[MPICH2-dev] MPICH2 bugs in configure and maybe MPI_Cancel
Philippe Combes
Philippe.Combes at ens-lyon.fr
Sat Nov 18 11:00:09 CST 2006
Sorry, I did not check for new messages before answering to Guillaume.
With regards to shared libs, with
./configure --with-device=ch3:ssm --without-mpe --disable-f77
--disable-f90 --enable-cxx --enable-sharedlibs=gcc --enable-fast
--prefix=/usr/local/mpich
I get a libmpich.so installed, but no libmpichcxx.so whereas there is a
libmpichcxx.a
Maybe both static libraries are merged into one for the shared object
version ?
William Gropp a écrit :
> This may be from another bug that I fixed - the same message was used
> for MPI calls *after* finalize as before MPI_Init. Its possible that
> this is coming from with Finalize, but after Finalize is expecting to
> see communication. Can you send your test program? We'd like to find
> and fix these problems. Thanks!
> Bill
> On Nov 17, 2006, at 3:36 PM, Philippe Combes wrote:
>> If I fix myself the mpichconf.h file to have _really_ error checking
>> and messages enabled, then I get on all processes:
>> Error encountered before initializing MPICH
>> Program exited with code 01.
>> Poor me, I have no more clue about why my send request is invalid...
>> Furthermore, it says "before intializing" although these errors occur
>> AT THE END of the execution and all communications were OK before.
>> Could you please help me ?
More information about the mpich2-dev
