[MPICH2-dev] RE: alignment hints for calculating the file domain.
Yu, Weikuan wyu at ornl.gov
Tue Jul 10 10:00:41 CDT 2007
> -----Original Message-----
> From: Robert Latham [mailto:robl at mcs.anl.gov]
> On Tue, Jul 10, 2007 at 08:55:18AM -0400, Yu, Weikuan wrote:
> > Wangdi has observed a lot of lock contentions when the file domain
> > partitions in collective IO are not aligned on Lustre
> stripe boundary
> > (say 1MB). As a remedy of that, we are proposing a minor
> change on the
> > implementation of ADIOI_GEN_Calc_file_domains() for it to
> respect an
> > advisory alignment. The attached patch illustrates what we are
> > proposing.
> Ok, so you turn fd_size from an output parameter to an in/out
> parameter.  I don't think that's introducing noticeably more
> complexity to the interface.
Right, that's the intention. We want to avoid a new function which adds
very little to the existing one.
> Before you call calc_file_domains, how will you set fd_size?
> Through a hint the user can override?
We can do that with a separate ADIO driver. For Lustre, we can find out
the stripe_size from the file attributes. Users can also suggest an hint
on stripe_size of new files.
--Weikuan
> > P.S.: We will use mpich-discuss at mcs.anl.gov for further
> discussions if
> > mpich2-dev is not for this purpose.
> I think this list will be fine.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
> Argonne National Lab, IL USA                 B29D F333 664A 4280 315B
More information about the mpich2-dev mailing list
