[MPICH2-dev] RE: alignment hints for calculating the file domain.
Yu, Weikuan
wyu at ornl.gov
Sun Jul 15 15:31:14 CDT 2007
Further update on this, attached is the working code I have in the Lustre ADIO driver.
The condition checking on "fd->file_system == ADIO_LUSTRE" can be removed for generic usage, assuming fs-specific ADIO saves a file's striping parameters in fd->info.
Weikuan Yu <+> 1-865-574-7990
http://ft.ornl.gov/~wyu/
-----Original Message-----
From: owner-mpich2-dev at mcs.anl.gov on behalf of Yu, Weikuan
Sent: Tue 7/10/2007 11:00 AM
To: Robert Latham
Cc: wangdi; mpich2-dev at mcs.anl.gov
Subject: RE: [MPICH2-dev] RE: alignment hints for calculating the file domain.
> From: Robert Latham [mailto:robl at mcs.anl.gov]
> On Tue, Jul 10, 2007 at 08:55:18AM -0400, Yu, Weikuan wrote:
> > Wangdi has observed a lot of lock contentions when the file domain
> > partitions in collective IO are not aligned on Lustre
> stripe boundary
> > (say 1MB). As a remedy of that, we are proposing a minor
> change on the
> > implementation of ADIOI_GEN_Calc_file_domains() for it to
> respect an
> > advisory alignment. The attached patch illustrates what we are
> > proposing.
> Ok, so you turn fd_size from an output parameter to an in/out
> parameter. I don't think that's introducing noticeably more
> complexity to the interface.
Right, that's the intention. We want to avoid a new function which adds
very little to the existing one.
> Before you call calc_file_domains, how will you set fd_size?
> Through a hint the user can override?
We can do that with a separate ADIO driver. For Lustre, we can find out
the stripe_size from the file attributes. Users can also suggest an hint
on stripe_size of new files.
--Weikuan
> > P.S.: We will use mpich-discuss at mcs.anl.gov for further
> discussions if
> > mpich2-dev is not for this purpose.
> I think this list will be fine.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division A215 0178 EA2D B059 8CDF
> Argonne National Lab, IL USA B29D F333 664A 4280 315B
Type: text/x-patch
Desc: striping-alignment.patch
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20070715/37cab8b8/attachment.bin>
More information about the mpich2-dev
