
but in our case I'd like to override that with device-specific code
in src/mpid/sc, where our MPID implementation lives.
You see what I'm saying? Am I missing a way to do this?
-dg
On Oct 10, 2007, at 2:57 PM, William Gropp wrote:
> David,
> The original thinking was that the device would provide its own
> MPID_Wtime/MPID_Wtick implementation, overriding the default
> implementations. That's what I'd prefer, rather than adding yet
> another option to configure :) . Let us know if that won't work
> for you.
> Bill
> On Oct 10, 2007, at 1:09 PM, David Gingold wrote:
>> Here is a question about implementing MPID_Wtick() in MPICH2:
>> We're presently using gettimeofday() on our system to implement
>> MPI_Wtime(). As far as I know, there is no way to ask Linux what
>> the resolution of gettimeofday() is, but I happen to know the
>> answer in our case: 1 microsecond. The "generic" implementation
>> of MPID_Wtick() tries to determine this, but now and then it
>> returns different values for different ranks.
>> To solve this, I'm inclined to add a parameter to configure.in
>> that lets me specify, at build time, the value that MPI_Wtick()
>> should return. Is there a better way? Is it expected, for
>> example, that an ADI3 implementation might provide its own
>> versions of the functions in src/mpid/timer/mpidtime.c, replacing
>> or overriding what is there?
>> -dg
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20071011/c857c8cf/attachment.htm>
More information about the mpich2-dev
