[MPICH2-dev] implementing MPID_Wtick()
William Gropp
gropp at mcs.anl.gov
Wed Oct 10 13:57:02 CDT 2007
David,
The original thinking was that the device would provide its own
MPID_Wtime/MPID_Wtick implementation, overriding the default
implementations. That's what I'd prefer, rather than adding yet
another option to configure :) . Let us know if that won't work for
you.
Bill
On Oct 10, 2007, at 1:09 PM, David Gingold wrote:
> Here is a question about implementing MPID_Wtick() in MPICH2:
> We're presently using gettimeofday() on our system to implement
> MPI_Wtime(). As far as I know, there is no way to ask Linux what
> the resolution of gettimeofday() is, but I happen to know the
> answer in our case: 1 microsecond. The "generic" implementation of
> MPID_Wtick() tries to determine this, but now and then it returns
> different values for different ranks.
> To solve this, I'm inclined to add a parameter to configure.in that
> lets me specify, at build time, the value that MPI_Wtick() should
> return. Is there a better way? Is it expected, for example, that
> an ADI3 implementation might provide its own versions of the
> functions in src/mpid/timer/mpidtime.c, replacing or overriding
> what is there?
> -dg
> David Gingold
> Principal Software Engineer
> SiCortex
> Three Clock Tower Place, Suite 210
> Maynard MA 01754
> (978) 897-0214 x224
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20071010/8c40e181/attachment.htm>
More information about the mpich2-dev
